Old 05-17-2012, 08:43 PM   #1
GodOmelet OP
GodOmelet's Avatar
Oddometer: 78
Eek 1977 R100 /7 Stubborn Wheel Bearings
Never mind. I was hitting the wrong side!
GodOmelet screwed with this post 05-17-2012 at 11:58 PM
GodOmelet is offline   Reply With Quote
Old 05-18-2012, 10:45 AM   #2
groop
So much to ponder
groop's Avatar
Oddometer: 3,285
Best post ever
Because you cannot eat a salad with a spork.
groop is offline   Reply With Quote
Old 05-18-2012, 02:43 PM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,710
I think it's a rear wheel bearing. I find that more heat usually works. Lotsa heat, I like playing with fire.
---Albert Einstein
Old 05-19-2012, 01:24 AM   #4
GodOmelet OP
GodOmelet's Avatar
Oddometer: 78
Doh.
I had followed the whole bit about using the spacer tool made from a length of steel nipple, and so having never done airhead bearings before, I didn't know hub from spacer from inner spacer to outer spacer. Per Ausherman's page, he kept referencing the hub as a cast unit, and to tap from the cast side, so that's what I did. What he failed to make clear was that the hub is actually a machined aluminum part, not a cast aluminum part, so I mistook the hub for the outer spacer. Once I realized exactly which part the hub was, I knew to tap from the drum side. Lot's of heat required, of course, but the stack came out with just a few taps.
I still don't see why you need the spacer to get the bearings out though, or why it's important to take it all out as a unit. I can see it being essential for pre-load and reinserting the bearings, but for getting out the captive side, you could just flip the axle, put it in from the drum side, and heat the hub and tap out the captive bearings, outer races, and spacers without all the messing about with the steel pipe. That's what confused me in the first place! Neophyte/idiot notwithstanding.
Times are GMT -7.   It's 02:31 AM.
