Old 05-18-2012, 12:46 AM   #1
DaBit OP
Oddometer: 345
Luggage racks, aluminium vs steel and tube diameter calculations
OK, so I am considering selling the heavy and wide TT Zega plus rack setup, and make my own luggage rack just like I did with the LC4. Allows me to make a less wide setup with the weight lower and more forward. Soft luggage for trips, small hard cases for daily use.
I would like to keep the rack light. It is used only 10% of the time, and the other 90% of the time it is only dead weight. Keeping it light can be done by using light materials or larger diameter tubing with thinner walls.
Now, the most practical materials for building the rack is either steel, stainless steel and aluminium tubing. I don't want stainless; very expensive and fairly hard to come by.
Steel is always a good option, but again: obtaining large diameter thin walled steel tubing is not easy also, and steel rusts.
And then there is aluminium. Easy to process, easy to obtain tubing in smaller quantities, does not rust, not as expensive as stainless. But, less stiff and strong (especially as-welded), so larger diameter tubing and larger wall thicknesses required.
Questions:
1) Is there a good reason why aluminium is seldom used as luggage-rack material, apart form the 'middle of nowhere repairability problem'?
2) Say I have a construction made of steel pipe with diameter X and wall thickess Y.
Now, if I want to make the same construction with the same stiffness using aluminium tubing with wall thickness 1.5 * Y and I keep the dimensions of the construction the same except for tube diameter, how much larger would I have to chose the the diameter of the tubing?
I don't think alloy choices affect the outcome much, but if you need numbers: regular steel vs extruded 606x-T4 tubing. Steel pipe diameter 16mm x 2mm wall thickness (approx 5/8" x 0.08"), aluminium 3mm wall thickness.
DaBit is offline   Reply With Quote
Old 05-18-2012, 04:45 AM   #2
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,694
Three of the following four statements are true
1.Aluminium fatiges fast when subject to vibration.
2.The end of your bike is a high vibration area.
3.Luggage racks break.
4.Every farmer has a MIG welder in the barn set up with alloy wire and a fresh bottle of argon.
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 05-18-2012, 05:43 AM   #3
DaBit OP
Oddometer: 345
If metal fatigue was such a big problem, then why do they make subframes out of aluminium?
Old 05-18-2012, 05:49 AM   #4
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,343
]1.Aluminium fatiges fast when subject to vibration. Depends on the aluminum alloy
2.The end of your bike is a high vibration area. Usually true
3.Luggage racks break. When they are pieces of shit poorly made with no consideration to load and stress
4.Every farmer has a MIG welder in the barn set up with alloy wire and a fresh bottle of argon. As long as the daughter is hawt who cares?
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is online now   Reply With Quote
Old 05-18-2012, 06:25 AM   #5
KS Jay
Oddometer: 614
Originally Posted by DaBit View Post
Questions:
1. I built my rack from 1/2" X 1/8" wall steel tubing, bought a small tube bender and welded it up with MIG .023 wire with C25 gas. Yes it is heavy but two weeks ago after a fluke dust devil knocked my bike over at work and nothing was broken, just had to straighten out a bark buster and repaint 2" spot on rack, I think the added weight of steel was worth it.
2. Can't help with question two except to suggest repost in Garage-Welding Questions thread or post here:
http://weldingweb.com/
chango
KS Jay is offline   Reply With Quote
Old 05-18-2012, 06:27 AM   #6
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,694
To save weight.
Anything I can think of with an alloy subframe has nothing hanging off it but a rear fender and a tailight and by the time you've owned it 12 months or 500 laps it's just so last season it's time to get a new one.
What did you have in mind for an example of an alloy subframe?
Old 05-18-2012, 06:36 AM   #7
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,694
So three usually true and one doesn't matter?
What grade of aluminium is vibration resistant.
The stuff I pick up at boatbuilders is OK on the plate & section but the tube is only good for edging.
I've made some reliable alloy bits but they are moncoque rather than spaceframe.
Old 05-18-2012, 10:30 AM   #8
nanisx
Oddometer: 105
I want to see where this goes. I want to build a rack for my S10 and have been asking the same question
nanisx is offline   Reply With Quote
Old 05-18-2012, 12:12 PM   #9
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,716
I built my racks from steel for a number of reasons. Cost of the tubing was not an issue but I was having trouble finding a suppler of 1" tubing that was bendable. I tried 3/4" 6063 pipe but that is 1.05" od and my bending die did not like that. A new die is a few hundred.
I also chose steel so I could weld it permanent to my subframe thus keep ing the weight down from lack of bolts etc. prob not an option for most people though.
Steel is just more forgiving, cheaper, stronger and easily available. Yes there is a weight penalty but it's not that much, and the commercial ones are powder coated for cheap in bulk but you also should factor that in.
I didn't know much about alloys and was hesitant to drop a bunch on tubing that would crack when I bent it. I will say if I were to do it from aluminum, I would use 6063 3/4" pipe and buy the proper die. It bends nicely, strong, light etc
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 05-18-2012, 12:46 PM   #10
norexit
Oddometer: 10
Why would you use pipe rather than tube? Wouldn't cutting and welding be stronger than bending Aluminum?
norexit is offline   Reply With Quote
Old 05-18-2012, 06:10 PM   #11
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,093
More engineering than you probably want to hear
The stiffness of a beam is proportional to the Moment of Inertia and the Modulus of Elasticity of the material . For tubing the Moment of Intertia .049 X (D^4 - d^4). http://www.engineeringtoolbox.com/ar...ia-d_1328.html The Modulus of steel is about 3 times the modulus of aluminum http://en.wikipedia.org/wiki/Young%27s_modulus
Also you asked about stiffness rather than strength. The strength is a function of the stress in the material and the yield strength of the material. The stress is a function of the section modulus instead of the moment of inertia. the section modulus is proportional to the moment of intertia divided by the outer diameter, so that will change the relative tubing diameters with strength rather than stiffness as the criteria.
Of course it is never as simple as those equations because of problems of denting tubes and fatigue, and heat treatment, etc.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 05-18-2012, 06:28 PM   #12
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,716
I couldn't find tubing in a bendable alloy locally. I could find 6061 in tubing, but all my local aluminum supplier could get was 6063 in pipe sizes. I was told that 6061 doesn't take to bending very well but that 6063 does.
I bent up some 6063 and it bent very well.
I just checked mcmaster and I guess you can get it in tubing sizes. Good to know for next time, however shipping it gets expensive quick.
As for the cutting and welding vs bending, I much prefer to bend aluminum to make a corner than to cut and weld. I never find the joints to be as strong esp with my TIG welding skills. Plus the aesthetics of a nice bent radius looks so much nicer than a square corner imo.
Nessmuk
Old 05-18-2012, 06:29 PM   #13
GH41
Oddometer: 822
When you run out of things to do try picking the fly shit out of a pile of pepper!! GH
GH41 is offline   Reply With Quote
Old 05-18-2012, 08:33 PM   #14
Andy-Gadget
Any bike can go anywere
Andy-Gadget's Avatar
Oddometer: 1,353
Bugger aluminium, go steel, if a welder is available at all, it will be set up for steel as a minimum.
Build it up out of triangles, and it will be light AND strong.
"If a man empties his purse into his head, no man can take it away from him.
An investment in knowledge always pays the best interest"
Benjamin Franklin.
'95 Sport 1100 Guzzi,'84 Cali 2 Guzzi, '95 Guzzi mille, '84 R65LS, '84 R100, '82 R100RS, '05 DL650, '72 Bultaco Sherpa T 350, '78 Montessa 348, "00 XR650R
Andy-Gadget is offline   Reply With Quote
Old 05-18-2012, 09:40 PM   #15
Ironwood
Friday Harbor, WA
Oddometer: 755
That my welder friend, is truly amazing.
Ironwood is offline   Reply With Quote
Times are GMT -7.   It's 06:36 AM.
