Closed Thread
Old 02-22-2013, 02:32 PM   #736
Les_Garten
Les_Garten's Avatar
Oddometer: 732
Originally Posted by garthg View Post
Not helpful.
The holes are plugged, and the bike runs fine. Petcocks are not leaking. I'd like to reduce emissions and mouthfuls of fumes after filling up. I've pulled the tank and it's obvious that fumes are coming out of the extra vent on the bottom of the tank on this evap.-equipped bike.
The links provided are all from people wanting to remove the smog equipment.
I'd like to hear from readers who may have this stuff sitting around their garage and want to part with it.
Do you have the drain hose for the tank vent in place?
Les_Garten is offline
Old 02-22-2013, 02:40 PM   #737
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,540
Originally Posted by bpeckm View Post
I have all the airbox stuff if you need that, but that is the for air-injection... I think the OP is talking about getting the SHED equipment that vents the tank itself? Different ball o' wax....
Yeah, I was thinking about the air injection stuff too.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline
Old 02-22-2013, 03:34 PM   #738
garthg
garthg's Avatar
Oddometer: 392
Originally Posted by saddlsor View Post
would it be possible to run a hose from the vent on the bottom to the airfilter housing? sort of recycle the fumes. all that vent does is drain spilled gas. on mine, I have a hose from that vent to the bottom of the frame. anything that comes out goes right to the ground.
That's what I've got, too.
Originally, the hose would have been connected to a charcoal canister under the seat, possibly with a valve of some sort.
garthg is offline
Old 02-22-2013, 03:36 PM   #739
garthg
garthg's Avatar
Oddometer: 392
Mike
Right. I'm looking for all the stuff shown in this fiche, 11 through 15 with all the hoses, check valves, etc.
None of this stuff hurt performance, but it kept the gas fumes out of the air and my nose.
garthg is offline
Old 02-22-2013, 04:07 PM   #740
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,008
Right. I'm looking for all the stuff shown in this fiche, 11 through 15 with all the hoses, check valves, etc .
Just run a line from the vapor bung to a generic automotive carbon cannister.
In all my years with BMW's I have yet to actually see any of those parts you want. In fact, I have only seen a picture of the engine cover with the holes in it for that plumbing.
Another option is to search this forum for the few that have discusses the shed plumbing and may still have it, for example:
Originally Posted by mykill View Post
Do your fuel lines go directly from the tank to the carbs?
My California model GS has solenoids under the starter cover that shut off the fuel when ignition is off. Those solenoids might have a questionable electrical connection. If you do, bypass and go straight from tank to carb and report back! Now you will NEED to remember to shut off your gas when parked.
and another:
Originally Posted by Grider Pirate View Post
My '88 RS has the fuel cutoff solenoid too. I'll pitch it someday but until I do, I carry bypass fuel lines, already cut to length. Being an electro-mechanical part, someday it WILL fail.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo screwed with this post 02-22-2013 at 04:14 PM
Solo Lobo is offline
Old 02-22-2013, 04:51 PM   #741
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,213
Man is this ever a silly discussion!
There are two attachment points under the tank for hoses. One is for the gas cap gutter, the other is a vent from inside the tank.
All of the BMWs before 1980? had none of the extra valves and garbage we've all removed. And you know what? I don't ever smell gas fumes! It's my opinion you're smelling fumes because enough gas went down the gutter drain to spill on top of the starter cover and evaporate.
First off, run a line from those attachment points back behind the transmission. Secondly, watch what you're doing and don't splash gas into the overflow gutter!
Really, it's that easy! Don't make such a big production out of it!
If you're smelling fumes without gas having run down the gutter drain, then there's something wrong. Either there's a split in the tank (rare, but I've heard of it happening) or one of the fuel lines is seeping - usually at the carb attachment point.
Wirespokes is offline
Old 02-22-2013, 05:01 PM   #742
100RT
100RT's Avatar
Oddometer: 747
Feel all around the bottom edge of the gas tank and see if its moist. I had a weep coming from one of the welds at the rear mounting bracket under the tank. I think Wirespokes has it correct.
100RT is offline
Old 02-22-2013, 06:14 PM   #743
Les_Garten
Les_Garten's Avatar
Oddometer: 732
He can't answer you right now.
He's picketting the La Brea tar pits ...
Old 02-23-2013, 04:40 AM   #744
luxlogs
luxlogs's Avatar
Oddometer: 301
I got the swiss cheese starter cover for ya if you want it, believe me nobody else does.
PM me
ABC # 11808
74 911S
87 TW200
82 R65LS
92 R100GS
luxlogs is offline
Old 02-23-2013, 06:25 AM   #745
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,465
I have a 17" rear rim that came off an 1993 (?) R100GS. It's in great shape. Just the rim
$100 / Offers? PM Me.
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline
Old 02-23-2013, 09:38 AM   #746
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,543
Why are you selling things in this thread?
Oh, THATS RIGHT!!!!! It's a flea market thread.
hardwaregrrl is offline
Old 02-23-2013, 11:05 AM   #747
ed mocz
Bristol WI
ed mocz's Avatar
Oddometer: 207
R100 heads
Pair of heads that came off of a 1978 R100s. Large valve with air injection. Not original heads. Unknown miles, good condition except one needs the exhaust threads repaired and some nicks in a fin or 2.
150.00 or make a nice offer. Pics: http://razzi.me/a/22552
1978 BMW R100/7 A holy union/cheap bike challenge combo.
ed mocz screwed with this post 02-23-2013 at 12:31 PM Reason: added info
ed mocz is offline
Old 02-23-2013, 11:25 AM   #748
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,138
Originally Posted by ed mocz View Post
Pair of heads off of a 1978 R100s. Unknown miles, good condition except one needs the exhaust threads repaired and some nicks in a fin or 2.
200.00 or make a nice offer. Pics: http://razzi.me/a/22552
The heads in your pictures are not '78 S heads. They're at least '81 or newer.
Completely different animal for anyone who's specifically looking for '77 or '78 S heads.
fwiw.
Lornce is offline
Old 02-23-2013, 12:28 PM   #749
ed mocz
Bristol WI
ed mocz's Avatar
Oddometer: 207
Changed ad
Thanks Lornce, fixed ad.
And, what is fwiw? Never mind, I looked it up.
ed mocz screwed with this post 02-23-2013 at 12:33 PM Reason: added info
ed mocz is offline
Old 02-24-2013, 02:11 PM   #750
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,854
R80ST parts
I have a couple of take-offs from an '83 R80ST in very ordinary condition:
  • chrome handlebars (same bars as on the Slash 6 (60/6, 75/6, 90/6) GONE RIDIN'
  • headlight bucket (bucket only, no lens, lights, wires, etc) (same as R65)
I recognize that neither of these has any real inherent or intrinsic (huh?) value... if anybody wants or needs them, let me know and I can sell real cheap plus postage....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm screwed with this post 03-18-2013 at 07:47 AM Reason: clarify bar and bucket fitment
bpeckm is offline
Closed Thread
Times are GMT -7.   It's 03:14 AM.
