Old 06-09-2013, 06:44 PM   #316
Hoots
Hoots's Avatar
Oddometer: 1,581
Originally Posted by PatSmith View Post
I tried a 17 tooth cs sprocket today and found it had slight interference with the rubber swing arm protector. Went to a 16 instead. Is anyone using a 17 cs on a 12 enduro?
I run 16/44 - great combination ...
Hoots is online now   Reply With Quote
Old 07-03-2013, 06:55 PM   #317
LordSteven
LordSteven's Avatar
Oddometer: 53
Thanks to creedyflyr for advice on clamp, worked perfect. Went for a two day ride with no issues.
My fuel overflow problem was simply my fault. When filling, the fuel was splashing back into overflow hose. A little care in aiming the fuel when filling solved the issue.
LordSteven is offline   Reply With Quote
Old 07-03-2013, 07:55 PM   #318
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
That's what she said!
Old 07-04-2013, 01:18 AM   #319
creedyflyr
creedyflyr's Avatar
Oddometer: 237
No worries Mate, Its sometimes the simplest solutions that are often overlooked. Glad to help.
Creedy.
creedyflyr is offline   Reply With Quote
Old 07-05-2013, 11:51 AM   #320
Martin Eves
Martin Eves's Avatar
Oddometer: 20
Notice that MY12 690 have an quite high oil consumption, 0,15L every 1000km.
About twice compare to my 653cc MY09.
Friends spark plug with Akra mapp and Slipon.
Is it running to lean?
Looking ok for me.
Martin Eves screwed with this post 07-05-2013 at 12:00 PM
Martin Eves is offline   Reply With Quote
Old 08-09-2013, 09:51 PM   #321
POMGRAD
POMGRAD's Avatar
Oddometer: 19
Hi, I am just wondering would this lamp start if engine oil is too low?
or in just case of damage oil lines, hoses, engine clutch cover ... etc...
I thing that only 690R models 2012-2013 had it.
POMGRAD is offline   Reply With Quote
Old 08-10-2013, 12:50 AM   #322
Hoots
Hoots's Avatar
Oddometer: 1,581
My oil light flashed a lot until I installed the correct map for the Akro pipe / air filter - the bike was idling too low ...
Still flashes occasionally when very hot, but not otherwise ...
Old 08-10-2013, 06:39 AM   #323
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 489
My oil light is on when the keys turned on and starting the bike but never while the bike is running. It should come on if the oil is too low.
Well while we are on the subject, the lock light us supposed to be for the ignition lock? Im confused. In order to get the instrument cluster to turn on the key must be in the "on" position. When would this light ever come on?
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
palmstatecrawler is offline   Reply With Quote
Old 08-10-2013, 04:19 PM   #324
palmstatecrawler
Oddometer: 489
Its right above the battery light.
Old 08-11-2013, 03:23 PM   #325
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Could possibly be for an OEM alarm system.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 08-17-2013, 10:21 PM   #326
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 625
'13 690Enduro R questions
I bought my '13 690 Enduro R used with 2600 miles on the clock.
What should be a proper idle rpm?
Also the side stand is hard to raise when sitting on the bike over pavement, worse on uneven dirt. A lot of right lean is necessary. Seems the angle is too vertical. But of course less vertical would put it sticking out when up.
If you have done something to fix that what was it?
coarsegoldkid is offline   Reply With Quote
Old 08-17-2013, 11:28 PM   #327
palmstatecrawler
Oddometer: 489
Aha! Hadn't thought of that. I have a gorilla alarm hooked up now but if it has an oem one I will get it.
Old 08-17-2013, 11:33 PM   #328
palmstatecrawler
Oddometer: 489
Proper idle should be around 1500.
The sidestand issue is usually from having a lowering link on the bike. If you don't have a lowering link you probably need to stiffen up your rear suspension and make sure you don't have excessive sag.
Old 08-18-2013, 07:25 AM   #329
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,991
Same thing here with the long sidestand.
I cut 1/2" off of the length and welded on a piece of 2" by 3" stand pad. Even with panniers loaded, now it sits at a better angle and it's much easier to kick the side stand up while sitting on the bike.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 08-18-2013, 07:35 AM   #330
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,175
too lean
[QUOTE=Martin Eves;21797746]Notice that MY12 690 have an quite high oil consumption, 0,15L every 1000km.
Looks lean to me. I like to see them a dark tan.....................................
fastdadio is offline   Reply With Quote
Times are GMT -7.   It's 01:23 AM.
