Old 07-22-2012, 03:58 AM   #106
Reklaw59
Softroader
Reklaw59's Avatar
Oddometer: 274
Originally Posted by ms-oz View Post
r ya working at FSH?
Yes. I assume that was your yellow GS parked up the other day.
Reklaw59 is offline   Reply With Quote
Old 07-23-2012, 02:27 AM   #107
ms-oz
Mike
ms-oz's Avatar
Oddometer: 69
yep she has heated grips and better tyres for the wet bitumen at 6am, as the weather gets better I'll take the HPN more often, I'm with a contractor for triple M.r u also going to FSH on a bike?
ms-oz is offline   Reply With Quote
Old 07-23-2012, 02:57 AM   #108
Reklaw59
Softroader
Reklaw59's Avatar
Oddometer: 274
When it warms up a bit .
I work on the facade, GIS/Yuanda, will try and catch up for a yak.
Old 07-23-2012, 06:57 PM   #109
pd pilot
Wannabe RTW
Oddometer: 33
Wink Re : Footpegs.......!
Hi Guy's,
love your bikes and can only dream. But in the mean time I will keep riding my R100GS/PD. I liked the look of those SWT footpegs and would like to know if they would fit my bike. If that is the case, would you be able to point me in the right direction to get my hands on a pair please.
pd pilot is offline   Reply With Quote
Old 07-23-2012, 07:05 PM   #110
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,543
Originally Posted by pd pilot View Post
I liked the look of those SWT footpegs...would you be able to point me in the right direction to get my hands on a pair please.
Dust off your deutsche:
www.swt-sports.de
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 07-24-2012, 05:03 AM   #111
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
www.swt-sports.de
linky no worky.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 07-24-2012, 06:20 AM   #112
Dakar83 OP
Dakar83's Avatar
Oddometer: 196
The link worked for me. Try this one http://www.swt-sports.de/sess/utn15500ea08062ace/shopdata/index.shopscript
Then look for part number 30143
Dakar83 screwed with this post 07-24-2012 at 06:44 AM
Dakar83 is offline   Reply With Quote
Old 07-24-2012, 06:57 AM   #113
Dakar83 OP
Dakar83's Avatar
Oddometer: 196
Any idea what make/model the magura clutch master/slave combo came off of? I looked into the available retrofit kits they sell a while back, but couldn't find one with enough pull length to work on an airhead.
Here is some info on that clutch
Old 07-24-2012, 07:07 AM   #114
Dakar83 OP
Dakar83's Avatar
Oddometer: 196
Here are some photos of the pannier frames that were made up by a local fabricator
The shape and tabs on the frames allow mounting of the aluminum panniers from my GSA. The cross bar provides additional support to allow the use of soft panniers as well.
Nice slim fit, they are made from stainless 19mm tube and mount at three points to the sub frame without mods to the bike. The low mount is made to press against the reinforced main frame
The HPM is off the road for the next 2 weeks while the forks are sent off for a rebuild including re springing and re valving.
Old 07-24-2012, 07:11 AM   #115
Dakar83 OP
Dakar83's Avatar
Oddometer: 196
Last for today are some pictures of the collector made up for the second, white HPM
It's looking good!
It should be on he road next week
Old 07-24-2012, 07:19 AM   #116
Airhead Wrangler
Adios Mexico
Oddometer: 6,543
HOT!! I'm gonna copy that. I like it. I was originally going to go for something like this below, but I like that solution better.
Old 07-24-2012, 08:37 AM   #117
Airhead Wrangler
Adios Mexico
Oddometer: 6,543
Any idea which model he used though? What bike is it actually intended for? Any idea of master/slave cylinder diameters and length of piston pull? Any possibility of having a custom length hose made or do they use weird Magura-only fittings?
Airhead Wrangler screwed with this post 07-24-2012 at 08:49 AM
Old 07-24-2012, 09:11 AM   #118
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 822
Mr. Wrangler,
FWIW I deal with Magura hydraulic brakes (bicycle) all the time.
Changing length/fittings is quite easy.
This should help:
http://www.powersports.magura.com/fi..._UK_screen.pdf
Late for work... I'll research today!!
Cheers,
S.
"Death in the pursuit of happiness is triumphant!"
rediRrakaD is online now   Reply With Quote
Old 07-24-2012, 03:31 PM   #119
Dakar83 OP
Dakar83's Avatar
Oddometer: 196
I believe part of the design intent is to keep length from header to muffler the same for both sides.
For the clutch i think the only mod was to make an extension for the actuator arm.
Old 07-24-2012, 03:49 PM   #120
Airhead Wrangler
Adios Mexico
Oddometer: 6,543
Next time you're there would you mind looking at the diameter markings on the master and slave cylinders? There are a few different sizes available for each, depending on the length of pull needed at the clutch actuating arm as well as the amount of mechanical advantage needed. Thanks for giving me new possibilities for squandering my income.
Times are GMT -7.   It's 08:39 PM.
