Go Back   ADVrider > Riding > Regional forums > Alaska
Old 05-04-2012, 08:33 PM   #1
Alaskajeff OP
Alaskajeff's Avatar
Oddometer: 1,239
D2D Gear question?
What does everyone carry for a tire inflator/ air pump? I am somewhat limited on space, and my ride is a kick start ONLY so NO battery to hook up to for a powered one. Are the little bicycle types up to the task? I'll need it for bringing my tires up to pavement pressure after the poker run and other dirt adventures.
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 05-04-2012, 10:13 PM   #2
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,330
well if you don't have electric power, you can get the little co2 infaltors and then just bleed off what you don't need. I have a mini compressor and going to look into the co2 inflators as the compressor takes about twenty minutes to get a tubed tire to min operating psi.
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is offline   Reply With Quote
Old 05-04-2012, 10:34 PM   #3
ThatGuy
Brownie
ThatGuy's Avatar
Oddometer: 5,350
^ what he said
Disclaimer: The writer does not represent any organization, employer, entity or other individual. The views expressed are those only of the writer. In the case of a sarcastic, facetious, nonsensical, stirring-the-pot, controversial or devil's advocate-type post, the views expressed may not even reflect those of the writer.
ThatGuy is offline   Reply With Quote
Old 05-04-2012, 10:44 PM   #4
subybaja
subybaja's Avatar
Oddometer: 2,891
Do some reading before buying Co2...I read of some guy taking 7-8 cartridges to air up a 17" rear. Expensive and takes up space.
Alaska Leather has some pretty neat little foot pumps for $20-30. THIS one.
We had part of a Slinky. But I straightened it.
subybaja is offline   Reply With Quote
Old 05-04-2012, 11:57 PM   #5
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,546
Suby, check yer PMs
Tom S is offline   Reply With Quote
Old 05-05-2012, 12:09 AM   #6
Full Power
Oddometer: 1,529
compact bicycle tire pumps are available, and inexpensive.
I keep one rubber banded inside left fender of KLR.
been there for a couple years, hasnt fallen off yet.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 05-05-2012, 02:21 AM   #7
ADVBMR
Polygamotorcyclist
ADVBMR's Avatar
Oddometer: 885
Just stand on the roadside for ten minutes. Help is always available on this stretch. If you want, I can loan you one for the day, someone will loan you some battery time.
IBA #47244
2007 R1200GS; 2006 DL650 V-Strom; 2011 F800R (sold); 2013 CRF250L (sold); 1995 R1100GS (sold); 2006 Ducati Multistrada 620 dark (sold); 2013 F800GS (woot!)
ADVBMR is offline   Reply With Quote
Old 05-05-2012, 11:10 AM   #8
Alaskajeff OP
Alaskajeff's Avatar
Oddometer: 1,239
I appreciate the offer Yeah, I'm sure there will be plenty of help on the roads too, just wanting to be prepared for whatever may come up.
Palmer, ALASKA
2011 Verys ADV
Old 05-06-2012, 07:08 PM   #9
AKmud
Muddy Gruver
AKmud's Avatar
Oddometer: 958
Jeff, if you are going to run with us, I have a 12v pump I carry.
AKmud is offline   Reply With Quote
Old 05-06-2012, 10:26 PM   #10
Alaskajeff OP
Alaskajeff's Avatar
Oddometer: 1,239
Sounds like a plan, thanks Mud. But I'd still like to pick up something I could use IF I'm not with the group at some time. I'll TRY to stay close by being a D2D rookie and all
Palmer, ALASKA
2011 Verys ADV
Old 05-07-2012, 05:08 PM   #11
Drunk_Uncle
Oddometer: 2,330
Are you riding out Tuesday or Wednesday? I am rolling out Tuesday and getting into Dawson wednesday afternoon. Looks like nothing really is going on Thursday so will probably do some riding around the area. I should my GPS somewhat figured out in the next two weeks to make some tracks for the area to follow.
Old 05-07-2012, 08:41 PM   #12
Alaskajeff OP
Alaskajeff's Avatar
Oddometer: 1,239
Our group is riding out Wednesday as far as I know.
If you are looking for a side trip in Dawson you might want to check out the Hoffman mining operation at quartz creek. I 've heard it's around 40 miles south of Dawson on some pretty choice roads
Palmer, ALASKA
2011 Verys ADV
Old 05-07-2012, 10:19 PM   #13
akrider
mild adventurer
Oddometer: 1,764
to air or not to air
I love this question. I have fumbled with it myself. I have come to two conclusions.
1) I don't know how much to lower the pressure.
2) I can't tell the difference when I do.
So it comes down to this for me......I'm too lazy to mess with it.
I would like to here some sound facts on the matter. I'll do whatever Jack says to do.
To someone with only a hammer - all problems appear to be nails.
Ignoranus-def: someone who is stupid and an asshole.
akrider is offline   Reply With Quote
Old 05-08-2012, 10:23 PM   #14
Beezer
Oddometer: 5,878
Kinda depends on which bike... for the KLR I carry an electric pump because it has tubes. On the dirt I drop to 18psi if it's a long run or it's sloppy. On the pave I run 30ish.
On my GS, I just leave the pressure alone. For repairs I carry a tubeless plug kit and CO2 carts around town & close in rides with friends, etc. If I go on the road for longer trips I take the pump and CO2, and a piece of rope or strap to make a Spanish windlass. It can be tough to seat a tubeless tire if it's off the rim. The pump doesn't make enough volume to do the job unless you are pretty good at forcing a seal to the wheel. The CO2 might be better, but you still need a pretty good initial seal. To get a seal, I put a loop of rope around the tread (running surface) of the tire, insert a stick and twist it tight until the beads touch the rim evenly, then air it up. Been meaning to try the ether/WD40 trick.... for those that don't know.... shoot ether into the tire & light it, it explodes & jumps right up on the rim. seen it on a video & seemed to work good.
Beezer is offline   Reply With Quote
Old 05-08-2012, 11:04 PM   #15
ThatGuy
Brownie
ThatGuy's Avatar
Oddometer: 5,350
Based on this I think I may just follow you!
Times are GMT -7.   It's 06:33 AM.
