Closed Thread
Old 10-27-2012, 02:55 PM   #376
Wdwrkr
Wdwrkr's Avatar
Oddometer: 2,013
Originally Posted by skipn View Post
Price reduced to $300
Would those bags fit a 73 75/? Would that be bastardizing my girl? Let me know
Wdwrkr is offline
Old 10-27-2012, 03:22 PM   #377
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,522
If your /5 is a LWB then they would bolt right up. You might have to shorten the turn signal stock which is easy to do with a pipe cutter.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is offline
Old 10-28-2012, 07:01 AM   #378
skipn
Oddometer: 145
I am not familiar enough with the different bikes to say. I was told by one fellow that they were pretty interchangeable, but I don't know for a fact. Maybe somebody can chime in.
skipn is offline
Old 10-28-2012, 04:44 PM   #379
kanakaka
kanakaka's Avatar
Oddometer: 286
Need beater mufflers
Looking for a set of cosmetically challenged mufflers for an R90/6. Surface rust is fine but not major rust holes. Plan on cutting them up to make a set of custom mufflers. I'm in central Florida toward the east coast. Thanks!
Race the rain, feel the wind and chase a sunset...
kanakaka is offline
Old 10-28-2012, 05:12 PM   #380
brocktoon
brocktoon's Avatar
Oddometer: 257
I have a set to ship from here in Northern California if you aren't able to find any closer by.
brocktoon is offline
Old 10-28-2012, 05:14 PM   #381
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,982
The /5 bikes are model years 1970 to 1973. They started with what became known as the SWB, Short Wheel Base, models and later the wheel base was lengthened by the extension of several parts of the frame. To begin with the swing arm is longer in a LWB bike, Long Wheel Base. This longer part can sometimes be recognized by welds in the drive shaft tube of the swing arm, but that is not a diffinative touch because the swing arm may be a longer one with out the welds.
Picture stolen from Duane Ausherman.
The sub frame is longer and the seat is longer on a LWB bike.
To make this more confusing there is no cut off or model change date. For a while they made both LWB and SWB bikes. And in the later 70's and 80's it was popular to make a LWB /6 or /7 into a SWB bike by swapping some parts around. You just have to learn how to spot them
How all this effects the luggage is interesting. The bag frames attach to several places. On a LWB bike the frames are different. The bags are the same but not the frames.
---Albert Einstein
disston is online now
Old 10-28-2012, 05:29 PM   #382
civhatch90
civhatch90's Avatar
Oddometer: 128
Looking for fork tubes (do not need the entire front end, just the tubes) for a 1974 R90/6.
civhatch90 is offline
Old 10-28-2012, 05:31 PM   #383
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,243
Really? I thought it was the subframe that was different, but the frames have the same geometry - though there may be differences in construction or tabs etc.
Wirespokes is offline
Old 10-28-2012, 05:35 PM   #384
Boxer Metal
Mad Scientist
Oddometer: 3,522
You are correct.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 10-28-2012, 06:47 PM   #385
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,982
This paragraph, two sentences, is about the bags. So it says the "bag frames" are different, not the bike frames. I did mention earlier that the "sub frames" are different.
This does get confusing. There is the bike frame, the bike sub frame, the bag frame.
All the bike frames are the same length.
On short or long wheel base bikes the sub frames and the bag frames correspond to the model. Seats also are either SWB or LWB.
Just trying to make it some what clearer but of course any time I do that it gets more confusing.
---Albert Einstein
Old 10-28-2012, 08:18 PM   #386
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,995
Google "Forking By Frank" if you're looking for new at a good price.
Big Bamboo is online now
Old 10-28-2012, 09:45 PM   #387
Boxer Metal
Mad Scientist
Oddometer: 3,522
PM sent
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 10-29-2012, 03:23 PM   #388
dan-o
Oddometer: 81
looking for a good used exhaust crossover tube/clamps and a choke lever assy for a /5. building a bike on a tight budget. thanks
edit (found the choke lever) still need the crossover
dan-o screwed with this post 10-30-2012 at 05:26 AM
dan-o is offline
Old 10-29-2012, 04:42 PM   #389
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,577
Originally Posted by dan-o View Post
a choke lever assy for a /5... building a bike on a tight budget.
Bend yourself some of these out of some heavy wire. Solved.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is offline
Old 10-29-2012, 06:23 PM   #390
Boxer Metal
Mad Scientist
Oddometer: 3,522
R100GS Rear Wheel and Sidestand
According to BMW these are no longer available. Good spokes, runs true. Light corrosion on the spoke nipples and hub. I will have the tire removed before shipping. $400 or OBO plus shipping.
Sidesand is in pretty good shape. Has a couple of holes drilled in the foot. $75.00
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal screwed with this post 10-31-2012 at 08:33 AM
Closed Thread
Times are GMT -7.   It's 10:10 PM.
