Closed Thread
Old 06-04-2013, 08:21 PM   #1246
richarddacat
high on honeysuckle
richarddacat's Avatar
Oddometer: 3,499
Originally Posted by Plaka View Post
Your stand isn't the same as mine at all. Mine is black and has a Barbie duct taped to the cross bar.
Mount the stand. if the bike goes up on it and both wheels are touching the ground, it fits. Then you need springs or extenders.
If the bike won't go up on it or both wheels aren't on the ground, it doesn't fit. Get another.
I've had it mounted but the springs won't hold it up.
That's what I'm saying, the fricking stock springs don't work with the Reynolds.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is offline
Old 06-04-2013, 08:26 PM   #1247
Plaka
Brevis illi vita est
Oddometer: 4,609
So the stand fits and works and all that and it's just the springts that are the issue?
Don't assume that the stock springs don't work. I'll look at mine in the AM, it's cold and rainy and dark and scary out at the moment. And I been in the Margaritas pretty hard.
Plaka is offline
Old 06-04-2013, 10:10 PM   #1248
GSAviator
GSAviator's Avatar
Oddometer: 133
Originally Posted by exhaust_nut View Post
That bracket on the top of your loops usually gets mounted facing down to stiffen the loops, but I guess you can use it as a grab rail too.
Thanks! That's the way it was mounted when I bought the bike, and I did not question it. Makes sense, though.
Turkey Creek Jack Johnson: Why you doin' this, Doc?
Doc Holliday: Because Wyatt Earp is my friend.
Turkey Creek Jack Johnson: Friend? Hell, I got lots of friends.
Doc Holliday: I don't.
GSAviator is offline
Old 06-04-2013, 11:50 PM   #1249
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,234
The ride-offs I've had used different springs and hooked to the lower frame cross bar behind the transmission. They had a half moon sheet metal piece that looped around that cross member, with a hole in one end the spring hooks into.
It would be easy enough to fabricate something better.
Wirespokes is offline
Old 06-05-2013, 04:30 AM   #1250
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,945
The springs on my Ride Off stand finally got too tired and I had to replace them. I tried the stock springs from a dealer but these didn't fit right. I ended up with some springs from the local hardware store. I only have one of the moon clips to anchor the springs on the cross member so I will have to fashion another sort of anchor to get a second spring on the stand. Currently my center stand works with only one spring, it stays up but it is kinda weak and the second spring will return it to it's snappy attitude.
---Albert Einstein
disston is online now
Old 06-05-2013, 09:06 AM   #1251
richarddacat
high on honeysuckle
Oddometer: 3,499
Well, that explains a few things.
Mid-TN Tag Riders
Old 06-05-2013, 09:30 AM   #1252
Plaka
Oddometer: 4,609
My springs go to the stock spring mounts on the frame. They rub on the oil cooler (the thing that looks like a pan extender) but work anyway. My stand has no crossmember.
Plaka is offline
Old 06-05-2013, 10:43 AM   #1253
richarddacat
high on honeysuckle
Oddometer: 3,499
Looks like your stand is different than mine. The cross member wirespokes is talking about is the one behind the tranny.
I think I can come up with something even though there is a trade off.
FYI - http://w6rec.com/duane/bmw/reynolds/
Sent from my iPod touch using Tapatalk
Mid-TN Tag Riders
Old 06-05-2013, 01:13 PM   #1254
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,944
Just a thought, try installing the spring with the coil end on top, the way the stock ones are mounted. This puts the coils oriented away from the engine, and may reduce the rubbing...
Big Bamboo is online now
Old 06-05-2013, 01:39 PM   #1255
loflyn71
Oddometer: 24
I'm selling one of my /5 airheads to purchase a R100GS. It's located in South Carolina if anyone is interested. Terry
. http://columbia.craigslist.org/mcy/3851534994.html
loflyn71 is offline
Old 06-05-2013, 02:42 PM   #1256
Plaka
Oddometer: 4,609
Thanks, but same difference. It's a strait line down the back of the thing.
Plaka is offline
Old 06-05-2013, 03:33 PM   #1257
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,944
Um, no... the hooks on the ends are 90 degrees different angles from spring. With coils at top = 180 degrees from case.
Old 06-05-2013, 04:58 PM   #1258
Plaka
Oddometer: 4,609
Sorry, I wasn't clear. If the coild face away from the case the back of the spring rubs. It's a strait line with the wire rubbing now. If the coils face the case it rubs a whole lot worse. All angles inbetween are variations on worse.
The coils don't rub, just the strait wire above them.
Plaka is offline
Old 06-05-2013, 05:21 PM   #1259
jjwithers
Oddometer: 111
Cool2 Rear /5 shocks with shouds
They aren't pretty anymore. But still work.
$40 + Shipping.
Located in Los Angeles, CA
jjwithers is offline
Old 06-05-2013, 05:55 PM   #1260
Kanticoy
Oddometer: 331
I could really use a set of Krauser tubular saddlebag mounts. As long as they aren't bent beyond belief i can use them. Rust doesn't matter as long as they're solid. I have a set of the cast mounts for partial trade as well. PM me if you have anything.
Sent from my DROID RAZR using Tapatalk 4 Beta
Kanticoy is offline
Closed Thread
Times are GMT -7.   It's 10:39 AM.
