01-29-2013, 10:24 AM
#811 |
Mad Scientist
Oddometer: 2,966
Boxer Metal Free Shipping
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
01-29-2013, 01:47 PM
#812 |
Oddometer: 430
very reluctant sale
http://corvallis.craigslist.org/mcy/3562189415.html BMW R80RT Work that’s been done. 3 years ago I reconditioned this bike to be reliable and fun. Most of this was to be preventive work. When I got the bike it needed brakes, pushrod tube seals and had electrical issues. Wheels and suspension New front wheel bearings Repack steering head bearings Rebuild front forks, new seals and fluid Progressive front springs “Works” rear gas shock with remote reservoir Farley side stand Brakes Rebuilt master cylinder Rebuilt calipers New speigler front rotors New spiegler stainless brake lines EBC “HH” pads BMW rear shoes Electrical Alternator brushes Diode board High voltage regulator New ignition control module “Run-n-lites” on rear Hyper lite brake lights Dyna coil Bosch wires, ngk plug caps VDO amp gauge Stock clock works, but is unplugged so as not to drain battery New battery on order Fuel Flushed gas tank ( yearly) Rebuilt petcocks Rebuilt carbs Fuel lines Aux filters (yearly) Controls New speedo, clutch and throttle cables New throttle tube and gears on handlebar Final drive Swapped stock to a 32/10 ratio. Helps with fuel milage and lowers RPM by 500 rpm at 70mph Big bearing, seal and brake shaft o-rings Engine Timing chain, sprockets and tensioner Rod bearings, piston pin bushings and rings Valves hand lapped Clutch disc Both rear seals New oil pump Transmission Completely rebuilt ( Steve Prokov, dundee oregon) Bearings and seals “Circlip” modification and install |
01-29-2013, 02:08 PM
#813 |
Airhead
Oddometer: 509
Have a few things that haven't sold yet:
- Corbin dual seat (all Black) for R100 GS and R - $175 plus shipping - Stock re-covered dual seat (Black and Grey) for R100GS and R - $135 + shipping - Triples and Forks from K100RS (bars have already sold) - R100R collector and muffler |
01-29-2013, 05:17 PM
#814 |
Knows all - tells some.
Oddometer: 12,889
Best of luck on your sale, coastranger; sad to see your bike go on the block.
Remodeling. Please check again later. |
01-30-2013, 04:08 AM
#815 |
turd polisher
Oddometer: 774
^SWB or LWB?
I wouldn't bring her home to Mama, but Mama ain't home tonight. |
01-30-2013, 04:13 AM
#816 |
G(/)S ... what else!
SWB ... but I didn't think there was a difference in subframes, was there?
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me] ... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake] Stephen Bottcher Ontario, Canada '72 R75/5 The Blues www.stephenbottcher.net |
01-30-2013, 04:56 AM
#817 |
Oddometer: 2,296
Yes, there was. The LWB /5's can use the /6 seats.
1974 BMW R90 /6 1968 Bultaco Matador MK3 1973 BMW R75 /5 Toaster LWB 1969 Bultaco Bandido MK2 2013 Husqvarna Terra TR650 |
01-30-2013, 06:47 AM
#818 |
ShadeTreeExpert
Oddometer: 5,026
There is a difference in the sub-frame, swing arm, drive shaft and seat. I think the fenders are the same. Oh and something else is happening with the battery box. Since I don't own a SWB I'm not sure about the battery box thing.
You /5 guys are lucky we let you use 12 volts.
Never memorize something you can look up. ---Albert Einstein |
01-30-2013, 06:50 AM
#819 | |
Oddometer: 2,296
01-30-2013, 12:50 PM
#820 |
Oddometer: 6
WTB: stock r100gs tank or a P/D front end. I have an '87 that I am trying to get back on the road.
For sale to anyone who may be interested (as I have no need for it) an Acerbis 13 gal. Plastic tank. Was white, now slightly tan. |
01-30-2013, 10:34 PM
#821 |
Oddometer: 4
Need R100 85-95 gas cap
Hi everybody. Got a cool tank from an R100 1985 to1995 for my cafe project but cant find a gas cap. Anybody have a spare they will sell?
01-31-2013, 06:09 AM
#822 |
Oddometer: 187
WTB: /5 Stock Side Stand
Like the title says, loking for a stock side stand for my 1971 R60/5. Not concerned with surface finish, but it must be straight.
Not interested in aftermarket, only stock. PM if you got something. Thanks!!
I might have been born yesterday, but I stayed up all night. |
01-31-2013, 09:11 AM
#823 | |
A proud pragmatist.
Oddometer: 2,870
Have tools, will travel!
01-31-2013, 07:02 PM
#824 |
Oddometer: 21
I'm looking for some 74 R90 /6 handle bars
Sent from my DROID RAZR HD using Tapatalk 2 |
01-31-2013, 07:44 PM
#825 |
BAM!!
Oddometer: 464
Looking for a r100gs transmission. 90-95
Looking for a r100gs transmission. 90-95.
