Old 03-05-2013, 04:24 PM   #241
Hoots
Hoots's Avatar
Oddometer: 1,495
Originally Posted by DirtRider50 View Post
I just purchased a 2012 KTM 690 R Enduro. The bike is great, but I have to take the highway very often for long periods of time and 6th gear is not enough. If I down the sprocket from 45 to 42 would it help without losing too much the off road capabilities? I plan to do a lot of of road as well.
Thanks for any comments.....
This will seem a bit over the top, but I was astonished by how much difference an aftermarket air filter made - I was intending to change the gearing (for the reasons stated), and only held off doing so as would have to have changed the chain as well subsequently added the new air filter, and the bike feels as though it has a new gear - now cruises at 110kph at < 5K revs, which is pretty comfortable - I won't now change the stock gearing, which is ideal for the enduro end of things ...
PS: if determined to change gearing, take the counter-sprocket up to 16 and leave the rear as is.
Hoots is offline   Reply With Quote
Old 03-06-2013, 08:39 AM   #242
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,485
Which air filter did you get
MeinMotorrad is offline   Reply With Quote
Old 03-07-2013, 10:39 AM   #243
spoky0
Oddometer: 1
2011 enduro R - Mine was a bit lumpy when new but got progressively better as it put on a few miles, Akra fitted and remapped, 2750 miles, no issues, runs clean and smooth right up to limiter in all 3 settings. No low speed idling problems, well no more than you get from any single, will never idle like a four. Best dual sport I've ever owned, wouldn't part with it for anything.
spoky0 is offline   Reply With Quote
Old 03-07-2013, 02:45 PM   #244
Hoots
Hoots's Avatar
Oddometer: 1,495
Twin Air - with conversion kit from Rally Raid:
http://www.rally-raidproducts.co.uk/...-foam-twin-air
I also bought some filter skins from KTM Twins, to cut back on cleaning:
http://www.ktmtwins.com/ktm-690-rall...d-filter-skins
Both companies ship quickly - excellent result.
Old 03-07-2013, 11:44 PM   #245
13x
13x's Avatar
Oddometer: 48
2nd to that. The air filter really make a whole lot difference.
only 2 thing you have to get used to. The engine sound (something which i get used to and loving it) and the filter getting filthy really quick.
rode it in heavy down pour no problems at all. haven't tried any river crossings thou.
13x is offline   Reply With Quote
Old 03-08-2013, 05:54 AM   #246
MeinMotorrad
Oddometer: 1,485
With the snorkel delete for this filter do you gain any space under the seat for tools or something?
Old 03-09-2013, 01:13 AM   #247
Hoots
Hoots's Avatar
Oddometer: 1,495
Interesting that you found the same thing re' increased engine noise - I wondered why that was - almost sounds / feels as though the motor is breathing as it was meant to, which amounts to roaring - you do get used to it, and it is a nice sound ...
The filter skins from KTM Twins will cut back the need for filter cleaning.
Old 03-10-2013, 08:40 AM   #248
13x
13x's Avatar
Oddometer: 48
My initial setup was rr foam filter with leo vince exhaust, and boy it was REALLY loud. But due to strict vehicle modification laws where I'm from (Singapore) i have to switch back to stock.
with stock exhaust it did sound rather weird on low revs. but gotta love it when i you are at 3k and above. sounds more like a roar rather. hahaha
yes placing order for the skins now. and prolly a spare filter as well. thanks for the recommendation.
Old 03-25-2013, 10:13 AM   #249
bfilk
Bfilk
Oddometer: 82
2012 690 E 2nd 3rd gear restriction
Can anyone say definitively whether the US model 2012 KTM 690E has a second and third gear restrictor? Just wondering if the de-restriction mod is necessary.
Thanks for any help.
bfilk is offline   Reply With Quote
Old 03-25-2013, 10:54 AM   #250
SKINNY
SKINNY's Avatar
Oddometer: 645
I could have sworn that the US models were not restricted, but susequent opinions on this thread say otherwise. Others have said it's not worth the effort ...very little noticeable difference...
Both my 2008 & 2012 have not been modified...
SKINNY is offline   Reply With Quote
Old 03-25-2013, 12:41 PM   #251
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,966
The '12's have no 2nd and 3rd gear restriction....from what I've gleened.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 03-25-2013, 09:25 PM   #252
bfilk
Bfilk
Oddometer: 82
If the 2012 have no 2nd & 3rd gear restrictor then why do they have the 3 wires coming out of the transmission on the left side like those shown in the de-restriction threads?
Old 03-25-2013, 10:29 PM   #253
POMGRAD
POMGRAD's Avatar
Oddometer: 19
My 690R 2013 has big oil consumption?!
around 0.5l-07l per 1000 km, I use Motorex Crosspower 10W60 fully synth.
It has around 4000km,
In general it runs perfect.
POMGRAD is offline   Reply With Quote
Old 03-26-2013, 12:23 AM   #254
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,070
You could try running some regular (non-synthetic) oil in it for a few hundred miles to see if the rings will set.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 03-28-2013, 09:06 PM   #255
bergerkingman
Oddometer: 32
690 suspension
Got a 2012 690 enduro as a replacement for 990 advenure and DRZ400. I have some complaints. Heard reports that 690 forks & shocks are harsh. I planned to find a KTM suspension guy for adjustments. (optimistic because ktm's got to be good stuff) After about 2200 miles of mostly dirt and having the forks done with some improvement I gave it a final test. Dialed in the compression and rebound until I felt it was pretty good. Still seemed harsh but maybe it's just me. To put my mind at rest I got the DRZ400 out that I had not ridden for a year and went for the same 60 mile ride priviously done on the 690. The Suzuki was wonderful! Smooth & compliant forks & shocks that did not upset the whole bike, my back or wrists on every sharp hit from that unseen rock. All the good seats, fuel tanks, and other good stuff that could make it a great bike doesn't really matter if the suspension doesn't work. Looking for ideas to make the suspension more compliant. Right now it looks like ktm cheaped out on a potentially great bike.
bergerkingman is offline   Reply With Quote
Times are GMT -7.   It's 06:51 PM.
