Old 05-13-2012, 06:57 PM   #1
lloydunknown OP
Oddometer: 78
propane airhead
"The extended cranking is because I'm running the engine on propane."
The comments say this airhead is running on propane. Has anyone else done this?
lloydunknown is offline   Reply With Quote
Old 05-13-2012, 07:44 PM   #2
ritetwist
ritetwist's Avatar
Oddometer: 178
Back in the mid-80's when gasoline was $.35 a litre, propane was $.09.Conversion to propane was all the rage.
Thing is, unless your engine was set up with Stellitted valves,it wasn't long before you needed new valves and seats.
Propane burns hot and dry and needs the stellitted vatves to stand up to the propane.Mileage worked out to be about 60% of what you would get with gasoline,thus the need for large tanks in the back of 1/2 ton trucks,or trunks of taxi's.Seems to me I had a 300 l. tank in one of my trucks.The propane burned very clean,extending oil changes and limiting spark plug fouling.The trucks also used a vaporizer with hot rad collant to help convert the propane from liquid to a gas.
My guess propane would be o.k. for a bike, if you could properly store it,the engine was set up for it, and you used it for short runs.
Afraid to sleep for fear of missing something.
ritetwist is offline   Reply With Quote
Old 05-13-2012, 08:26 PM   #3
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,463
....great "starting etiquette"....wrap her to 6 grand in one second and hold her there....I'd be a smokin too...
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 05-13-2012, 09:16 PM   #4
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Sorry but I'll wait until the technology has been worked out a little better.
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 05-13-2012, 10:23 PM   #5
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,797
Propane is the single nicest thing you could do for your motor. I have seen many propane motors that had 3-500,000 thousand miles on them, and they looked great inside still.
You loose a bit of power, but if you raise the compression significantly (it can be very high with propane) or supercharge, you get the power back.
The bike in the video is hard starting, and smokes because it is a worn out POS, not because it runs on propane.
Old 05-14-2012, 04:20 PM   #6
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,234
I hope no one here starts his engine like that! This guy obviously hasn't a clue that BMWs run very high oil pressure and when it's cold, the pressure is out the roof! And that's on top of takin-it-easy-till-it-warms-up. You're right fubar - that bike need some lovin' and a new owner.
Times are GMT -7.   It's 01:10 AM.
