Old 05-14-2012, 06:46 PM   #1
lloydunknown OP
Oddometer: 78
Head Stud Question - Airhead
1983 R100RT
I pulled my heads, pistons, and cylinders. These leaves four studs on either side.
On the left side, or the shifter side, I can flick each stud and hear a twaaaaang sound.
On the right, rear brake side, I flick three and hear a twaaaang sound.
The fourth stud is the bottom stud closest to the front wheel.
That stud doesn't twaaaang. Instead, I can screw and unscrew it by hand.
I also can feel inside the case and touch the end of the stud.
The other studs seem to be installed into blind holes instead of through and through.
Does this sound out of the ordinary?
lloydunknown is offline   Reply With Quote
Old 05-14-2012, 09:09 PM   #2
bmwrench
Oddometer: 2,060
Only the two right rear stud holes are blind. If the threads look good in the hole in which you can turn the stud, loctite that stud. Actually, I Loctite all of them to prevent movement.
bmwrench is offline   Reply With Quote
Times are GMT -7.   It's 05:39 AM.
