Old 05-13-2012, 07:19 PM   #1
sam1905 OP
sam1905's Avatar
Oddometer: 221
Replacing airbox with cone filers and block off plate - what to do with breathers?
I am slowly building my cafe bike from a 1978 R100RS and have bought K&N cone filters for direct fitting to the carbs and a block off plate to replace the air box. (see link)
The two hoses that entered the airbox from the top/front (cc breathers?) will not work with this plate.
What options do I have - can i just remove the entire 3 hose assembly and if so do I need to replace it with anything?
Sam
http://boxermetal.com/?wpsc-product=...late-1970-1979
2010 R1200 GSA (For Sale)
2014 KTM 1190 R (On the way)
Jezebel - 71 Porsche 911R hotrod
2013 F150 FX4 to move it all around.
sam1905 is offline   Reply With Quote
Old 05-14-2012, 07:57 AM   #2
mykill
odd
mykill's Avatar
Oddometer: 1,166
You could rout it to a catch can or run a hose along your rear fender like Triumph did. If you clean your bike a lot, then a little filter attached near the breather could work as well. This pic wasn't intended to show the breather when shot, but the hose goes from an R65 breather cover and into the Boddingtons can.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Times are GMT -7.   It's 12:58 AM.
