05-11-2012, 07:56 AM
#16 | |
Yinzer
Oddometer: 1,209
i understand why MSF teaches what they do to brand new riders. i don't understand why they don't teach 2 finger braking in the ERC, though. |
05-11-2012, 08:11 AM
#17 | |||
Oddometer: 3,683
1) Their primary focus is n00bs. It takes less coordination to keep all four fingers together, and that also helps them close the throttle for braking- because when I forget and the engine starts revving, I close the throttle, but a new rider is more likely let go of the handlebar. They will always blame the bike for having a sticky throttle. 2) Not every rider can generate maximum braking with only one or two fingers on the lever, especially not a new rider- the combination of finger strength and fine muscle control doesn't exist for them (yet... for many, it never will, because they don't care enough to try). 3) Not every bike can generate maximum braking with only one or two fingers on the lever. Some bikes need all the strength you can get; some bikes, fingers on the throttle will interfere with lever travel. A KLR fits both examples. 4) The ring finger (I'm told) has a better sense of feel than the index and middle fingers. dwoodward screwed with this post 05-14-2012 at 06:06 PM Reason: De-Klaying. Wow I was tired. |
05-11-2012, 08:25 AM
#18 | |
Oddometer: 819
05-11-2012, 08:34 AM
#19 |
Oddometer: 2,079
Practice almost everyday, usually on yellow lights. I don't run the yellow/red anymore.
A trick for your hard braking...squeeze your tank hard.
2010 Buell Ulysses 1984 Suzuki GR650 "Tempter" |
05-11-2012, 08:47 AM
#20 |
Samsquanch
Oddometer: 125
I practice a lot too, generally wen I space out and almost blow past a turn I wanted to take.
![]() (While checking my six, of course)
1985 XJ700 1999 R1100R JWG: yes, you guessed it, the rider is thinking WTF .. the road has bended |
05-11-2012, 09:46 AM
#21 | |
Oddometer: 501
You should ALSO practice in less ideal environments which are more like the real-life situation where you will need to brake hard, but not ONLY there. |
05-11-2012, 10:10 AM
#22 |
Isn't that dangerous?
Oddometer: 1,222
Sacrifice two chickens and a lamb....
EastSideSM: '06 950SM Black, '01 Honda RC51 |
05-11-2012, 10:21 AM
#23 |
Yinzer
Oddometer: 1,209
yep. you have to build the foundation first.
05-11-2012, 03:13 PM
#24 | |
Oddometer: 714
It's about good technique & good reactions wherever & whenever you need it. As somebody mentioned, practice will take you so far but good training will take you a lot further. |
05-11-2012, 03:29 PM
#25 | |
MNE
I was about to tell you the same thing practice practice .... |
05-11-2012, 04:23 PM
#26 |
Be aware
Oddometer: 2,472
And, if you ride a bicycle with hand brakes...
Flip the levers so the front is on the right not the left. Body memory and all that.
05-11-2012, 05:41 PM
#27 | |
not dead yet
Oddometer: 26,416
Again maybe from dirt exp, even a front lock-up doesn't put you down unless you fail to ease it. On non-ABS bikes, it amazes me how much little of the available braking a lot of riders use. I can think of two instances where I was leading a small group ride on pavement, was a bit late spotting an upcoming turn but still had time to brake and make the turn (on a non-ABS bike with knobbies), while a rider further back blew right by it (despite seeing me turn in ahead of him/her) due to lack of braking confidence.
Advanced pancreatic cancer diagnosed 04/2010. 95% mortality within 2 years but NOT DEAD YET. Been thru & still doing all sorts of treatments. Gonna keep doing what I'm doing until I can't any more. |
05-11-2012, 05:54 PM
#28 |
jack of all trades...
Oddometer: 6,587
1) They're primary focus is n00bs. It takes less coordination to keep all four fingers together, and that also helps them close the throttle for braking- because when I forget and the engine starts revving, I close the throttle, but a new rider is more likely let go of the handlebar. They will always blame the bike for having a sticky throttle.
2) Not rider can generate maximum braking with only one or two fingers on the lever, especially not a new rider- the combination of finger strength and fine muscle control doesn't exist for them (yet... for many, it never will, because they don't care enough to try). 3) Not every bike can generate maximum braking with only one or two fingers on the lever. Some bikes need all the strength you can get; some bikes, fingers on the throttle will interfere with lever travel. A KLR fits both examples. 4) The ring finger (I'm told) has a better sense of feel than the index and middle fingers.[/QUOTE] I highly recommend learning to use two or three fingers eventually. You develop the necessary hand strength. If your lever comes back far enough to pinch your fingers I'd be looking at why. If the lever comes back that far it is possible you aren't getting max braking capability. As for the ring finger, with all four fingers on the lever that won't make any difference. Again, watch experienced racers from about any motorcycle sport and you will seldom see them with all four fingers on the brake. I've seen some who use the ring finger on the clutch for quick slipping while having a good grip. On the off roaders the levers are short, making using all four fingers on either lever extremely difficult if not impossible.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens! Mark - klx678 95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550 |
05-11-2012, 05:57 PM
#29 | |
Oddometer: 714
When we started practicing it was a revelation how quick we ended up stopping. Something not mentioned so far is gear changing. The point our instructor made was your better off looking at the bumper of a car in 3rd gear than you are sitting on it in 1st. Fair call.. Being able to use maximum braking is the one thing that will save your bacon when the fan gets hit. |
05-11-2012, 06:16 PM
#30 | |
Oddometer: 714
Day to day on the road having the skills & confidence to use your brakes to the max when required is a life saver not a race winner. Somewhere between old spongy brakes & state of the art brick wall stoppers is the happy medium of using the right number of digits required to do the job. I think anybody willing to go out & practice has the right attitude to find out what works best for them & their bike. Their are quite a few variables so practice + training will give the best technique for a rider willing to learn. |
