05-10-2012, 10:41 PM
#1 |
Yankee
Oddometer: 4,452
Bigger gas tank for 2003 450EXC
I'm having difficulty finding any large fuel tank options for my '03 450 EXC except for the $afari tank, which also requires a seat change. Are there any other options that fit with minor modifications?
05-10-2012, 11:39 PM
#2 | ||||||||||||||||||||||||||||||||||||||||||||||||
tEAM iDIOT
Oddometer: 5,516
I though the 03 would accept the 04 to 07 tanks with no midification.
I know you need an 03 seat to fit a 03 to 07 tank on a pre 03 EXC. I'm running a tank was fitted to an 06 EXC on my 00 200, all I had to do was fit the 03 seat. Edit, I just did a part number search for the 03 450 exc tank (5900701350044) and it shows the following models use the same part... (remembering that this list only includes bikes with this part number and wont include thos that use a different part number because the tank is a different colour).
tEAM iDIOT... tHE oRIGINAL. Hard Core Dirt Touring. tHEtREV screwed with this post 05-10-2012 at 11:52 PM Reason: Did some looking. |
05-11-2012, 12:14 AM
#3 |
Needs to STFU
Oddometer: 7,778
I'm pretty sure there are differences between 02-07. My 05 Clarke tank did not fit on my buddies 02 450.
To answer your question, Clarke makes a good tank, but were I to do it again I would get the KTM hardparts tank, it's the same size (3.1gallons) but looks fkn cool. *Edit as far as larger tanks I think the supply is limited. There are 1gal auxiliary tanks you can buy though.
Wedding = $25,000 Divorce = $500 Brazilian 2nd wife = Priceless 2007 Triumph Tiger 1050 ABS
05-14-2012, 10:30 PM
#4 |
Yankee
Oddometer: 4,452
After consulting with a few other folks, I have a 6.6-gallon Acerbis on the way. It sounds as though it will fit well enough for my use.
05-14-2012, 10:39 PM
#5 | |
tEAM iDIOT
Oddometer: 5,516
I know the seat doesn't fit the tank unless you trim the front of it, but I thought that was all.
tEAM iDIOT... tHE oRIGINAL. Hard Core Dirt Touring. |
05-15-2012, 12:57 AM
#6 |
Needs to STFU
Oddometer: 7,778
I don't remember unfortunately. Might be the location of the tank mounting stem.
05-15-2012, 07:59 AM
#7 |
Oddometer: 160
The dual headers and the kickstarter are different and that may be the issue. I had to change my kicker to get an '03 stock tank to fit my '02.
<equipment_list>Insert a list of the crap you own here</equipment_list> |
05-18-2012, 02:16 PM
#8 | |
Yankee
Oddometer: 4,452
it with a hammer and vise but I have other work to do on the bike first. It does look like some minor seat modification will also be required.
05-22-2012, 04:59 PM
#9 | |
"Riders" Sequoia
Oddometer: 2,087
KTM 640-E / KTM 525 EXC CENTRAL VALLEY DUAL SPORT RIDES / RIDERS Sequoia-So Cal / STEWARDS OF THE SEQUOIA |
07-31-2012, 08:45 AM
#10 | |
Yankee
Oddometer: 4,452
08-01-2012, 05:01 PM
#11 | |
Oddometer: 12
Very interested in the outcome here.. I'm going through the same search, here in Australia, Bigger tank needed, no luck so far.. So, what sort of after market header have you ordered? "Mines damaged" so I need a new one
08-01-2012, 11:22 PM
#12 |
Yankee
Oddometer: 4,452
It's an FMF titanium PowerBomb header, it turned up on eBay and the price was very right.
08-02-2012, 04:34 AM
#13 |
Oddometer: 12
11-14-2012, 04:33 PM
#14 |
Oddometer: 1
I have an 03 300 exc and would also like to know how it turns out. I have been trying to figure out if I can order the 6.6 and make it work. What was the seat issue that you had and how did you overcome it? Any pictures of a finished product? Thanks
Joey |
11-14-2012, 04:54 PM
#15 |
tEAM iDIOT
Oddometer: 5,516
I was playing around with my 6.6 when I got it and put it on my 00 200exc for a test fit.
I had an 03 seat on it and was using a later model tank. The tank fit OK, but the tank braces that come with the kit wouldn't work, you would have to make new ones, and the seat mounting tabs wouldn't line up with the mounting nuts, they were a centimeter or two to far back. I didn't try to fit it properly, it was just a test fit and I have since sold the 200. There was a guy on this thread that fitted one to his 250sx so it must be possible.
