Old 04-15-2013, 10:21 AM   #286
zxrider11
Oddometer: 192
The buzz will go away after the 5,000 mile break-in. If you still feel too much buzz, there are options: BRP Rubber Mount
http://www.brpmoto.com/products?page...tegory_id=1774
zxrider11 is offline   Reply With Quote
Old 04-15-2013, 03:33 PM   #287
PatSmith
Oddometer: 391
Buzz / vibration
HI GUYS,
Thanks for the responses. I have my clickers all the way in Comfort setting already. A quick check of static sag shows only 10mm of sag, so clearly I have other issues to address first. The PO put the lowering link on it and as he weighted even less than i do, I suspect he did not check / set sag after install. Off to do some sag work and will consider the BRP rubber mount idea. I only have 1100 miles on it now. Sure hope my wrists make it 5k.
PatSmith is offline   Reply With Quote
Old 04-15-2013, 04:28 PM   #288
sprouty115
sprouty115's Avatar
Oddometer: 1,415
Originally Posted by zxrider11 View Post
The buzz will go away after the 5,000 mile break-in...
5000-mile break in? I assume you mean 500?
sprouty115 is offline   Reply With Quote
Old 04-15-2013, 05:32 PM   #289
zxrider11
Oddometer: 192
Yes 5,000 miles - right about the time of your second regular oil change.
Old 04-15-2013, 08:50 PM   #290
PatSmith
Oddometer: 391
5000 mile
This is my first foray into KTM's. What happens at 5000 miles?
Old 04-15-2013, 08:52 PM   #291
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,914
What happens at 5,000 miles?
You'll still have that stupid grin everytime you twist that right grip.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 04-15-2013, 09:07 PM   #292
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 485
At just 175 miles I started having stalling issues when coming to a stop. Tonight I had a hard time starting it after a 5 minute ride to the drug store. FI blink 37 noting a ignition coil/cylinder issue. I will see if there are some loose connections tomorrow. Hopefully it will be a simple fix like a loose wire or something.
palmstatecrawler is offline   Reply With Quote
Old 04-16-2013, 05:34 AM   #293
sprouty115
sprouty115's Avatar
Oddometer: 1,415
From another thread:
"A few miles down the road Luke's bike dies. NICE! Right now my bike is in the lead for least reliable, so I am pretty excited for Luke's to gain the lead back. Unfortunately it gives us a familiar fuel injection code: 3 long then 7 short. We've already seen this twice and know it's just a loose wire. Crap! I guess my bike is still in the lead. By now we consider this fix maintainace and not a break down. Similiar to my weak rims that get dented every other day."
Old 04-16-2013, 05:44 AM   #294
sprouty115
sprouty115's Avatar
Oddometer: 1,415
I can't seem to find anything that indicates 5000 miles is the break in period. According to the owners manual you moderate the throttle and limit RPMs for the first 1000Km. Then you change the oil every 10,000Km. This is pretty much what Triumph recommends (my other bike). Where did you come up with 5000 miles?
Old 04-16-2013, 06:28 AM   #295
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 795
As a KTM noob...
it seems to me that the weak link in this bike is the wiring loom. I seem to be tracing down a loose wire or one that's not firmly connected more than I've had to do since my '67 BSA Thunderbolt. Headlight was the last one. Solved quite easily but not up to modern standards. I guess such is the penalty for weight loss.
Bob Hancock
'14 R1200GSW; '14 F800GSA
'10 690 EnduroR; '88 R100RS
JustBob is offline   Reply With Quote
Old 04-16-2013, 07:01 AM   #296
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,414
Spontaneously combusts.
Old 04-16-2013, 07:02 AM   #297
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,414
I think what they are talking about is around that mark the bike starts to run smoother, i.e. less vibration. I hit 5K miles so long ago I really don't remember anything changing.
Old 04-16-2013, 10:14 PM   #298
PatSmith
Oddometer: 391
Static sag and rider sag
What measurements are guys running for Static and Rider sag?
Old 04-16-2013, 11:00 PM   #299
palmstatecrawler
Oddometer: 485
So it was an easy fix. The purple/white wire was the culprit as sprouty pointed out. Everything appeared fine so I tugged on the both and the purple/white easily came off. Seemed like it was good enough to make contact but I tightened it and all is well now. Thank goodness! Back to enjoying my bike thats too big for me!
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
Old 04-17-2013, 06:50 AM   #300
MrHix
MrHix's Avatar
Oddometer: 384
I would recommend sending your suspension out for lowering & respring/revalve so you can reach the ground. I am 5'8" with a 32" inseam & I could only touch the ground with the bike leaned over. I sent the suspension to Superplush and they lowered it 1.5", resprung it for my weight, and revalved to better fit my riding needs (basically everything). I can now touch the ground with the balls of my feet and it handles everything from pavement potholes to log jumping better. I still have about 8.5" of travel front & rear.
It is an expensive job ($1000 or more), but if you get the right stuff done, it makes a world of difference!
Cheers,
MrHix
MrHix is offline   Reply With Quote
Times are GMT -7.   It's 02:25 AM.
