Old 07-10-2012, 05:10 PM   #61
4Lo
Oddometer: 28
I was running the Advanced #2 Map. Gonna need better response off idle for the tight trails. Probably a pipe and tune in my future huh?
4Lo is offline   Reply With Quote
Old 07-15-2012, 02:53 PM   #62
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,595
[QUOTE=4Lo;
3) I plan to get the Euro tail and some small LED turn signals. But for now, I eliminated the fender thingy and tried my luck with some aluminum tape on the lower half of the OEM turn signal to keep it from melting. Holy shit! It worked like a charm! Simple fix I guess.
[/QUOTE]
Isn't an issue on later model 690s KTM changed the stalk so it sits up out of the exhaust stream. I gather that some after market pipes like the Leo Vince may require some mod to the signal light as the pipe seems to be set up for bikes with the European tail where the signals lights are set lower. In any event now you are doubly protected
CanadianX is online now   Reply With Quote
Old 07-15-2012, 02:56 PM   #63
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,595
Originally Posted by Kirkster View Post
I think my pressure sensor is on its way out also... First started acting up a little bit ago and will come on when at idle now...
Are you getting the 1x long 4x short FI flashes for the ambient air pressure sensor? Been having this come up on mine on occasion.
Old 07-17-2012, 12:59 AM   #64
Frontwheel21
Oddometer: 43
I have had one major problem a couple of days ago. In a hot city center of southwestern France suddenly the FI warning lamp started to flash. I could not anymore accelerate properly and there was lots of backfire (spark failure) and the exhaust was extremely loud. Also the engine easily died off. At first the blinking code was 6x short (throttle position sensor circuit A - input signal too low). So I called my local mechanic and he said I should check the connections/plugs and I should also take off the cable from the battery (that did not help). After reconnecting the battery cable, the blinking code changed to 9x long (throttle position circuit fault). Fortunately I found a big KTM dealer just 5 km away from me and could make it to him on my own. They also considered this failure as a major problem and could not repair the throttle position sensor. Thus they replaced it with a new one. Then the bike run again perfectly as before. Actually, I was a bit disappointed that there was a major problem already after just 4200 km driving. I bought this new 690 mainly because there were some very positive reports about this 2012 model which emphasized its reliability. Also the extended 10,000 km intervals for service gave me confidence in this new LC4 engine. I do not think that the throttle position sensor failed because of "aging". So here are some facts about my bike and also my explanation (just a guess) for the failure.
I have the Akra slip-on without cat on my bike. My local dealer put the Akra mapping on the bike. So this worked very fine (smooth engine running + no oil consumption) the first 2800 km basically only onroad driving. For the next 1000 km offroad driving I changed the mapping on the map select switch from position 3 (akra) to position 1 mainly because with this soft mapping you can drop down to just 2000 rpm without causing the engine to die off (after 3800 km I switched back to position 3 for "street mode"). I really liked this soft mapping in rough terrain but I am afraid that this is not healthy for the LC4 if you have Akras without cat mounted. The soft mapping is adjusted to the stock pipe with cat so I guess that this caused the failure. I also noticed that the oil consumption suddenly increased after I switched to position 1. Interestingly, the mechanic in France told me that there was no Akra mapping on my bike although my local mechanic said he put it on. Maybe the use of the soft mapping for 1000 km driving caused the Akra mapping to disappear?? To sum up, I think it is not advisable to use the soft mapping (optimized for stock pipe with cat) when you have mounted an exhaust without cat.
Frontwheel21 screwed with this post 07-17-2012 at 01:22 AM
Frontwheel21 is offline   Reply With Quote
Old 07-17-2012, 04:20 AM   #65
wino975
wino975's Avatar
Oddometer: 49
the map is disappeaed??? change mechanic ;)
anyway putting the selector in 1 (soft map) only affect the way how the butterfly is opened.... nothing else
wino975 is offline   Reply With Quote
Old 07-17-2012, 04:58 AM   #66
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Weird what you write here.
As far as I know, position 2 or 3 works well with the Akra. (actualy what I have) Where did you get this that position 3 is not for Akra ???
As far as reliability is concerned, you certainly did not read on ADVRIder. There are thousands of threads relating to the 690 issues.
Paul jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 07-17-2012, 05:32 AM   #67
Frontwheel21
Oddometer: 43
Why weird? I said that position 1 (soft) seems to have caused problems in conjunction with the mounted Akra because I cannot think of anything else to be the reason.
Concerning reliability, this thread is to report on major problems with the 2012 model (which I have). I have just described one major problem I experienced but I also wrote that I JUST GUESS what could have caused this problem....If you have more constructive suggestions or better ideas I would be thankful.
(Yes it is strange, I have no idea why the French mechanic did not find the Akra mapping anymore but I just know that I have a very trustworthy local mechanic.)
Old 07-17-2012, 08:38 AM   #68
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,597
He wasn't referring to your particular issue, He was referring to your statement that you bought the 690 under the assumption that it was a reliable bike, and he was just pointing to the fact that if you had read a lot of the posts here, that's not an assumption you would readily make.
Old 07-17-2012, 01:37 PM   #69
Kirkster
Parts Murderer
Oddometer: 296
Sorry bit of confusion... My oil pressure sender may be packing it in. No ambient air pressure sensor problems for me...
TAT 2013 the "I'm Just Sayin" tour
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Kirkster is offline   Reply With Quote
Old 07-17-2012, 03:57 PM   #70
Frontwheel21
Oddometer: 43
@Albie your (off-)topic is unfortunately missing the point/problem. Gros Buck even didn't read that I am talking about problems with the position 1 mapping. But anyway, despite this obvious ignorance the point is that many guys are right now buying the new 690 model MY2012 because it is considered very reliable for a single cylinder. Imagine this new 2012 model has service intervals of 10,000 km, thus more than the LC8 Adventure with 7500 km service intervals. Moreover, the new model has improved also small technical issues like friction with the radiator/cooler and other parts. And yes, of course this bike has still some known "typical weaknesses". But together with the extremely cultivated performance of this single cylinder many customers have good reason to believe that they purchase a relatively reliable LC4, despite all the "negative information" from older models which they surely read before investing almost 10K Euro for the new model. That's why they still want to know in this special thread if there are still major problems with this model. I have just reported one major problem with the new model but that doesn't mean that I am unhappy with my bike...By the way, this is not my first KTM so I know why I made my buying decision...
Old 07-17-2012, 04:31 PM   #71
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,597
Old 07-17-2012, 04:55 PM   #72
SportsGuy
icanhazdirt?
Oddometer: 538
Originally Posted by Albie View Post
Albie, you've got a good head on your shoulders.
SportsGuy is offline   Reply With Quote
Old 07-17-2012, 07:40 PM   #73
ramjet
ramjet's Avatar
Oddometer: 2,219
It's not a major problem but annoying and relevant to the 2012. It is the kickstand. It seems way too long. Jump on the bike and you need to lean right to get the damn thing
up. Shorter works better for me in offroad situations also. They all like this?
Fundamentally transforming a KTM..
ramjet is offline   Reply With Quote
Old 07-17-2012, 07:52 PM   #74
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,162
Not so for somebody not overweight... Just kiddin..
I am 195 lbs and my problem too. Plus I am only 5'9" making it worse around town and at filling stations and such.
I am installing a lowering link and I have to cut the side stand. I lowered my Yam 1 inch and cut the side stand a half inch. Was perfect.
I think the new 690 will require a full 1 inch cut on the stand, because stock, the stand is too long. Haven't decided yet, though.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 07-17-2012, 09:38 PM   #75
ramjet
ramjet's Avatar
Oddometer: 2,219
I know, Pantah, that's the killer-I weigh 156. And it's nice to be able to get the stand down on a hill and still dismount to the high side. While only slightly taller than you I've adapted to it OK because my XR was as tall as the 690. I agree, this bike needs a 1 inch standectomy.
Times are GMT -7.   It's 02:36 PM.
