Old 05-06-2012, 07:53 PM   #1
chipsdad OP
chipsdad's Avatar
Oddometer: 54
Question no spark on r75/5
I bought the bike with no battery a while ago and have been working on it since. I repaired all of the fried wiring as it should be. not only my motor is /6. my chassis is a /5. here are some vitals that you may ask in order to help me get spark.
-tested from coil post to ground 12v
-bike cranks over nicely
-no spark between points
- neutral light goes off and on properly
I am thinking it is something improperly wired but I dont know what to check. I have cleaned all visible terminations and greased connections.,
on a mission
chipsdad is offline   Reply With Quote
Old 05-07-2012, 01:04 AM   #2
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,232
So I'm thinking the wiring should also be /5? You say you have repaired wires already, did you use a wiring diagram or just replace one wire at a time?
You are getting 12 volts to the coil. Is the black wire, on the right coil, going back to the condenser?
It is often a perplexing problem to fix ignition when the short wire between the coils has a break.
Points are new? Did you also replace the condenser with a known or new part?
---Albert Einstein
disston is online now   Reply With Quote
Old 05-07-2012, 07:50 AM   #3
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,393
Try this
With the ignition on, spark plugs out but plugged into the plug wires and grounded to the head, touch the negative coil lead to ground. Let go. Do this quickly several times and you should see sparking at the plugs.
This will simulate the action of the points.
If there is sparking, it will tell you the points need attention. If not, there's something wrong with the coils.
Old 05-09-2012, 09:53 AM   #4
chipsdad OP
chipsdad's Avatar
Oddometer: 54
the negative coil lead?? that is the one that bridges the two coils or the other post. if it is the other post it will only fire the one plug correct?
on a mission
Old 05-09-2012, 03:13 PM   #5
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,232
The coil contact that has a black wire going to it. It's on the right side of the bike. The left side wire is hot when ignition is on. That wire is Blue/Green, I think.
Leave the short wire between the coils alone except to check it for continuity. It is amazing that this short wire can be broken inside the insulation or have badly fitting crimp terminals and be the source of many a mysterious ignition problem. Common problem actually.
---Albert Einstein
Old 03-05-2013, 04:45 PM   #6
chipsdad OP
chipsdad's Avatar
Oddometer: 54
My black post and both the cross over posts have 12 volts. Does this indicate a bad coil
on a mission
Old 03-09-2013, 02:45 AM   #7
Plaka
Oddometer: 2,593
What the hell is a black post??
Guy, I don't mean to be harshing on ya but if you don't know how to test a coil then you don't know how that system works. You're quite capable or you wouldn't have torn into the project. But hows about doing some homework? I don't see this as the place to spoonfeed someone Ignition 101. I'm sure not gonna, too many other people have written it out already---and you haven't read it.
Mottorad Electric sells a booklet for cheap that takes you through the thing. Snowbums site has everything you want to know (tho' he is long winded, convoluted and visually annoying---a different price to pay for the info)
The whole system has 5 components and some wire. Understanding what each does and how they work together is not difficult. Perhaps an hours worth of reading. It would take me two to write it out.
Once you understand how it works you will also understand how to test each part. From there you know what is and isn't bad.
if you come to some conclusions and want someone to check your work before you spend money, a forum can be valuable. If you get stuck it can also be valuable. You post up and say in detail what checks you have done and what the results are. You should have covered the bases. Then someone can advise you on some fine point you might have missed. But you probably won't need much if any help. It's really that straightforward a system.
When, not if, it takes a crap on the road, you will know what to do to get going again.
Or you could go the take-it-to-a-mechanic and always carry AAA route. Many if not most people do.
But if you are going to roll your own, RTFM, do like it says, then ask questions.
Cheers, and good luck with it.
Airhead stuff, tools, camping stuff, riding gear for sale/trade.
http://www.eskimo.com/~newowl/BMWPARTS.htm
Plaka is online now   Reply With Quote
Old 03-10-2013, 10:53 AM   #8
hwy61
hwy61's Avatar
Oddometer: 403
Gee Plaka, There are lots of places to look up what a black post is...
"Don't speak unless you can improve on the silence." Chinese proverb
hwy61 is offline   Reply With Quote
Old 03-10-2013, 01:08 PM   #9
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,232
You are going to have to have a wiring diagram. They are in all the manuals that we constantly tell new riders they have to have. There are some wiring diagrams on the Web but you need the correct one. It does not help when we ask pertinent questions and get no answer because you don't think it's important. If you don't know what you are doing you also don't know what is important.
Check out Snowbum's Web site. He has some of the wiring diagram's. His site can be not easy to navigate but the diagrams are there.
http://bmwmotorcycletech.info/
You have a /5 bike. I suspect you have /5 wiring irregardless of the /6 engine. Fortunately for the ignition the wiring is the same for /5 and /6 anyway.
Here are some basics. You must have a battery large enough to crank the engine and run the ignition. Too small a battery does not work in this situation where you are trying to find a problem.
When the key is on the left side coil has battery voltage, 12.5 volts minimum, at the positive post. The wire here may be a blue/green wire.
The left side coil negative terminal has a short wire to the right side coil positive terminal. This short wire can be taken off and checked for continuity. It's resistance is not important but it should be very low. Bend the wire to see if it stays contingent. i.e. It doesn't loose connection. Clean these terminals and replace short wire.
There should be a black wire attached to the right side negative terminal. Follow this wire to where it connects to the condenser. You can disconnect this wire at both ends and using a meter test to see it is the same wire from the right side coil to the condenser.
Finally the ignition points are also connected to the condenser.
If all of this wiring is in place and you get power to the left coil and the function of the points seems correct then it is time to spend some money.
Buy a new set of ignition points and a new condenser.
Instructions on installing and adjusting the ignition points are in the manual. You may need some further explanation but try to get the jest of the matter from the book. Maybe you have done this before? I mean ignition points? All cars and motorcycles used to have these. They started disappearing in cars in the mid '70's. They were gone from Airheads in 1981.
---Albert Einstein
Old 03-10-2013, 01:12 PM   #10
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,232
While you are at it measure the resistance of the plug wires. You need good plug wires and new spark plugs to get mystery bikes running.
---Albert Einstein
Old 03-10-2013, 01:25 PM   #11
Plaka
Oddometer: 2,593
Yeah, it's the one where you always get smoke leakage. See, all the components are packed with a certain amount of smoke from the factory. If any of it leaks out you're in big trouble...
Old 03-10-2013, 01:38 PM   #12
Plaka
Oddometer: 2,593
New points are good to have even if they are not a problem. But go to an outo parts store and get a BIG Mallory condensor. Things last forever (100k + Miles) and you never have to worry about or replace the condenser again.
Knowing how to work with the points is important to not frying them. So you want all that info before beginning. Slapping in some old fried points and filing them a bit is not a bad idea. You can still buy points files I imagine.
Old 03-10-2013, 01:47 PM   #13
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,232
Plaka,
Nice idea. Interjecting something like this is not helpful though. I suspect that Chips Dad is capable but not all that experienced. It would just be easier at this point to get it running don't you think?
He has a VOM so I don't think he's hopeless.
We often run into this problem of trying to help riders and we don't know how much experience this rider has. May be his second car is a 1951 Ford P/U. Maybe he knows a thing or two? Maybe the problem is that he's an Engineer? How often do we see NASA scientist types that can't get their Airhead running?
So give the guy a break if you can. I know you're having a ruff day and want to take it out on some noobies but they do mean well, until proven other wise.
Your Friend,
Charlie
---Albert Einstein
Old 03-10-2013, 04:18 PM   #14
Plaka
Oddometer: 2,593
Plaka,
Your Friend,
Charlie
I gave my answer more than a second thought...and I was having a decent day with some projects turning out well. i vacillated between not saying anything and giving the answer I did. I chose to answer because that is helping. Spoonfeeding the guy might look more helpful, but it the end you foster dependance rather than independence. I noticed the guy had a meter. Definitely a good candidate. But some attitude adjustment required.
Working on electrics requires one to be in "Brain On" mode. I don't get the impression, based on his question, that our OP is there. I could write out so long bit on how it all works...but he hasn't bothered to read any of the treatises already out there. Why should he read mine? Just 'cause I wrote it out just for him all special like? if you read what's out there and don't get something, then ask. Show a willingness to educate yourself, help yourself and solve your own problems. Ignorance is fine, failing to exert yourself (beyond asking an ignorant question in a forum) is not fine. I chose to point this out.
I see these interminable threads centered round just this. The op gets barraged with questions and answers containing a mish mash of information, misinformation, truths and half truths---and none of it is hanging together on an armature of a a basic understanding of the system.
An example below:
"Bend the wire to see if it stays contingent" Um, no. See if it stays continuous.
"Follow this wire to where it connects to the condenser." Not unless you plan on cutting the loom open.
"You can disconnect this wire at both ends and using a meter test to see it is the same wire from the right side coil to the condenser. " Maybe, maybe not. The matter of shorts is ignored. You can get continuity in a shorted wire. You still get a bad circuit. indeed, if it's shorted it continuous to every ground wire on the bike. And of course if it's shorted the coils will never make spark.
If you are thinking about the system as a whole then all this stuff is clear without asking.
Last but not least, when you do your homework you take a seat at the table as an equal. You don't need to know it all or be the most experienced. You do need to pay some dues and show some self reliance. It's a 40 year old machine, well documented with a loose fraternity of owners who are enamored of the things. How you wear your hat kinda matters.
Speaking of hats; to put on my psychologists hat for a moment...dealing with a problem that requires analytic thought AND dealing with analyzing a system you know little about is anxiety provoking, to say the least. Depending on personality, on way to reduce this anxiety is to retreat to a position of helplessness. (formally: a regressive defense). This of course gets you nowhere but you do feel better. Applying a 2x4 upside the head, or a boot in the butt, can provide a second anxiety provoking force...looking badly in front of peers. Now you don't feel better anymore. The defense itself is attacked provoking some other response. Some other defense can be invoked (when someone responds with rage, irrational hostility, etc, you're seeing it) or a more positive response that reduces the primary anxiety can be forthcoming. like reducing the ignorance about the system and thinking carefully about what is going on. The boot in the butt routine is a gamble, it can go either way. But if it goes right the recipient will gain confidence with each success. it ends up with someone you feel good helping rather than feeling used for helping them. This preserves your own head (integrity) and you can stay with a position of offering more, and more frequently.
Personally I stay off the airheads list. I don't like too many of those people nor do I care for the so-called airheads ideal. They aren't simple by choice...they don't have a choice. But it can be a good resource, especially if you like being helpless.
Plaka screwed with this post 03-10-2013 at 04:47 PM
Old 03-11-2013, 08:23 AM   #15
chipsdad OP
chipsdad's Avatar
Oddometer: 54
sorry, i didn't grow up with several machines in the front yard on blocks to sharpen my mechanical skills. i am not ashamed to ask questions that may seem a little easy for you to answer. I do have an in depth electrical understanding as I work in telecom. Granted there are different electrical characteristics that i pay attention to then what we see in automotive wiring. If you feel that it is below your credentials to answer a question that is too simple for you to answer don't answer. i find it puzzling that you spent as much time as you did forming your reply. I thank you once again Disston for your informative reply. I was refering to the black post as the post that returns to the condenser. I believe that where i am i need to look at the plug wires and the condenser. i checked the points with a test light and they appear to be working correct.
on a mission
Times are GMT -7.   It's 05:05 AM.
