10-27-2012, 06:28 AM
#46 | |
Scope Creep's Victim
Oddometer: 2,214
Let's face it, you'd need serious frame mods and reinforcing for it to be a big dirt bike ... but keeping it this way it will become a really comfortable trail / forest service road / ADV bike ... And if you want to make a scrambler ... you can find one less mod'ed in order to make the transformation. And besides ... this one looks SO GOOD ![]() Lovin the rebuild.
Fred '85 R80RT G/Sified '91 R100GS Bumblebee Airhead Zen: Ride-Maintain-Repair-Ride On. |
10-27-2012, 08:54 AM
#47 |
Semi-Occasional
Oddometer: 1,534
Well, it will be functionally that bike, but altered a little to fit my needs. eg, it's not set up to carry gear for a trip. I need to fix that. The geometry is not right for long road miles, and I need to fix that, too.
What I'm NOT doing is chasing a style...I'm chasing functionality first. But I am using the aluminum fenders. That's my main vanity feature -- I just like that look and I think it's right for an old boxer. I picked up some tubing yesterday and will start working on a new subframe -- I'm building the correct rear rack and side bag standoffs right into the subframe so it's all one piece. I'm sending off the wheel hubs and a few other bits to be blasted clean so I can get the new wheels built up while I work out the subframe, seat mount and tank mount. I really want this thing on the road by spring. Going to be a big snow year and I want to go see the Yosemite waterfalls.
'74/'70 R98/6/GS Traveling Bike (construction under way) '91 Bill Holland Steel w/Dura Ace |
10-27-2012, 02:07 PM
#48 |
Semi-Occasional
Oddometer: 1,534
More mockup to make sure the plan will work.
10-28-2012, 07:55 AM
#49 |
Screwed the Pooch
Oddometer: 496
Nice. Like the overall look.
If your gonna be dumb, you gotta be tough When you get knocked down you gotta get back up, I ain't the sharpest knife in the drawer but I know enough, to know, If your gonna be dumb, you gotta be tough |
10-28-2012, 08:02 AM
#50 | |
Screwed the Pooch
Oddometer: 496
It's got to work everywhere that I want it to--any surface, commute, tour, etc. Make it your own, man.
10-28-2012, 08:17 AM
#51 |
Oddometer: 2,869
your bike is my muse
2002 DRZ250 what it lacks in horse power it makes up for with traction for sale ![]() 2000 DRZ400e tagged ![]() 1980 TS125 project in the corner 200? zuma 50/70 the wifes bike
10-28-2012, 01:25 PM
#52 |
Oddometer: 391
lookin great!
the seat reminded me of this recent build from CRD. http://www.crdmotorcycles.com/motos/...-the-challenge |
10-29-2012, 11:44 AM
#53 |
upside down parker
Oddometer: 3,238
have you checked to make sure you have clearance between the front engine cover and the front wheel at full compression of the suspension? sliding the forks up that far might cause interference. it's hard to tell from the picture.
10-29-2012, 11:59 AM
#54 |
Semi-Occasional
Oddometer: 1,534
Yup...plenty of clearance. Room for the fender, too.
11-03-2012, 08:22 PM
#55 |
Semi-Occasional
Oddometer: 1,534
Starting on the subframe/rack. I got the wrong tubing for the main subframe (3/4", but too thin-walled) so I started on the top rack. Got it flat and square on the first try! 12" square...will have three crossbars. Wide enough to mount my Pelican case hardware bits, or a big Motofizz bag. Side standoffs next...
11-04-2012, 09:36 PM
#56 |
Oddometer: 7
Awesome project..i have a R75/6 in the shed.. Also planned to go dirt with her.
Following in awe!
11-05-2012, 08:53 PM
#57 |
Semi-Occasional
Oddometer: 1,534
I got a heavier gauge of 3/4 tubing for the top rail of the subframe. The existing subframe was relatively light gauge since the bike was probably not used for fully loaded touring. I want to be able to have a single strut (on each side) holding up the subframe, with the top rail cantilevered out past the seat and strong enough to hold ~70-80 pounds of gear on rough roads. So I cut off the old subframe, preserving the nice mounts for the shock, and welded in my heavier gauge tubing. I notched the bottom of the tubing on both sides of the butt joint and inserted a piece of 1/2" tubing that was notched and bent till it spring-fit. Welded over that notch on my highest voltage, and then welded the butt joint. This should now be overbuilt by an order of magnitude.
![]() ![]() Next up is to finalize the angle of these rails and bend the part that extends past the seat so they are level to the ground. Then make the support rail that bolts to the old footpeg bracket. All the rest of the tubing can be lighter gauge.
11-05-2012, 10:47 PM
#58 |
made for adventure
Oddometer: 49
Love the look of the trials tire, looks so period correct! Makes me want to rip into the G/S!
11-06-2012, 07:08 AM
#59 |
Semi-Occasional
Oddometer: 1,534
BTW -- I weighed the pieces of tubing. The difference between making the subframe "as strong as all the other ones" and "overbuilt crazy strong" is only 1.7 lbs. Small price to pay for peace of mind.
11-06-2012, 09:39 AM
#60 |
Oddometer: 2,869
its coming along nicely
