Old 05-07-2012, 10:29 PM   #1
WhereTheHellIsJames? OP
WhereTheHellIsJames?'s Avatar
Oddometer: 47
WhatTheHellIsWrong with WhereTheHelliIsJames' bike?
Iím at a loss. I canít seem to figure out what is going on with this bike, and itís driving me nuts. It all started towards the end of March on the n00bs ride in Death Valley. Many people there heard about Ďthe broken KTMí, but so far, nobody has been able to present the solution.
Details of the bike: 2006 KTM 950 Adventure. Canisterectomy, flappendectomy, SAS removed, ran fine, then just started not running fine- no major event, no revving, no nothing. Out of nowhere, while maintaining a steady RPM on the highway, it just started running crappy on the front cylinder.
Hereís the dealÖ
Riding along the highway between Panamint Springs and Furnace Creek, something happened. No clunk, no thud, no whap, no nothingÖ it just started not wanting to run right below 6k RPM. When we pulled into the fuel station at Furnace Creek, the clutch was pulled in to coast up to the pump, and the engine died. Weird, but whatever- thinkgs like that happen sometimes. When we go to ht the trail, the bike is hard to start, wont idle, and is popping a bit. I figure that maybe itís flooded, or thereís a piece of debris in the carb thatíll work its way out in a couple of miles, so we head up the road. Things donít get any better after a few miles, so the decision is made to stop, figure out whatís going on, and try to fix it.
Turns out that itís the front cylinder thatís popping, and itís acting like the jet is clogged. Off come the crash-bars, fuel tanks, glovebox, airbox, and carbs, and I opened them up for a quick service right there in the middle of the desert. Nothing- those jets are clean as a whistle. Thinking that maybe whatever was stuck in the jet had fallen out when I drained the float bowl, it all went back together. Turn the key, fire it up, and pop, hmm hmm pop pop hmm pop. Still the problem persists. At this point Iíd been holding up my friends for an hour in the middle of the day while we tried to fix the bike. I knew that my ride was over, so I sent them on their way and headed back to Panamint Springs on the bike.
On the highway, it rode like one might expect- not as good as it does when all is running perfectly J It did keet a normal temperature though, and didnít seem to be struggling terribly. When I got back to camp, a thorough cleaning was in order. I spent the rest of the day pulling it apart, going through that front carb extra carefully, then put it all back together. Turn the key, and Ö hmmm pop hmm hmm pop pop hmm pop. WTF?! I sought outside help, and Lior stepped up to the plate and offered assistance. We worked on that bike until around midnight, and never did out whet the heck was wrong with it. Some other forum members offered up some spares, so we replaced the plugs on the spot, swapped coil packs front to back, as well as bypassed the fuel pump and used brand new super out of Liors tank. A valant effort on the part of the community, yet the problem persisted, and the front cylinder continued to pop and backfire. We were out of ideas, and it was late.
The next day, a VERY COOL forum member set me up with a loaner bike for the day, and I got to go ride. It was my first trip to DV, and I was super stoked to be a part of a community so caring, that they offer up a spare bike when mine was beyond field repair. Another VERY COOL forum member drove me and the KTM all the way back to San Francisco when the trip was over. To all that contributed- you know who you are and what you did for me, and Iím so grateful. Thank you.
Continuing onÖ the bike is back home, and Iíve had it apart now more times than I care to admit, and itís still misfiring on the front cylinder. Seriously, WTF. Iím at a total loss here. The carb is probably cleaner than it came from KTM, the valves are in spec, the cams are where they should be, fuel is getting to the carbs, new boots (not that there was anything wrong with the old ones) but still, that front cylinder keeps on backfiring!
It seems to be a lean conditionÖ
When the bike is running, and you look down the carbs, the slide on the rear carb is going crazy like it should, but the front is hardly moving. It pops humms pops pops humms, etc. When I put my hand over the front carb, the popping stops (this is why I say a lean condition).
Hereís what Iíve done:
* Cleaned that front carb like I never have beforeÖ like 5 times. Carb cleaner, compressed air, banjo string, the works. Lior cleaned it twice too.
* Checked and confirmed that the valves and cams are in spec. They were. I thought that maybe the cam chain had somehow skipped a tooth, but it didnít.
*Replaced spark plugs, and swapped coil packs front to back to see if the problem switched cylinders. It didnít.
* Replaced intake boots.
* Drained old fuel completely, and put some fresh non-ethanol stuff that I bought while in Oregon last week in it.
* Checked all the fuses, and moved them around / swapped positions.
* Cleaned fuel lines from the connection halfway down the left side all the way up through the T and to the carbs.
* Thoroughly checked/cleaned (not that it needed it) the bellow that the needle attaches to.
* Removed the SAS system and installed block-off plates / plugs.
* Confirmed that there is no air leak where the canisterectomy bolts were installed.
* Replaced the vacuum lines (for carb-synching) on the right side of the manifolds.
* Ran the bike without the airbox on it, placed my hand over the front carb, and sprayed carb cleaner and starting fluid around the boots and intakes to confirm that there were no air leaks there.
* Confirmed that the valves seating by turning the engine to TDC, and spraying carb cleaner in the manifold. It pooled and sat on the valves overnight, with no change in fluid level. (yes, I sucked it all
out before turning the engine over again)
* Slaughtered a chicken and lit some candles.
* Finally, after a month of trying to fix this on my own, I wrote this long-winded post.
So thatís where Iím atÖ out of ideas. If your suggestion turns out to be the fix to the mysterious front cylinder backfire problem (and no, taking it to a shop doesnít count), Iíll send you a set of Pie-Hole makers. Also, if you have a spare front carb, and youíre 100% certain that it is 100% good, and youíre willing to loan it to me for a quick test to confirm that I'm not completely inept at cleaning the carb that's on this bike, Iíll gladly pay the shipping costs both ways, and do something cool for you.
Some very bright KTM folks are stumped on this one. If you figure it out, youíre a hero.
WhereTheHellIsJames? is offline   Reply With Quote
Old 05-07-2012, 10:40 PM   #2
nesloyrag
Oddometer: 65
I had that happen to me once, double check to make sure the front carb is seated in the rubber boot to head, its a son of a gun to get it seated, I use a long bar and pry it down to snap it in place. If it isn't seated completely it will run way too lean, something to check for anyway
Hereís the dealÖ
nesloyrag is offline   Reply With Quote
Old 05-07-2012, 10:48 PM   #3
mousitsas
mousitsas's Avatar
Oddometer: 2,909
Have you tried to swap the diaphragms between the carbs? It has been noticed that some times they might get hard with age and reluctunt to move properly. Do your slides rise in tune with each other?
Also, a long shot as I don't remember if it is possible, but can you reverse the carbs for a static test?
Alternatively, find a friend with time and appetite and swap carbs.
How about the hall effect sensor that signals the front spark?
mousitsas screwed with this post 05-07-2012 at 10:56 PM
Old 05-08-2012, 01:22 AM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,011
Maybe you nailed it
When the bike is running, and you look down the carbs, the slide on the rear carb is going crazy like it should, but the front is hardly moving. It pops humms pops pops humms, etc. .
Seems like there is something here!
Cheers.
Old 05-08-2012, 03:56 AM   #5
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,999
Double check all vacuum caps. You mention two lines, but there are four vacuum ports on the manifolds. If you use an air flow meter to check carb sync, you can remove all lines and seal the four ports. It removes one possible source of problems. Also, carbs way out of sync will do just what you describe. I don't know why they would jump out of sync, but when my bike goes a little out of sync, it pops just like that.
Orangecicle is offline   Reply With Quote
Old 05-08-2012, 05:57 AM   #6
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 442
Intake valves on front cylinder may be out. Mate had the same symptoms on 03 950 and it was tight intake clearances and carb sync.
Lc8grrr is offline   Reply With Quote
Old 05-08-2012, 07:58 AM   #7
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Well, hell, I've got nuthin for ya, but this:
takes me back to so many fun places from my racing days..
That I had to say thanks!
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 05-08-2012, 08:07 AM   #8
mdfehrmann
mdfehrmann's Avatar
Oddometer: 338
+1 This would be my next step. Check for pin holes or tears as well.
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S - 2004 Sherco 2.9
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Old 05-08-2012, 08:29 AM   #9
Oddometer: 47
Thanks for the ideas, folks!
Peeps who mentioned the diaphragms:
* I cleaned and inspected that diaphragm a couple of times while the carbs were apart, and it was good and plyable (as opposed to tough and brittle).
* I didn't try swapping the two (since it really appears to be just fine), but I will give it a shot either today or tomorrow.
Peeps who mentioned other stuff:
* The intake valves are in spec, not tight, not loose.
* There are 2 remaining vacuum ports on the manifolds, as 2 were permanently sealed. for the two that remain, I installed new hoses, clamps, and caps.
* The front carb is definitely seated correctly.
* The front spark is strong.
Regarding swapping the carbs for a static test:
* I didn't do this since the carbs are asymmetrical.
However, I wonder if I could disconnect all the cables, remove the airbox, and pop them on the manifolds backwards for a hand-operated static test. I could definitely leave the TPS connected, and I think there might be enough slack in the choke cable to connect that too... if I unlaced in from the frame and kept the bars turned to the left... this might just work.
I'll report back later today or tomorrow with my findings after swapping the diaphragms (if they're swappable), as well as to report the results of the static carb swap... if in fact it can be done.
WhereTheHellIsJames? screwed with this post 05-08-2012 at 08:42 AM
Old 05-08-2012, 01:24 PM   #10
Orangecicle
On a "Quest"
Oddometer: 2,999
Seems off point, but could your fuel pump be dying?
Old 05-08-2012, 02:41 PM   #11
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
That maybe wouldn't explain the popping, but could definitely explain some of the other things. It will cause some weird stuff to happen on its way out and will work most of the time, but quit unexpectedly at others.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 05-08-2012, 05:33 PM   #12
Oddometer: 47
The fuel line goes from the pump to a T connection, where it splits to each carb. If the pump was going out, then the problem should exist in both cylinders, and not just the front. The pump seems to have good pressure, and equal amounts of fuel look to be going through the carbs into each cylinder.
FWIW, I tried bypassing the fuel pump, and fed gas through an IV canister to the carbs, both when it happened out in DV, and once since. The rear cylinder ran fine, and the front didn't.
Old 05-08-2012, 10:26 PM   #13
GZERO
Fixing stuff around
GZERO's Avatar
Oddometer: 265
ok, my $.02 and i hope i get something right just so you can enjoy your bike.
First, sounds like your front cylinder is not moving air properly (because you mentioned the diaphragm) check your whole exhaust, maybe you have a clogged cat for the front cylinder, also check for dents on the exhaust, all the way.
Second, try spraying starting fluid or carb cleaner on the front carb with the engine on, see if it makes a difference. (please be very carefull with this, don't burn yourself)
Third, have you check the pick up coil? you mentioned you had spark, and that makes me think it doesn't has anything to do with it, but check it none-the-less.
Fourth, have you checked your choke cables? if they get stuck open for some reason it will make your symptoms.
Remember something, you need 3 things for combustion, spark, fuel and air.
i have blackberry messenger and whatsapp, i can give you that info so we can chat and talk about possible faults, I'm a mechanic.
GZERO screwed with this post 05-08-2012 at 10:35 PM Reason: spel
GZERO is offline   Reply With Quote
Old 05-09-2012, 05:10 PM   #14
Oddometer: 47
Today I did all the things that were suggested...
I swapped the carbs front to back, and guess what... it didn't make a difference. The front cylinder still sputtered and popped and backfired, etc. The good news, is that this tells me that I'm capable of cleaning a carb out just fine, and that I'm not crazy thinking that it's spotless and perfectly operational. Just for kicks, I swapped the coil packs and intake boots at the same time, and nothing had any effect on the condition.
Knowing that its not the carbs, I put the bike back together, then started at the other end. As suggested, I checked the pipes for dents/kinks/cracks all the way down, and (as I already knew) there were none. I removed both cats/silencers, and fired the bike up. Good thing that I had my Remmington headphones that I use for trap shooting on, because man that sucker was loud running on open headers!! (my neighbors must love me)
The good news, is that I can also eliminate the cat/can's from being the problem here, since the backfiring and poor running condition remains the same with or without them. Just for kicks, I swapped sides when I put them back on. The bad news of course, is that if the problem isn't being caused by anything on either end, then it's somewhere in the middle... which is always more difficult. At least it's getting chased down a bit.
FWIW, after the engine warmed, I checked the oil again, just because, and it was perfectly full to spec.
So... if it's not the carbs, not the cans, not the manifold boots, not the coil packs, the valves are within spec, and the cams are where they should be, what's next?
Old 05-09-2012, 05:58 PM   #15
GZERO
Fixing stuff around
GZERO's Avatar
Oddometer: 265
Next would be compression and leak down test, because if it has spark, fuel is fine and air is fine then the problem is "the pump" meaning rings or something like that.
How many miles does this engine has?
Times are GMT -7.   It's 03:51 AM.
