Old 05-17-2012, 05:20 PM   #1
sigpe57 OP
Oddometer: 335
R80ST Ignition Switch repair/replacement
The ignition switch on my 80ST can only turn one click instead of two. Can the ignition switch be repaired by myself or a locksmith?
The OEM BMW ignition part cost $108. Are there after-market ignition switch that can be used to replace the factory unit?
Thank you for the reply,
TT
sigpe57 is offline   Reply With Quote
Old 05-18-2012, 01:45 AM   #2
adventure950
Anglo-Saxon
Oddometer: 520
you can get a used ignition switch quite cheaply http://www.motorworks.co.uk/vlive/Sh...IA_30&spPage=2 or you can use a later series or a gs one (second hand) and solder a bridge on the back of it between two of the wires (i did this on mine) It creates the same wiring connection circuit as the ST ( if you decide to do this let me know and I will look up what I connected as I cant remember off hand) but if you check out the wiring diagram you will see the two different key circuits and they are easily re mapped.
'A tourist sees what he went to see,
a traveller sees what he sees'
adventure950 is offline   Reply With Quote
Old 05-18-2012, 11:46 AM   #3
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 984
A grand opportunity to get the BMW switch used in Europe on these bikes, i.e. a switch with 5 positions
off
park
ignition on
ignition + park light
ignition + park + headlight
It's same swith used on 1974 (only) /6 bikes.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Times are GMT -7.   It's 11:15 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
