Old 05-13-2012, 07:59 PM   #1
Harpua OP
formerly josdavlar
Harpua's Avatar
Oddometer: 166
Questions about bringing a Yamaha CT1 back to life
so i picked up this CT1 for $100. it's got everything except street legalizing stuff. hasn't run in years. the counter sprocket looks fudged so i'm thinking that's when they put it away. i just want the bike to run nice and reliably as a light trail bike.
the two big things are:
-is it necessary/worth it to open up the engine? it turns over without protest. there was a little water and a little oil in the case. i don't know much about two strokes so i don't know how the valving works and if it needs attention as a matter of course.
-should i scrap the auto oiling system and just mix the fuel? this sounds a lot easier to me and more reliable...
other things:
-is it worth it to replace the ignition system with a solid state system?
-is it worth it to mess with the suspension or will it suck no matter what?
i'm digging this old bike!
THANKS!
Harpua is offline   Reply With Quote
Old 05-13-2012, 08:38 PM   #2
Shocktower
Shocktower's Avatar
Oddometer: 9,488
Ok on the oil injection system leave it on how many miles and we need pic's how bad is it, pay as you want to play with the suspension
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 05-13-2012, 09:44 PM   #3
Harpua OP
formerly josdavlar
Harpua's Avatar
Oddometer: 166
still trying to figure out the two sparkplug thing...
Old 05-14-2012, 12:31 PM   #4
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,376
one plug is just a back up incase the one your running on fowls you just swap the plug wire over.... have you checked the point gap ?? the timing ? compression ?
its a two stroke there aint no valves just a couple of ports in the cylinder.
sign up at yamahaenduro.com
JeffS77 is offline   Reply With Quote
Old 05-14-2012, 06:13 PM   #5
Harpua OP
formerly josdavlar
Harpua's Avatar
Oddometer: 166
compression... yes, one of the few really important tools i don't own... good idea tho, i'll borrow one. or maybe i'll just buy one and be done with it.
that's funny about the spark plugs! it's like they threw their hands up and said, we can't fix this, here's a workaround. i wonder if you put on a modern ignition system if you could fire them both off for better combustion like on my DR.
thanks for the yamaha enduro link... i've signed up.
Old 05-23-2012, 06:55 PM   #6
AC Swank
AC Swank's Avatar
Oddometer: 9,641
There is no modern ignition system that will fit, just the magneto you have.
Make sure you use the correct puller to remove the flywheel, and yes the puller threads are left hand.
If your lucky, all you will need to do is spray some contact cleaner to remove the crud on the points and coils.
If you decide to reset the timing, you might want to get a dial indicator (the head will need to be removed). You might get lucky and the timing tab will still be there attached to one of the coils (there is a scribed line inside one of the cut outs of the magneto face.
AC Swank is offline   Reply With Quote
Times are GMT -7.   It's 07:42 AM.
