Old 05-11-2005, 03:32 PM   #31
CA Stu
CA Stu's Avatar
Oddometer: 47,483
I have a really nice S&K 3/8" in/lb wrench, has worked well for me.
Can't find it on the web, but I think it goes from 15 to 180 in. lbs or so.
There are a shitload of Snap On and Mac tools on eBay every day.
You pay peanuts, you get monkeys.
Buy a nice one and be set for life.
CA Stu
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 05-11-2005, 03:45 PM   #32
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by meat popsicle
ok, so i got a bead on a couple of wrenches:
1/4in 0-75in-lb wrench vs. 3.8in 0-150in-lb.
creeper, I believe you recommended a 0-150in-lb. but in a 1/4. i am guessing the 0-75in-lb doesn't go high enough and am eyeballin the 0-150 - correct? and does the 3/8 hurt? (wouldn't think so)
if this all works out, which it probably won't , i will have two good wrenches with ranges matching the suggestions of Don Creeper
It kinda all depends on what you use them for. A 0-150 in.lb. 3/8" drive? Now that just seems odd. Is that a typo on your part?
So... how's tricks?
creeper is offline   Reply With Quote
Old 05-11-2005, 04:14 PM   #33
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,236
I was wondering if the 640a has bolts speced out in the 75-150 in-lb range... kinda thought that from you original suggestion of a 10-150. specs:
CDI
1502LDIN Dial Torque Wrench
Torque range english: 0-150 in. Lb.
Grads. English: 2 in. Lb.
Torque range metric: 0-18 Nm
Grads. Metric: .5 Nm
3/8" (DRIVE)
10" (LONG)
$ 167.19 (NOT WHAT I AM PAYING! )
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 05-11-2005, 04:15 PM   #34
meat popsicle OP
Ignostic
Oddometer: 14,236
CA Stu
Snap On and Mac are too trendy = expensive!
I am working on getting a nice one for my price range; wish me luck!
Old 05-11-2005, 04:22 PM   #35
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
My concept of the optimized set would be a 1/4 drive 20-200 inch pound (small fastener, small wrench) and a 3/8 drive 10 to 150 foot pound (medium fastener, medium wrench) wrench.
The idea of a 3/8 drive inch pound is... odd to me. A 3/8 drive that goes to 17 ft lbs?... What the hell is that for? Leverage?
So... how's tricks?
Old 05-11-2005, 04:26 PM   #36
meat popsicle OP
Ignostic
Oddometer: 14,236
agreed, but the only 1/4 that currently is a good price only goes to 75in-lb. thought that might not be enough range to cover me on the 640a... should I wait?
the other one I am trying to get to complete the set is a 0-100ft-lb. 1/2in drive... but the price is right
meat popsicle screwed with this post 05-11-2005 at 04:37 PM
Old 05-11-2005, 04:41 PM   #37
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
If it were me... I'd get a decent 3/8", 5-75ft.lb. to start, and wait until you can swing a 1/4 in.lb. Just use a little CS on the low torque fasteners.
I think I may have already said that once.
So... how's tricks?
Old 05-11-2005, 04:54 PM   #38
meat popsicle OP
Ignostic
Oddometer: 14,236
dont have a great price on the 3/8 5-75ft.lb... i guess that means a wait recommendation.
hm. i just can't see why these good deals wouldnt work well for the 640a. the quality and precision of the pieces is exemplary always worried about missing a good deal
"a little CS"... common sense? careful screwin'?
thanks for the help creeper; I do use a 1/4 drive as often as I can and take it easy on the little guys.
BTW, who knows what I would have ended up with w/out any help...
Old 05-11-2005, 05:21 PM   #39
CA Stu
CA Stu's Avatar
Oddometer: 47,483
I reckon mine's been pretty handy.. Wish I had it handy so I could post a pic, but I'm here at work....
Just going by memory, I think mine goes 20-250 in. lbs...
Cheers
CA Stu
Old 05-11-2005, 06:54 PM   #40
Max Power
Secret Agent
Max Power's Avatar
Oddometer: 4,526
1/4" drive 40-200 inch pounds
3/8" drive 200-1000 inch pounds.
Hi Ho Silver... Away!
Max Power is offline   Reply With Quote
Old 05-11-2005, 09:21 PM   #41
meat popsicle OP
Ignostic
Oddometer: 14,236
that's a big tool max...
show and tell, featuring torque wrenches!
keep em coming!
Old 05-11-2005, 09:26 PM   #42
Max Power
Secret Agent
Max Power's Avatar
Oddometer: 4,526
Old 05-13-2005, 06:35 PM   #43
CA Stu
CA Stu's Avatar
Oddometer: 47,483
Cheers
CA Stu
It goes 25-250 inch pounds,S-K model 74025.
3/8" drive, works great for cam caps, valve cover bolts, side cover bolts, etc.
CA Stu
Old 05-13-2005, 09:42 PM   #44
meat popsicle OP
Ignostic
Oddometer: 14,236
CA Stu
Thanks Stu,
I just won an auction on this:
CDI torque wrench
0-150 in. lbs.
Model 1502ldin
new with case
the 3/8in drive isn't a liability with the small stuff? i agree with creeper that it seems like overkill. but this one was the right price so i couldnt pass it up.
Old 05-13-2005, 10:05 PM   #45
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
CDI torque wrench
0-150 in. lbs.
Model 1502ldin
new with case
Sexy.
So... how's tricks?
Times are GMT -7.   It's 06:23 AM.
