10-24-2012, 04:42 AM
#151 | |
Oddometer: 576
The 690 has had fly-by-wire throttle since the first model... your dealer needs to read up on what he's selling....
10-24-2012, 05:41 AM
#152 |
Oddometer: 4,942
That's only partially true. The throttle butterfly is activated through a normal mechanical cable, there is just an extra controller (EPT) that can override it.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
10-24-2012, 06:19 AM
#153 |
Kool Aid poisoner
Oddometer: 5,061
I've never had a false neutral with my 690 or my 450.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
10-24-2012, 07:15 AM
#154 |
Oddometer: 176
False neutrals.
I get them, mostly between 5th and 6th. It's like 6th is in a different place: 1, 2, 3, 4, 5,.....6.
10-24-2012, 10:05 AM
#155 | |
Oddometer: 138
I've had them between 5th and 6th as well. Has happened while shifting up as well as down. Only once in a blue moon though. |
10-26-2012, 10:51 PM
#156 |
Oddometer: 28
The fly by wire throttle is used on the current 2012 Duke 690 together with a twin plug head and gives over 70 HP!!
It is also used on the new 1190 adventure,it is not used on the 690 E or R but my dealer has been told it will be used on the 2013 R. |
10-26-2012, 11:15 PM
#157 |
"Racin Mason"# 4
Oddometer: 1,401
I think you will find its on my 12 R model
10-27-2012, 04:21 AM
#158 |
Oddometer: 4,942
No it's not. The 690 models (except the 2012 Duke) until now have a mechanical throttle cable that can be overriden by the EPT computer through a solenoid that controls the throttle butterfly. It sits on the right of the butterfly shaft in this picture:
![]() The 2012 Duke 690 uses a true fly-by-wire system, or ride-by-wire as KTM calls it, so there is no mechanical connection there any more. ![]() This is what the throttle grip looks like, it has a spring inside to mimic the feel of a regular throttle pull: ![]() This system does of course offer some benefits because the computer can decide when it's a good idea to give it some more gas - e.g. when starting the bike etc - but at the same time it complicates things further. IMO - great on a 690 Duke that I ride around town, not so great on a 690 Enduro (R) that I'm taking out into the boonies.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 LukasM screwed with this post 10-27-2012 at 04:33 AM |
10-27-2012, 10:08 AM
#159 |
Oddometer: 28
Thanks for the feedback lukasM
I agree with you that it only adds more complication on a machine which I will be taking off road, that is why I am sourcing a new 2012 model. All you need is a bad or even faulty contact [dirt, dust, mud, creek crossings,vibration] where the ride by wire plugs into the EFI and youre in trouble,this is something I cant afford to happen as I am planning to ride around Australia and through deserts next winter using as many dirt roads as possible. |
10-27-2012, 10:13 AM
#160 | |
Oddometer: 4,942
10-27-2012, 11:21 AM
#161 | |
Oddometer: 189
'12 KTM RC8R, '07 Aprilia SXV 5.5 |
10-27-2012, 01:14 PM
#162 |
"Racin Mason"# 4
Oddometer: 1,401
sorry my mistake I thought it was fly by wire
10-27-2012, 01:42 PM
#163 |
Oddometer: 28
I wish I knew how to do a carb conversion as we can have trouble with dirty outback fuel here in Australia,some people have fitted extra filters on bikes and 4wd vehicles and used products like a 'Mr Filter Funnel" to strain the outback fuel when filling up.
The fuel gets dirty by not having the Service Station tank breathers covered with a dust filter and it can be extremely dusty in the Outback. There are reported cases of 990 Adventures and other fuel injected bikes breaking down in the Outback due to this dirty fuel,it has happened to a mate of mine 2 years ago on his 990 but some people have problems some dont. It is my biggest concern with taking a fuel injected bike into the outback, my 525 has a simple drain screw on the carburettor float bowl and you can simply dump the dirty fuel and flush out the contaminates. This is another reason why the carburettor Suzuki DR 650 is so popular for this type of travel here. I have done many kilometers in the Outback on my 525 with my Girl following in our 4WD pick-up and I have never had a dirty fuel problem with either vehicle,but doing a big trip solo on a fuel injected bike is still a concern to me but what choice do you have other than a heavy underpowered DR. But like I said some times its a problem most of the time its not but you only need it to happen once and it becomes a BIG problem. As a point of interest there is a very good Adventure Rider thread on this type of travel with a 690 it can be found at' Fifty Shades of Orange - A Tale of the APC Rally 2012' its a good read with plenty of photos and the trip covered over 7000 klms much of it in the Outback. |
11-11-2012, 12:28 PM
#164 |
Oddometer: 12
After mounting FMF powercore 4 on 690R 2012 owner needs to do this:
1. Throttle calibration 2. Idle reset procedure http://www.monomaniacs.nl/tnt/KTM-69...hrottle-issues 3. 2nd and 3rd gear restriction www.monomaniacs.nl/tnt/KTM-690/2nd-and-3rd-g2nd and 3rd gear restrictionear-restriction 4. SAS removal http://www.advrider.com/forums/showp...97&postcount=8 5. Mapping is that it? |
11-11-2012, 09:37 PM
#165 |
motorcycle guy
Oddometer: 88
12 690R probs
Any major problems?...a couple thus far. My roomie/riding friends bike has been a bitch (esp compared to my LC8). A quick read of this thread, did not see any similar issues . Not looking for answers here, bike is still under its 6mo warrenty, its going to the dealer asap. Here has been his summer with his first ktm/LC4
-intermittent stalling when hot @ traffic lights, with a extended long crank to get started again--PITA but not the end of the world. talked to the dealer, they had a 690smt there, same complaint, no problem found(prolly software glitch,whatev) -@ 700mi-bike would crank but not start or start briefly & would not rev-up after just eating lunch from tearing up some local twisties & running like a top, in front of a bunch god damn harley riders, he had to ride bitch home to get his truck ![]() No FI light, trailered bike to the dealer, several days later...they found debris in fuel injector(plastic shavings), cleaned out as nec, ran normal, shit happens *he installed a FMF pipe, hated it, said lost a lot of midrange (did not re-map it), re-installed stock exhaust *installed the open air box cover,was loud, removed for our 800mi trip(which went well), never re-installed @ 3500mi-(today) bike starts, hunts & holds a 5500rpm idle after a hot re-start from riding @ some local trails. He rode about 8mi home with the engine revving away the whole time. He could rev the engine to redline but would maintain the 5500rpm idle. No FI light he did drop the bike on its side @ very low speed in some mud, bike stalled quickly while on its side, fired right back up & romped it for another 15min w/no problem! Hes an expierenced MX rider, we shot the shit for a few minutes, went to ride some more & thats when the throttle had a mind of its own. shut if off & started it several times...bike could maintain hwy speeds in top gear by itself ![]() Were thinking a throttle housing or a TPS issue I was just trying to get him to go to MOAB with me next summer... ![]() Our KTM shop is very helpful & trustworthy I'll let you FF know when I know ****UPDATE**** was just a loose throttle housing to intake boot
"saddle up or shut up" KaTooM to Alaska http://advrider.com/forums/showthread.php?t=859471 AJ990R screwed with this post 11-19-2012 at 10:43 AM |
