Old 06-14-2012, 03:37 PM   #16
ballistic_ken
Helmet hair victim.
ballistic_ken's Avatar
Oddometer: 5,391
I have a '05 TTR 125 and the clutch engagement is way out, no engagement at all until the clutch is almost fully released.
I am assuming the clutch pack is due for replacement, but am open to other ideas.
Running down a dream!
ballistic_ken is online now   Reply With Quote
Old 06-15-2012, 07:21 AM   #17
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,624
I know the lever on the clutch actuator is a bit short, but that usually causes a stiff clutch pull. I have heard (think it was thumper talk) of folks extending the that little lever. It may make the throw a littler longer but it sound more like you have a worn clutch. I assume you are getting close the the end of adjustment? it's not a stretched cable is it?
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 07-08-2012, 10:07 AM   #18
truck6driver
The Fireman
Oddometer: 7,507
Hey folks,
I bought an 08' for my son a week ago. It had what I thought was rocker arm noise that ended up being piston slap. So I pulled the top end and found a galded piston, well crap. The kicker is I accidently dropped the cam gear washer behind the flywheel. I pulled the side cover but could not see the washer. Using a puller I attemped to pulle the flywheel off. the puller ended up bending the threads of the crankshaft. Now I have an engine that needs a piston and a crankshaft.
Is the crankshaft really that soft? Has this happened to anyone else.
No aftermarket crankshafts and a new OEM one is $300
Any help would be appriceated.
Ray
Life has F@#ked with the wrong man. I will come out on top. Just watch.
truck6driver is offline   Reply With Quote
Old 01-24-2013, 08:58 AM   #19
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,324
Originally Posted by truck6driver View Post
Hey folks,
Ray
Sounds familiar.....
Yes, the crank is that soft. When I did it to my son's bike, I ground down the end of the crank shaft so the flywheel would slide back on easily without screwing up the tapered finish of the flywheel. I then machined down the left side of the inner hub of the flywheel so that the thread of the bolt would engage again. I believe I ended up removing something like 1/4" of steel. Bolted it back up and off we went.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is online now   Reply With Quote
Old 11-12-2014, 02:45 PM   #20
Baconologist
Oddometer: 218
bump and old dead thread. But I don't know where else to ask this.
Has anyone done SUMO wheels on a TTR 125 small wheel?
Baconologist is offline   Reply With Quote
Old 11-12-2014, 02:47 PM   #21
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,707
i've seen them before, i think the guy got them from Procycle:
https://www.procycle.us/bikepages/ttr125.html
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 11-12-2014, 02:52 PM   #22
Baconologist
Oddometer: 218
that would work for the 125L
We have 14/19's now. I don't think I can squeeze a 17 into the swing arm.
EDIT
Pro Cycle guy was a ton of help. It's not doable without changing the swing arm to run a 17" rear, bummer
Baconologist screwed with this post 11-12-2014 at 02:59 PM
Old 01-07-2015, 09:39 AM   #23
carburated
carburated's Avatar
Oddometer: 429
new years bump.
I recently picked up an older TTR125LE for my daughter (she has been riding an auto clutch TTR90). She hates the clutch and doesn't want to give up the 90. I looked into adding a Rekluse, only to find out they discontinued it for the TTR125 for some reason! What's the deal there? Anyway, looks like another company out there makes an auto clutch for it, http://www.efmautoclutch.com
Anyone have any experience with EFM? Seems crazy to spend as much on an auto clutch as I paid for the bike, but wtf. I have a strong vested interest in her wanting to ride, and the clutch pisses her off.
01 KLR650
00 GasGas XC250
04 ttr125l
carburated is offline   Reply With Quote
Times are GMT -7.   It's 09:23 PM.
