05-16-2012, 10:46 PM
#136 |
Oddometer: 820
05-16-2012, 11:12 PM
#137 | |
Oddometer: 3,686
You can brake fairly hard and hold your line. The consequences- for us mortals- of overbraking are immediate and likely to be painful, and it's not recommended if you can avoid it. Just to I've seen ABS activation while leaned over fairly hard...
05-17-2012, 07:11 AM
#138 | |
Crusty Demon
Oddometer: 338
05-17-2012, 07:14 AM
#139 |
Oddometer: 820
05-17-2012, 07:32 AM
#140 |
Oddometer: 17,989
When are we going to get to the catching on fire part?
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
05-17-2012, 08:54 AM
#141 | |
Oddometer: 3,686
DISCLAIMER: That is not to say one should rely on ABS to prevent you from falling down if you have to brake while turning. But it turned out that you can brake harder than you think in a corner. Smooth counts (DUH), and not as hard as in a straight line- but harder than you might think. So, you're both right. If you apply max braking in a straight line and try to turn, fall down go ouch. But you can brake fairly hard. Having to do so means you screwed the pooch on setting entrance speed, but that's another topic. |
05-17-2012, 10:36 AM
#142 | |
jack of all trades...
Oddometer: 6,587
I missed the part of saying I was misjudging my cornering speed. Maybe you're just deluded or something. Braking mid-corner when there is a reason that is not visible on entry is not misjudging, it is avoiding a situation, but of course since you'd simply run into whatever it was or else run off the road rather than brake while in a turn, there is no use in telling you this. I will tell you that as I actually think about it, I'm finding I actually do continue my braking or even increase it when actually leaning into a turn at times. It just all depends on what, when, where, and how. After all, I'm not always at the limits of traction. Just something that I apparently can do that you can not. A skill developed over about 40 years and a lot of miles in a lot of conditions. The past fourteen years have included several thousand miles of riding on dirt/gravel and rough pavement with the dual sports. As a few knowledgable riders here have said, it is not something one learns immediately or in some MSF class, it is slowly learned if a rider actually works on their skills, pushing the envelope ever so slightly again and again. It's not about pushing to the point of crashing, it is about pushing to the point of knowing how to do something that may be of great value some day. I have run into blind decreasing radius turns on unfamiliar roads a number of times while traveling at a reasonable rate of speed. Rather than sit up and go into the other lane or run off the road, I'd learned I could actually brake, even rather hard considering conditions, and hold my line through the corner. Maybe that doesn't seem of value to some here, but it certainly has paid off for me. Simply starting out with light braking, deceleration, acceleration, turning in, and turning out on a corner with good surface, good line of sight, and at reasonable speed is the perfect practice. As skills develop a rider finds it easier to brake more, move about more easily, accelerate, or decelerate in a corner. That develops a skill that makes it a lot harder to actually be into a corner too hot. When you know how to trail brake or actually intentionally brake while cornering, it comes in handy some times. But for those of you who do not believe this is possible, make sure you do all your braking before you get to a corner, otherwise you're gonna get hurt.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens! Mark - klx678 95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550 |
05-17-2012, 10:48 AM
#143 | |
Oddometer: 6,587
But then again I'm not quite clear on why you would come to a complete stop every time someone turns in front of you or cuts you off... wouldn't that be a bit dangerous on a road where the traffic behind you is closing in at about 50 mph or more? I can not remember the last time I came to a complete stop due to someone doing something like that. Slowed a lot, sure, but not stopped. Of course I also don't remember the last time I had a situation like that where I actually HAD to panic. Seems I've developed a skill for observing what is and what could happen in front of me and have been ready to take action before it is necessary. Try it some time you may find the panic situations are reduced greatly. I have. I find I'm actually braking harder in practice/play and also when running some of our favorite roads than I actually have had to do in traffic for the past several years.
05-17-2012, 10:54 AM
#144 | |
Oddometer: 6,587
So, if you brake really hard in a straight line and start to lock up the brakes are you going to keep them locked up until you fall over? Same thing with braking in a corner. A rider who knows how due to practicing and learning will not be stupid enough to stay full on with brake pressure when leaning into a turn. That is not saying they will not be braking fairly hard. It just means they know enough to work within the traction limits of the tire. Again, braking hard is a relative term. Braking hard on a slick concrete surface is totally different from that of an old asphalt surface. Same with wet versus dry and cold versus warm. It is entirely relative to what is possibly maximum traction. Same with cornering under braking. Those who play and learn, then practice can have a good grasp of this relative nature. Just because you and others do not does not make it impossible or wrong.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens! Mark - klx678 95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550 markk53 screwed with this post 05-17-2012 at 11:02 AM |
05-17-2012, 05:08 PM
#145 |
Crusty Demon
Oddometer: 338
05-18-2012, 02:32 AM
#146 | |
Citizen of the world
Oddometer: 1,096
05-18-2012, 05:35 AM
#147 |
Oddometer: 128
I absolutely get don't brake while cornering, and I avoid it whenever possible.
But, how else do you negotiate a clover leaf freeway offramp with a stop sign at the end of the curved section? Slow to 10-15 mph before doing the curve? I have one of those I ride fairly routinely. There is a little space to stand the bike up before getting to the intersection, but not very much. Even at the posted speed (25) you need to be on the brakes while leaned, or else practice a panic stop upright. |
05-18-2012, 08:20 AM
#148 | |
Oddometer: 6,587
You learn how to brake while leaning into a corner. Pretty simple now, isn't it. Realize "do not brake while turning" is a rule of thumb for new riders and those with lesser skills, not a law of physics. The physics law is do not exceed the available traction from your front tire in your combination of braking and cornering. The less traction used by cornering the more available for braking and vice versa. Easing into learning to brake while cornering is the obvious thing to do of course, much like anything else you learn to do. It's just using one's brain for more than filling a helmet. You obviously have some of the skill already with having to use brakes on an on-ramp.
05-18-2012, 08:21 AM
#149 |
Oddometer: 6,587
You mean along with not learning how to brake while leaning into a corner? By the way, the implication is I apparently am riding safely enough to not have to brake heavily for idiots who turn left in front of me, etc.
05-18-2012, 08:27 AM
#150 |
Oddometer: 820
