Old 05-17-2012, 07:04 AM   #1
R90pilot OP
Oddometer: 19
Oil PSI Switch
I remember reading about NAPA having an oil PSI switch that was a match for the R90/6 but I can not find the napa part number. Does anyone have that handy?
Tom
R90pilot is offline   Reply With Quote
Old 05-17-2012, 07:12 AM   #2
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Tom
It's actually more expensive than the factory BMW one. Are you near a BMW dealer or have access to one?
Don't believe the rumors that "it's the same as any aircooled VW" that's not true except for the 70-73 /5 bikes.
Sorry don't recall the part number from NAPA but I believe it was from an 80s model BMW car.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 05-17-2012, 07:22 AM   #3
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,548
Also I think I remember that the VW sensors have a somewhat higher switching pressure so they'd give a bit more advanced warning of oil pressure loss rather than indicating that you're already f*&%ed and have been for a while.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 05-17-2012, 07:51 AM   #4
R90pilot OP
Oddometer: 19
NAPA Oil Pressure Switch OP6065
Old 05-17-2012, 08:06 AM   #5
Airhead Wrangler
Adios Mexico
Oddometer: 6,548
What's the switching pressure? The NAPA switches with the higher pressure can flicker at idle and freak people out. FYI.
Old 05-17-2012, 08:14 AM   #6
Garbln
Oddometer: 450
The stock ones can flicker at idle too! I have BMW's with each kind.
Garbln is offline   Reply With Quote
Old 05-17-2012, 08:26 AM   #7
Airhead Wrangler
Adios Mexico
Oddometer: 6,548
If a stock BMW oil pressure switch functioning correctly is flickering at idle then you have problems. Either your oil pump, mains, or big ends (or all three) are hosed or will be shortly. The switching pressure on the stock switches is only about 3 psi, so if you have less than that, your engine is devouring itself. You sure you aren't looking at the charge light?
Airhead Wrangler screwed with this post 05-17-2012 at 08:36 AM
Old 05-17-2012, 01:01 PM   #8
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
61 31 1 243 414 is the BMW number, msrp $10.80 and comes with the crush ring
NAPA #OP6065 is $13.99 does not show the crush ring in the online pic
www.wirewerkes.com
Old 05-17-2012, 05:33 PM   #9
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
No kidding! Just ask me how I figured that one out!
And if the light is OK at start-up but flickering under decileration, you REALLY need to look things over!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Times are GMT -7.   It's 12:13 AM.
