Old 11-07-2012, 11:01 PM   #61
limeymike
Who Me?
Oddometer: 627
Sorry, late to the build party, nice job indeed.
More pls...
limeymike is offline   Reply With Quote
Old 11-13-2012, 09:19 PM   #62
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
This came in today's mail. Should work great for relocating the battery up under the seat pan. I'm making a little tray for the battery and other electronics. This brand of Li battery has the charger/balancer electronics built into the case. No futzing around with special chargers and balancers...
1974 R90/6 w/1050 kit. Motor only. Seeking a frame.
1970 R60/5
'91 Bill Holland Steel w/Dura Ace
'01 Z3 3.0 Coupe. The Clownshoe.
DiabloADV is offline   Reply With Quote
Old 11-14-2012, 11:10 AM   #63
Beater
Airheaded, eg Simple
Beater's Avatar
Oddometer: 3,247
2.1 pounds?! Wow. You must tell us how it works ...
Fred
'85 R80RT G/Sified <|> '73 R75/5 LWB
Simply Simple and getting more so.
Beater is offline   Reply With Quote
Old 11-14-2012, 11:47 AM   #64
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
Two-year warranty, and the re-seller is an inmate here -- herrhelmet, over in vendors. Reports so far are all good. Placing the electronics right in the box is a brilliant move and, IMO, takes away a lot of the failure outcomes of these batteries.
The main downside is that this battery is pretty much for starting and running the bike. You don't want to, say, charge your GPS overnight or inflate a big camping mat without the bike running.
1970 R60/5
Old 11-17-2012, 04:57 PM   #65
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
Choices...The bottom pic is the way the bike is now, with upturned mufflers. But, I'm thinking they might look better flat, matching the line of the rear rack. They work better flatter, insofar as turn signals, etc. need to be set up. What thinks this band of experts...?
Or
1970 R60/5
Old 11-17-2012, 05:00 PM   #66
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
I could see the flat option with them about 4" lower...just below the top of the tire...would really show off the fender and still be well out of the way of rocks.
1970 R60/5
Old 11-17-2012, 05:15 PM   #67
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
A little lower...
1970 R60/5
Old 11-17-2012, 08:30 PM   #68
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,241
Definitely prefer the turned up option.. , but are you going to take luggage? If so you need to think about how that will work. The turned up look shouts dirt bike. The lower says I'm just another old road bike
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 11-17-2012 at 09:58 PM
Box'a'bits is online now   Reply With Quote
Old 11-17-2012, 09:41 PM   #69
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
I'll be making oval side racks, to fit Wolfman bags. The mufflers can work either way, since the racks will be outside them.
I need to keep staring at it. Right now, I like them upturned.
1970 R60/5
Old 11-17-2012, 11:11 PM   #70
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,241
I've got low on my GS and hate it. Buggers up ground clearance. Your lowest point isn't the sump. It's just in front of the rear wheel..
Old 11-19-2012, 09:22 AM   #71
Chico
Thief and Saboteur
Chico's Avatar
Oddometer: 736
Just for Looks
From a purely aesthetic perspective, upturned is better. And if you can run it with only 1 can, I think it makes the bike tidier overall and is more consistent with the 70s (I think).
Chico is offline   Reply With Quote
Old 11-19-2012, 01:01 PM   #72
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
Will this bike run good with one 1-1/2" muffler or would I need to go to 2" (after the 2-into-1 merge pipe)?
1970 R60/5
Old 11-19-2012, 01:37 PM   #73
tdrrally
tdrrally's Avatar
Oddometer: 3,333
i favor the dual hi my self
but its your bike , so go with what makes you happy
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 11-19-2012, 01:46 PM   #74
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,782
Either position looks good to me, not much help I know
A single 1 1/2 muffler will flow fine for up to around 150hp, so you should be OK for now
Old 11-19-2012, 11:55 PM   #75
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,545
Angled looks better to me.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Times are GMT -7.   It's 08:58 PM.
