Go Back   ADVrider > Riding > Regional forums > Alaska
Old 05-09-2012, 12:50 AM   #16
USBYGS
Riding the World
USBYGS's Avatar
Oddometer: 882
Originally Posted by ThatGuy View Post
Based on this I think I may just follow you!
Easier said than done...
Combat Touring Division
Two up Pterrorists
Take no prisoners - Leave no witnesses
USBYGS is offline   Reply With Quote
Old 05-09-2012, 08:35 AM   #17
ThatGuy
Brownie
ThatGuy's Avatar
Oddometer: 4,993
No kidding!
Disclaimer: The writer does not represent any organization, employer, entity or other individual. The views expressed are those only of the writer. In the case of a sarcastic, facetious, nonsensical, stirring-the-pot, controversial or devil's advocate-type post, the views expressed may not even reflect those of the writer.
ThatGuy is offline   Reply With Quote
Old 05-09-2012, 11:20 AM   #18
Beezer
Oddometer: 5,645
mark444.... ya heard of that trick. it might work but I doubt it is any better than CO2, if at all. you would still have to have a pretty snug fit to begin with because the front valve has to have the core in it, and thats a pretty small hole to push air through.
Beezer is offline   Reply With Quote
Old 05-09-2012, 12:08 PM   #19
KHuddy
Big Sky Country
KHuddy's Avatar
Oddometer: 2,795
Sounds like an excellent way to achieve tire equilibrium... meaning two flat tires.
Kevin
KHuddy is online now   Reply With Quote
Old 05-09-2012, 11:44 PM   #20
Wheeldog
Wheeldog's Avatar
Oddometer: 1,660
Originally Posted by Beezer View Post
Been meaning to try the ether/WD40 trick.... for those that don't know.... shoot ether into the tire & light it, it explodes & jumps right up on the rim. seen it on a video & seemed to work good.
I have done the ether (starting fluid) deal on my dump truck several times when I have had flats. Just give it a shot inside the tire and leave a trail coming out. Light the trail and it seats the bead.
It ain't the safest thing to do, but it does work. Always wondered what my insurance would do/say if I burned my truck up doing it???
Wheeldog is offline   Reply With Quote
Old 05-10-2012, 11:28 AM   #21
Beezer
Oddometer: 5,645
ya.... been thinking about that hose between tires thing. the reason I started using the rope trick is because I had a really hard time sealing up a tire once.... 40 gal tank with 150psi and still couldn't just blow it up.
Over the years I've watched tire mounts dozens of times in the shop where the guy throws a band around the tire & inflates the band to squeeze the beads up to where they will seal. I didn't have that & just used what was at hand. I'm sure I'm not the only one to think of this trick.
BTW, don't panic, the only time you might need it is if your tubeless tire is off the rim or the bead is broken.
Old 05-10-2012, 12:13 PM   #22
AKmud
Muddy Gruver
AKmud's Avatar
Oddometer: 944
A ratchet strap works well for that trick too. Done it many times on wheeler tires and truck tires.
AKmud is offline   Reply With Quote
Old 05-10-2012, 01:20 PM   #23
MMNORTH
Got GUZZI
MMNORTH's Avatar
Oddometer: 59
+1, Also I have used 2 large CO2 cartridges to get 20+ psi on a rear GS tire.
MMNORTH is offline   Reply With Quote
Old 05-10-2012, 05:19 PM   #24
Alaskajeff OP
Alaskajeff's Avatar
Oddometer: 1,136
All that discussion on tubeless tires kind of makes me glad I have tube type right now. I KNOW there are + - to both types though.
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 05-10-2012, 05:27 PM   #25
akrider
mild adventurer
Oddometer: 1,743
Stand Back
If your using the ether/starting fluid trick I would suggest standing back when you throw the match. Seems the wheel and tire sometimes get airborn as the fluid explodes. Did it alot with race car tires but always either used a chain to hold it down or put it under the lift in the shop. Not sure if a motorcycle tire would do the same as a car tire but then again its not my hand with the match or my chin leaning over the rim.
I'll bet Tom S has some good truck split rim stories.
Call me so I can come watch!
To someone with only a hammer - all problems appear to be nails.
Ignoranus-def: someone who is stupid and an asshole.
akrider is offline   Reply With Quote
Old 05-11-2012, 02:09 AM   #26
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,400
Originally Posted by akrider View Post
... I'll bet Tom S has some good truck split rim stories.
Dennis, you must have me confused with someone else. I know nothing about truck split rim wheels, and glad I don’t.
Tom S is offline   Reply With Quote
Old 05-13-2012, 09:12 PM   #27
Wheeldog
Wheeldog's Avatar
Oddometer: 1,660
I have used the ether/starting fluid quite a few times on truck tires. It doesn't take that much.The tires have always been mounted on the truck. Judging from how well it works on truck tires......I would say it may work "too well" on motorcycle tires.
I changed lots of split rims as a kid working on a farm. While I have heard lots of stories of guys getting their head ripped of when they let loose......I or none of the folks I worked with never had any problems. We bolted several pieces of logging chain around the tire/rim and placed it ring side down on the floor when we aired em up.
Forklift/Towmotor tires can be wild too. If you ever see anyone taking a fork lift tire off by removing ALL the nuts.......run.
Old 05-13-2012, 09:43 PM   #28
KHuddy
Big Sky Country
KHuddy's Avatar
Oddometer: 2,795
I worked in high school and college for a truck tire recapping and roadside assistance company. Saw hundreds of split rims inflated and only one came apart. It was a three piece rim and came apart in cage we used (sometimes); no one was hurt. It seemed everyone who worked in the shop knew a guy that saw a guy get hurt by a split rim, but no one ever saw it themselves.
Kevin
Old 05-15-2012, 01:46 AM   #29
marbee40
Some Fear is Good
marbee40's Avatar
Oddometer: 1,099
Had a cantankerous scraper tire in Guam that wouldn't come OFF the rim. Called EOD and they applied a little gem called det-cord! VIOLA....tire off of rim. Anyone carrying any det-cord around? You could just throw it inside the bead, pop the detonator, and hope for the best!
R1150GS
01 WR426F
marbee40 is offline   Reply With Quote
Old 05-17-2012, 11:33 AM   #30
AKTroy
BE AWARE OF TRAINS
AKTroy's Avatar
Oddometer: 2,225
Wicked
Man, there's a good one there and I can't quite ..................................
Team Pterodactyl, Hooligan Division. R.I.P Harry
Mythical Riders, boy are they movin'. Thru dust, rocks & mud..............they're FUKENGRUVEN!
As I look back through the decades, theres a thought that prevails. We are born without a road map and a choice of many trails...........
AKTroy is offline   Reply With Quote
Times are GMT -7.   It's 09:12 PM.
