05-04-2012, 04:43 PM
#1 |
Oddometer: 35
Headlight question
While headed to my class today my headlight went out. When I returned home I did the usual checks, replaced bulb no change! Both beams are out. I checked fuses,they appear good.didn't see any loose or corroded wires in the headlight bucket. High beam will flash with the passing switch depressed. The tail light and turn signals work fine! It is a 1983 R 100 with CS package purchased new by me.there are no hacked wires or connections. I t also has the euro headlight on off switch. I am thinking relay. Thanks
05-04-2012, 06:49 PM
#2 |
Chronic Noob
Oddometer: 2,292
Swap the Hi-Lo wires over on the back of the bulb.
If the low beam comes on with the passing switch held down then the relays & circuts ar OK and it's likely the switch is worn(out)
If the Earth is flat why are my tyres round? |
05-04-2012, 09:48 PM
#3 |
Mad Scientist
Oddometer: 2,961
When you turn the ignition switch on does the headlight relay click?
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
05-05-2012, 06:08 AM
#4 |
Oddometer: 35
Upon suggestions received,I turned on the ignition switch and had a finger on the headlight relay where I felt and heard a faint click.I flipped the hi/lo switch and now both beams are working fine.I was going to change the wires for hi/lo to check the passing light function but this isn't needed now.I am thinking loose connection to relay as cause but hate an intermittent problem.Thanks for the great suggestions!
05-05-2012, 06:19 AM
#5 |
Oddometer: 973
Could be the switch, too.
Just curious: tail light? Turn signals? or just headlight out?
Pastor, Church of the Horizontally Opposed Air Cooled Twin '66 BMW R60/2, '83 BMW R100RS, '81 BMW R100RS "Das Beast", '77 Honda XL125 Airhead #371 |
05-05-2012, 12:04 PM
#6 |
Oddometer: 35
All other lights worked! Taillight,brakelight, turnsignals and parking light were fine. Last year I switched out the US headlight switch for a new euro on off switch so unlikely that the switch is worn out. It is working fine since I cleaned and applied dielectric grease to the wires that plug into the headlight relay.
05-05-2012, 12:48 PM
#7 |
the thread-killer
Oddometer: 4,297
Maybe it's just time for a new headlight relay. They aren't that much
05-06-2012, 06:22 AM
#8 |
Oddometer: 35
Yes, it is a nearly 30 year old relay that retails for around $20. I will pick up one Monday from our local airhead shop Motorrad Unlimited in Asheville.Thanks!
05-06-2012, 11:59 AM
#9 |
Oddometer: 973
Rick has 'em. Dunno how much, but I am sure cheaper than the closest BMW boutique.
