Old 06-05-2014, 10:11 AM   #1
MotoMax OP
Caffine shakes anyone?
MotoMax's Avatar
Oddometer: 461
Light it up.
So I have questions on upgrading my headlight. What have some folks done? Right now when I have my regular lamp on, it is absolutely ridiculous. I ride around with my highbeam on to make it seem normal, and no one even flashes me. I love this bike and ready to go the distance. . .
Do I need to upgrade the charging system at the same time? I think I want to do that anyway. . . .
Is there a bulb change? or a entire assembly?
Thanks for whatever info that can be shared!! - Moto
"A shot of espresso is worth another 100 miles. . . . " - Moto
Airhead # 9189
MotoMax is online now   Reply With Quote
Old 06-05-2014, 10:18 AM   #2
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,056
Max, what bulb is in there now? There are some upgrades available, depending on what style bulb the socket is designed for.
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 06-05-2014, 10:31 AM   #3
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,201
Any clue what bike this is?
'73 R60/5 Toaster
Old 06-05-2014, 12:18 PM   #4
MotoMax OP
MotoMax's Avatar
Oddometer: 461
oops. . .
guess I forgot that part. It is my 1971 R75/5.
Airhead # 9189
Old 06-05-2014, 01:55 PM   #5
erimille
Oddometer: 62
The following article could probably use some love, but might be a useful place to start
- http://5united.org/articles/headlights/
hope this helps,
--e
erimille is offline   Reply With Quote
Old 06-05-2014, 02:46 PM   #6
Bill Harris
Oddometer: 8,201
Convert to H4 halogen, 55/65 watts. No easy "adapter", replace the lens-refector-bulb assy.
From Hucky, http://bmwhucky.com/007563.html , the econo kit and deee-lux kit:
07 63 R kit 012 headlight H4 conversion kit 12V / 5 $ 115.00
63 12 1 356 693 BMW - H4 kit / 5 $ 480.00
Easy as pie.
--Bill
'73 R60/5 Toaster
Old 06-05-2014, 03:00 PM   #7
JGT
Oddometer: 201
This is something I've wanted to do as well. Following a few links and doing some searches led me to this:
http://www.powersportsuperstore.com/...-p/4129343.htm
Seems like this should fit right into the /5 headlamp, as it is a P45T bulb (same base as original). Halogen should be brighter, and at 60/55W it gives more light but is not high enough to require rewiring, new relays, etc.
Snowbum (on this page: http://bmwmotorcycletech.info/lamps.htm) mentions an Osram bulb (the 64198) that supposedly is a straight replacement for the stock /5 bulb. Here is the manufacturer's spec page for it:
http://www.osram.com/osram_com/produ...tId=ZMP_102851
Looks like the same shape, etc. as the Eiko bulb on the first link listed here.
If this is right, then an upgrade can be had for less than $10.
Does this seem right or am I missing something?
JGT screwed with this post 06-05-2014 at 04:15 PM
JGT is online now   Reply With Quote
Old 06-05-2014, 05:17 PM   #8
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,618
The powersports.com bulb appears to have an H4 base which won't fit a /5 original headlamp. The Osram I couldn't tell from the linked information, but it did appear to be a different base--no mention of it being halogen that I could find.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 06-05-2014, 05:32 PM   #9
JGT
Oddometer: 201
I thought P45T was the designation for the base. At least from this article:
http://www.volvosolutions.com/Misc_P45T.html
I just found and ordered this one from Ebay:
http://www.ebay.com/itm/osram-64198-...-/221341575138
I'll do some testing when it arrives and post my results. Seemed worth the money to find out.
Old 06-05-2014, 06:56 PM   #10
Bill Harris
Oddometer: 8,201
Let us know what you find out.
The photo at the powersportsuperstore website shows a std H4 base:
Here is the bulb with the "P45" base:
More info when googling "p45t base".
I remember this coming up before but don't recall what happened...
--Bill
'73 R60/5 Toaster
Old 06-05-2014, 08:04 PM   #11
sammm
Oddometer: 22
I had a dim low beam issue recently, and it turned out that I had switched the ground and low beam terminals in the headlight connector when I reattached the headlight to the bike. It's simple enough to check, so you could always start there.
sammm is offline   Reply With Quote
Old 06-06-2014, 06:58 AM   #12
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 1,022
Just replacing the bulb with an H4 will give you more light but will be a problem for traffic coming towards you (unless your reflector has a deflector in it). Like what Samm said, check that your headlight bulb is wired properly and that it is in fact working properly. The /5 headlight bulb should light the road just fine (45/55 if I'm remembering right).
If you have an old headlight ring, you could try something we used to do in the 70s. A 7" halogen headlight unit (we used Bosch and Corello units back then) can be pushed into the back of the headlight ring (with some fiddling) but won't enter the opening for the lens. I used to trim out the lens hole until the 7" lens could enter then push the unit in to place (retaining with the lens clips as usual). I don't know about now but back then the headlight ring was made of chrome plated brass and wasn't all that hard to alter.
If you do go this route, the new headlight may have some metal tabs that will have to be broken or ground off on the back of the edge of the reflector or it won't go into the headlight bucket.
Just an aside, Cibie used to make a unit that went straight in, rim an all. The lens was concave. I haven't seen any of those for quite a few years.
Pokie is offline   Reply With Quote
Old 06-06-2014, 07:22 AM   #13
pkboxer
Oddometer: 95
Relay
Unless already upgraded, your bike doesn't have a headlight relay.
You can try adding one first (the matchbox one is easy/simple/good price).
If you pick up a volt or 2 it's a big step up in lumens.
You should add one anyway to take the load off your switch gear.
pkboxer is offline   Reply With Quote
Old 06-06-2014, 08:44 AM   #14
MotoMax OP
MotoMax's Avatar
Oddometer: 461
Thank you gents.
I traced the wiring and sure enough, it was not correct. 31 was in 56b. Swapped them out and it is much better. Sammm thanks man.
Thanks for the advice tho. I still think an upgrade in my charging system will be on the horizon - Max
Airhead # 9189
Old 06-06-2014, 08:46 AM   #15
MotoMax OP
MotoMax's Avatar
Oddometer: 461
Small missing bulb?
So when I pulled out the headlamp I am missing the little bulb at the bottom of the regular lamp. What does that one do?
Airhead # 9189
Times are GMT -7.   It's 01:46 PM.
