Old 05-08-2012, 07:56 PM   #1
JNS-WRX OP
Oddometer: 28
WR250R & X Rotopax and Givi compatible Billet Racks
Hello, I have for sale two different options for WR250R and X owners. A smaller rack predrilled to accept a Rotopax mount, that is designed to be non obtrusive when not in use yet fully funtional.
Also a bigger rack that is compatible with Givi's monokey system, which is also Rotopax compatible in the same respect as the former. It is about 2.313" wider than the smaller rack but same in length and thickness(.500").
Both are available in either bare aluminum, anodized clear, black, or blue.
This is the smaller rack.
The Bigger.(Bare finish, with Givi mounting lug kit - not included)
Both these racks can be found on eBay and there are separate listings for the small anodized and small bare racks.
If you are interested in a Big Rack without anodizing contact me directly through the forum or via eBay message.
Of course more pictures can be seen on the current 3 listings for these.
JNS-WRX is offline   Reply With Quote
Old 06-05-2012, 09:40 AM   #2
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,432
More ...
You can see a bunch of additional pictures ... in his thread on the WR Forum ..
http://wr250rforum.forumotion.com/t6...rack-available
Also ...
I had Jared make a custom plate for me (for a different application)... turned out GREAT ! :cheers:
Thanks - Jared ... :
Honda
GsVs is online now   Reply With Quote
Old 06-07-2012, 12:49 PM   #3
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
great details in that rack!!!
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 06-13-2012, 05:11 PM   #4
rpet
Awesometown
rpet's Avatar
Oddometer: 820
what is the weight on the smaller rack? thanks
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 06-14-2012, 07:25 AM   #5
JNS-WRX OP
Oddometer: 28
The small rack weighs about 1.5 lb, the Big Rack weighs a little over 2 lbs. The bolts and mounting spacers add almost 1 lb to the total weight.
Old 06-14-2012, 07:50 AM   #6
therockmantex
Geezer
Oddometer: 89
Billet racks
Jared, have you had any problem with the Givi box not fitting? I bought your big rack (love it) and the mounting kit from Altrider and find that my Trekker topbox won't fit. It seems like the rear latch needs to be about 1/8 to 3/16 further back. I saw on the WR forum that you had put the same Trekker box on your bike, so did you have to make any adjustments?
Steve
therockmantex is offline   Reply With Quote
Old 06-15-2012, 07:47 AM   #7
JNS-WRX OP
Oddometer: 28
I noticed this as well Steve, Its not that the location are incorrect but it seems to be extra tight fit on the front lugs. I have to give mine a good push to get the case to slide on far enough. It didn't bother me enough to mess with it a lot. But I did try putting the thin washers that came with the kit and putting them between the lugs and the rack. That fixed the clearance problem and makes the case snap on easily. I think that alt-riders front lugs are probably out of tolerance in there machining. I had used a lug kit that belongs to a friend that came from Happy-trail.com and it was not an issue.
I hope this helps and let me know if there is anything I can do to get you fixed up.
Old 06-15-2012, 07:09 PM   #8
therockmantex
Geezer
Oddometer: 89
Billett racks
Jared, do you know where I can get a couple of lugs without having to order the whole kit?
Steve
Old 06-15-2012, 07:43 PM   #9
JNS-WRX OP
Oddometer: 28
No, I don't know of anywhere that you can buy them apart from the catch block. Although I must admit I have thought about making my own hardware since I noticed even the holes in the block are tapped crooked. The best advice I can give you is using a washer under the front posts. A smaller one than what they supply would be ideal, even a small O-ring may work well for the task. I could try putting an o ring under mine and let you know what size fits best.
Old 06-18-2012, 09:34 AM   #10
JNS-WRX OP
Oddometer: 28
Hey Steve, I got around to fiddling around with my setup yesterday and found that placing a #009 size o-ring between the rack and the front studs works well, aiding to the smooth attachment and detachment of the trekker case. I squished the O-ring down to about half of its thickness and that worked out about right.
Old 11-08-2012, 04:47 PM   #11
jgormley
jgormley's Avatar
Oddometer: 812
Just an fyi...
I just put the Givi B33 monokey on the rack using Happy Trail's mounting hardware.
It is a tight snug fit, but it all works together.
I ordered the mounting hardware over the phone so I got a break on the shipping and order only 1 set of mounting hardware. Their kit online is for side racks so there is two sets of mounting hardware...
jgormley is offline   Reply With Quote
Old 07-02-2014, 08:36 AM   #12
Chivvalry
Chivvalry's Avatar
Oddometer: 549
I'm bumping this zombie thread just because I just found it and I am in awe of the beauty of this guy's Givi and Rotopax compatible WR250R/X cargo rack...
I almost bought a Pro Moto rack before I saw this.
http://www.scaggsmotodesigns.com/wr250r---x.html
You are not paranoid if They are actually out to get you, however, They probably are not and you probably are.
USAF - '86-'99
2008 FJR1300
2011 WR250R
Chivvalry is offline   Reply With Quote
Times are GMT -7.   It's 06:06 PM.
