Old 04-03-2013, 05:49 PM   #271
sprouty115
sprouty115's Avatar
Oddometer: 1,555
Originally Posted by goldwinger11 View Post
...Anyway, my question: Will putting a wings pipe and rally-aid air filter converstion kit do any harm at this point in break in process?
Not with the proper map. But then what's the rush, you still shouldn't be opening it up until it's broken in.
sprouty115 is offline   Reply With Quote
Old 04-03-2013, 05:54 PM   #272
goldwinger11
Oddometer: 3
Good point! But it is still fun to shop and plan....
goldwinger11 is offline   Reply With Quote
Old 04-03-2013, 05:59 PM   #273
eurods
Oddometer: 4
I have a 2011 690 Enduro R that I bought new. It has been an awesome bike. Perfect for a Dual Sport that is ridden mostly on non technical trails, dirt roads and pavement. I'd like to get the suspension re-valved, and a handlebar mounted map switch. With those two modifications, I think it would be way more friendly in the woods. This bike has so much torque, it's an absolute blast to ride on tight twisty mountain roads!
eurods is offline   Reply With Quote
Old 04-03-2013, 06:22 PM   #274
creedyflyr
creedyflyr's Avatar
Oddometer: 234
Thanks,
Harry
I did exactly that, Ditched the stock can & filter for Wings & RR filter as soon as I got it home. I asked the dealer when I picked it up & was told it would be fine. He even encouraged it. Although I did leave the stock map untill the 1st service, then went to Akra.
Creedy.
creedyflyr is offline   Reply With Quote
Old 04-03-2013, 09:18 PM   #275
Hoots
Hoots's Avatar
Oddometer: 1,498
Thanks for the response. I really do not want loud per say. The filter makes it louder than wings pipe? I had read the wings with silencer is not too loud. Breathing in and out better sounds like a good thing.....
The Rally Raid Twin Air filter makes the bike seriously LOUD ...
You get used to it, but ...
The other issue to think about is the fact that the Twin Air filter works without the plastic snorkel - i.e. it's just sitting there under the seat - the situation is worsened if you fit the Evo-2 tanks, as they necessitate removing the small plastic guards from either side/front and around the key - then there really is no protection at all - i.e you can stand next to the bike and see the air filter ...
IMO the Rally Raid Twin Air filter kit seems better suited to the situation where you also have an Adv or Rally fairing - it was designed for that scenario ...
I'm going to swap mine over to the UniFilter arrangement ...
Hoots is offline   Reply With Quote
Old 04-03-2013, 10:56 PM   #276
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,492
Originally Posted by brianpc View Post
Thank you for this thread!! I have a deposit down on a '13 enduro R, and after a year+ of ownership of a flawless and very reliable '12 350 EXC-F, this is starting to concern me! The dealer I buy from is very good however, so I'm hoping they're familiar with these issues that they can be of help.
Question - anybody from CA, what are you guys paying for these things? Anyone else have a deposit down on the '13? The ride by wire throttle I did not know about it, but I don't fear technology that much... Things like the broken tank bolts and the throttle body backfiring off scare me more!
Thanks again for all the info. :)
I wouldn't worry.
I've 3.5k+ miles with no issues. Replacing the tank bolts is very simple and quick. I can't recommend enough upgrading your seat to a Seat Concepts foam and skin - it will transform your bike from an instrument of torture into one that can be ridden all day long.
I'm two weeks away from heading off into continental Europe and Morocco/Western Sahara for the next year and more and I have no fears about reliability.
MeinMotorrad is offline   Reply With Quote
Old 04-10-2013, 08:41 PM   #277
PatSmith
Oddometer: 391
Temp gauge reading
My 2012 690 runs about 3-5 bars from the top most days. Is this about normal?
PatSmith is offline   Reply With Quote
Old 04-10-2013, 09:03 PM   #278
MeinMotorrad
Oddometer: 1,492
Depends on what the air temp is and what kind of riding you're doing. Doesn't sound like you have a problem.
Old 04-11-2013, 01:02 AM   #279
Hoots
Hoots's Avatar
Oddometer: 1,498
Mine is about the same - coming to the end of summer here, but has been a concern - gets a lot hotter on warm days, and slow going.
I'm going to replace the coolant with Engine Ice, and see what effect that has.
Old 04-12-2013, 12:17 PM   #280
dunefreak
dunefreak's Avatar
Oddometer: 93
Normal.
I have seen mine as much as 2 bars from the top when it's over 105F outside and I'm pushing it hard.
2012 KTM 690 Enduro R
dunefreak is offline   Reply With Quote
Old 04-14-2013, 01:10 AM   #281
POMGRAD
POMGRAD's Avatar
Oddometer: 19
Would this levels fit on 690R enduro?
http://www.ebay.com/itm/Clutch-Brake...9d1a26&vxp=mtr
POMGRAD is offline   Reply With Quote
Old 04-14-2013, 10:08 AM   #282
wsmc831
wsmc831's Avatar
Oddometer: 755
No.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 04-15-2013, 08:19 AM   #283
PatSmith
Oddometer: 391
Handlebar buzz / vibration
I have a stock 2012 690 Enduro with the stock tires.
I have what seems like a lot of buzz / vibration in the handlebars while riding on the street. I assume some of it is from the tires and some of it from the overly stiff suspension. Does any one have a solution to deaden some of this buzz / vibration?
Old 04-15-2013, 08:40 AM   #284
leanin
Oddometer: 181
[QUOTE=eurods;21102879 I'd like to get the suspension re-valved, and a handlebar mounted map switch. [/QUOTE]
Have you adjusted the clickers? I just got a new 2013 and the stock suspension setup was very stiff and harsh. I backed off the compression damping 5 clicks at both ends and it is MUCH better.
leanin is offline   Reply With Quote
Old 04-15-2013, 08:53 AM   #285
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 809
I ended up setting mine to "Comfort" for compression damping and "Standard" for rebound. I get some vibration, but it's a 690cc single with knobby tires, so part of the territory.
Bob Hancock
'14 R1200GSW; '14 F800GSA
'10 690 EnduroR; '88 R100RS
JustBob is offline   Reply With Quote
Times are GMT -7.   It's 04:35 PM.
