Closed Thread
Old 01-11-2013, 08:03 PM   #616
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,083
Originally Posted by bmweuro View Post
78-80 or 81-95?
Good point! I hadn't thought about the fact the ribbed style came out before the updated clutch.
I need a transmission cover for an 81-95 trans.
Wirespokes is offline
Old 01-11-2013, 09:13 PM   #617
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,195
Also available new. 46 54 2 300 008 Max's lists for $33.79 I bought one about a year ago. You will get a pair of keys. Number will be random but if you know the number of the other one they can try to match it.
---Albert Einstein
disston is online now
Old 01-12-2013, 05:47 AM   #618
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,419
Originally Posted by strichzwei View Post
Searching for a latch for my airhead BMW luggage, the one that attaches to the carrier frame and is riveted to the luggage, no key needed.
Cheers,
Scott
Fyi, just in case, the 3 digit code for the key is stamped into the side of the lock, when it's opened. Usually, keys of a certain number can't be ordered and there are 30 or so possibilities at least.
boxerboy81 screwed with this post 01-12-2013 at 05:54 AM
boxerboy81 is online now
Old 01-13-2013, 12:31 PM   #619
some_guy
some_guy's Avatar
Oddometer: 144
Corbin R85DT
Hello all,
I have here a Corbin seat that I have no use for. It is a R85DT. More info can be found here: http://www.corbin.com/bmw/8593dual.shtml
Its in good shape with the exception of the one corner that has a small tear and a couple spots on the bottom lip are a bit rough. I don't know when Armando built this seat, but the sticker has patent dates of 02 on it. I'm not really sure what to ask for it, so $150 + $30 for shipping. If you're local to the NoVA area I can deliver within 20 miles or so, or you can pick it up. If you think $150 is a bit too much let me know, and feel free to make me an offer.
If your name is Airhead Al and want the seat back, give me a shout and I'll deliver it.
Pictures:
https://lh3.googleusercontent.com/-S...113_134816.jpg
https://lh3.googleusercontent.com/-P...113_134823.jpg
https://lh4.googleusercontent.com/-O...113_134841.jpg
https://lh6.googleusercontent.com/-0...113_134909.jpg
https://lh4.googleusercontent.com/-a...113_134858.jpg
https://lh3.googleusercontent.com/-d...113_134853.jpg
some_guy is offline
Old 01-13-2013, 02:11 PM   #620
some_guy
some_guy's Avatar
Oddometer: 144
Instrument Cluster
SOLD! Thanks.
I also have an instrument cluster off a 95 R100RT.
Speedometer, tach, odometer, trip, trip reset, oil pressure, generator all work. Sometimes the neutral indicator works. The turn signal and high beam indicators have never worked, might just be the bulbs. Other than that its in good shape. The previous owner fixed a broken trip reset button with a pen and a screw....it works though, I used it like that for the last few thousand miles resetting it every tank.
Also included is the bracket and the connector with about 16" of wire on it. $200 + $20 shipping gets it. If you think that's too much make me an offer. If you're in the NoVA area I can deliver within 20 miles or so, or you can pick it up.
Pictures:
https://lh5.googleusercontent.com/-R...113_134414.jpg
https://lh6.googleusercontent.com/-v...113_134433.jpg
https://lh5.googleusercontent.com/-v...113_134454.jpg
https://lh5.googleusercontent.com/-i...113_134702.jpg
https://lh6.googleusercontent.com/-Q...113_134608.jpg
https://lh4.googleusercontent.com/-_...113_134531.jpg
https://lh5.googleusercontent.com/-J...113_134630.jpg
some_guy screwed with this post 01-15-2013 at 04:58 AM
some_guy is offline
Old 01-13-2013, 07:58 PM   #621
strichzwei
Oddometer: 28
Thanks to everyone who responded, the coding info is great!
Scott
Cheers,
Scott
IMG_20121223_135010 by gummikuh, on Flickr
strichzwei is offline
Old 01-13-2013, 10:12 PM   #622
SJ BMW
SJ BMW's Avatar
Oddometer: 79
WTB 2.81 rear drive
I need a 2.81 rear drive (or 2.81 gear set) for a twin shock for our Bonneville project this year. Price? Tell me what you got.... They would be 31:11
Chris
Faster than you
SJ BMW screwed with this post 01-16-2013 at 06:38 PM
SJ BMW is offline
Old 01-14-2013, 11:32 AM   #623
oldbmw
havehandlebarswillrideit
oldbmw's Avatar
Oddometer: 197
Wtb "normal" aftermarket side stand for BMW R100GS
oldbmw is offline
Old 01-14-2013, 01:16 PM   #624
swanker
Shadetree Tinkerer
Oddometer: 146
PM Sent
Originally Posted by Jim K in PA View Post
I am looking for a straight pair of snowflake wheels for my '79 R100 T with drum rear brake/front dual disk. 18" rear and 19" front. I have and use the originals that are fine, but want a second set to mount up some knobbly tires for more enthusiastic use. Not too concerned about the finish, but must be straight, and the front should be the revised design. Nearer to Pennsylvania the better.
Figured I would check here before I retreat to eBay.
Thanks.
swanker is offline
Old 01-14-2013, 02:18 PM   #625
apt13 OP
Oddometer: 476
WTB: crash guards and seat trim
still looking for a set of black crash/engine guards that would fit a 78 r80/7. i like the 2 piece kind and not the one piece. they don't need to be pretty.
also need the black plastic seat trim pieces for a stock /7 seat. with all you folks creating custom seats, got any of these laying around from your old rusty torn seats?
thanks
'78 R80/7
'74 CB360
Airhead Tshirts!
apt13 is offline
Old 01-14-2013, 03:57 PM   #626
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,860
Anyone a magician?
This is the reason I was looking for a LWB seat pan...any ideas?
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline
Old 01-14-2013, 05:07 PM   #627
brittrunyon
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 490
What is a "normal" aftermarket side stand?
I might want one also?
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is offline
Old 01-14-2013, 05:29 PM   #628
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,195
There are people that can fix something like that but it likely would cost two or three times more than another seat pan from Ebay or a Flea Market. It just means you may be looking for the part you need for awhile. Wire brush it and throw some paint on it. Use it till you get another.
---Albert Einstein
Old 01-14-2013, 06:28 PM   #629
woodly1069
woodly1069's Avatar
Oddometer: 1,860
Yeah, kinda posted it as a joke!
Old 01-14-2013, 07:19 PM   #630
benthic
glutton 4 punishment
benthic's Avatar
Oddometer: 397
thanks
I might have something for each of you. please remind me if I don't contact you in a day or so, but i have crashbars, trim pieces and a seat pan that is better than you have;)...
1978 BMW R80/7
"all we need is time and courage." - Renner
"A lightened flywheel on your bike is like me getting into Spandex and putting on track shoes to walk the dog." - M
www.blindfishz.com
benthic is offline
Closed Thread
Times are GMT -7.   It's 04:41 PM.
