Old 05-13-2012, 11:47 PM   #1
greenjeans OP
man with purpose
greenjeans's Avatar
Oddometer: 87
stock exhaust vs aftermarket
so my GSPD has a super trap muffler on it and i can't take the volume, my first choice would be a staintune but the cost is over the top, 850 just for the mufler, ouch, but on ebay there is a full stock system for 5 bills, would i regret the swap? and if i just changed the muff and used my headers & Y pipe would it still be stock quiet? thanks for any advice! gj
greenjeans is offline   Reply With Quote
Old 05-13-2012, 11:52 PM   #2
tkent02
Oddometer: 2,255
Take a few plates out of the supertrapp.
It will quiet it right down.
tkent02 is offline   Reply With Quote
Old 05-14-2012, 12:35 AM   #3
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,769
Unfortunately Supertrapp's are restrictors not mufflers, so the less plates, the quieter it will be, but it will cost you power for sure. There are a lot of mufflers that could be adapted onto the header you have, with minimal expense. One suggestion is a 96-2006 GSXR muffler. These are light, almost free, very quiet, and make great power. A simple flange welded to your headed, and a different mounting bracket will fix you right up.
There are other options, but this is one I use a bunch.
Old 05-14-2012, 03:04 PM   #4
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,717
I doubt the stock can will work with the supertrapp headers and Y-pipe.
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 05-14-2012, 03:30 PM   #5
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,463
I can guarantee it won't. Different diameter and different location. Also a big part of what makes the stock GS system quieter than most is the GIANT collector box. Replace it with a y-pipe and it'll be a lot "BRAP"-ier.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 05-14-2012, 10:24 PM   #6
greenjeans OP
man with purpose
greenjeans's Avatar
Oddometer: 87
Thanks for the advice i will pass on the stock setup and play with the supertrap discs for a little less volume.
Old 05-15-2012, 06:37 AM   #7
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,342
It is going to sound like some sort of sick airplane no matter what you do.....Just the nature of the beast. IMHO the only thing you can do is make it super quiet (stock muffler) to make that flat drone go away.
I had the Supertrapp on mine and went back to stock.....I sold my Supertarpp used for $400 15 years ago....I bet a nice one is still worth at least that much.
The ST also has lotrs of fibergalss packing taht blows out after a while (in addition to the discs. You might try repacking it to see if that helps.
This is SPARTA!
SCQTT is offline   Reply With Quote
Old 05-16-2012, 08:06 AM   #8
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,472
The stock system is the way to go on airheads in general. Even lots of race bikes use them. HPN tried to improve on the gs exhaust and muffler and couldn't , today they make a $700 carbon muffler that is basically a lightweight version of stock.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Times are GMT -7.   It's 10:20 PM.
