Old 05-17-2012, 12:46 PM   #1
GearHeadGrrrl OP
Oddometer: 332
How hard to replace fork seal on 1992 R100GS?
MN Tech day is saturday and I think I've got all the parts and tools here... What am I getting myself into?
blogging @ www.gearheadgrrrl.com
GearHeadGrrrl is offline   Reply With Quote
Old 05-17-2012, 01:16 PM   #2
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,668
a simple job, loosen the top caps ( don't remove till fork are off), remove caliper,remove axle and wheel, loosen large allen bolt at bottom of forks, loosen triple clamps, remove fork brace, remove forks, then gaitors, remove cap, drain plug and bottom allen bolt, with draw slider from tube, then remove seal retaining ring along with washer, then pop the seal out. Clean and inspect tubes and sliders, assembly is in reverse.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 05-17-2012, 01:34 PM   #3
supershaft
Oddometer: 9,110
That's way easier said than done IMO. A lot of people I have seen do that job including myself has a major issue getting the retaining ring out. My very quick and easy trick is to take the seal out first. How? With a small modified Vise Grip. Then I femove the retaining ring after I remove the seal. IMO it makes the job WAY easier.
Old 05-17-2012, 03:57 PM   #4
jimbee
Airhead Intermediate
jimbee's Avatar
Oddometer: 334
Just did it myself last weekend. One Less Harley's description is good. As SS, pointed out, the retaining clip can be tricky. I'm not the strongest fellow, but I found some determined prying with a small screwdriver (wearing safety glasses) worked okay. Bon Chance
R100GS for going far, FZ1 for going fast, TE250 for getting dirty, and DR650 for when one of the others needs work
jimbee is offline   Reply With Quote
Old 05-17-2012, 04:06 PM   #5
One Less Harley
Oddometer: 4,668
these forks are way easier than others!!! On a scale of 1-10, I'd rate the job as a 5-6, mainly due to with the number of parts taken off.
BTW- witht he forks bolted up before you put the springs and oil back in, make sure the forks move freely.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 05-17-2012, 07:44 PM   #6
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,136
I am normally pleasantly surprised at how easy fork seals are to change. That is true right up until they're bollocksed up good, anyway
But really even I find it to be not that taxing.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 05-17-2012, 08:11 PM   #7
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,276
i don't even remove the fork tubes from the bike. you can drain the oil, remove the wheel and fork brace and then unbolt the lowers from the tubes. unclip the fork boots and slide the lowers off.
i think it takes a 5-6 difficulty and makes it a 3-4 as you take much less off the bike.
the seals come out very easy with a seal puller. the retaining clips can be difficult but not a big deal if you have a strong pick or small tipped screwdriver to get behind them and pull the end out enough to grip it with something.
bmwblake is offline   Reply With Quote
Old 05-17-2012, 10:18 PM   #8
camgregus
riding gently now
camgregus's Avatar
Location: on the banks of the mighty mississippi, AR side
Oddometer: 3,006
thank you Blake!
that is especially helpful!!!!
got to get it on the good foot
camgregus is offline   Reply With Quote
Old 05-17-2012, 11:36 PM   #9
supershaft
Oddometer: 9,110
From what I have seen of sliders getting the retaining clips out is a big deal IF you don't want to gouge the sliders. I have seen quite a few buggered pretty good.
Old 05-19-2012, 06:33 AM   #10
GearHeadGrrrl OP
Oddometer: 332
Thanks Everyone!
Doesn't sound beyond my (questionable) abilities, but the GS is blowin' oil out the final drive vent so I elected not to chance the 150 mile ride to the Tech Day. Riding the '84 R65LS instead, may tinker with it a bit...
Old 05-19-2012, 12:09 PM   #11
supershaft
Oddometer: 9,110
Two major issues with those forks. First is the tube chrome fails and flakes off causing the seals to leak on a very regular basis and second is that the teflon bushings most often need replacing when the seals do. It can add up to an expensive repair. It might be a good time to look onto some new fork boots too.
supershaft screwed with this post 05-19-2012 at 12:31 PM
Times are GMT -7.   It's 04:17 PM.
