Old 05-18-2012, 02:45 PM   #1
2GbeemerLUV OP
Bavarian Motor Pie
2GbeemerLUV's Avatar
Oddometer: 51
Before I do something I regret...
Trying to gain a fuller appreciation for my machine and how it works, I popped off a valve cover to try and see what that adjustment looks like. Following my clymers, I found tdc on the compression stroke and took measurements: 0.01 intake and 0.02 exhaust. Perfect as expected- this machine was resurrected only but a year ago, more accurately, less than 1k miles ago.
Upon further inspection, where the measurements were right, the OT mark on the flywheel was about 1.5 cm north of the middle of the window. "hmmm, ok, advance the flywheel so OT is dead center and remeasure" in this position, there is no free space at all, everything is pressed tight.
What are the indications?
Should the adjustments be redone with OT centered or is it within a tolerance?
Does this tell me the timings off?
Am I crazy? Am I making any sense?
2GbeemerLUV is offline   Reply With Quote
Old 05-18-2012, 03:22 PM   #2
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
Sounds like the bike was timed for full advance rather than static/idle. I had to do the same for my GS so that it would run correctly.
But I set my valves according to centered TDC mark, not adjusted for the altered timing.
Others may chime in differently but my bike is happy according to plug readings and performance.
*EDIT* Never mind, AW and HG picked up on the issue better than I did.
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 screwed with this post 05-18-2012 at 06:24 PM
ignatz72 is offline   Reply With Quote
Old 05-18-2012, 03:26 PM   #3
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
Try turning it over 360 degrees to the "next" OT mark. Then see if they're still tight.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 05-18-2012, 03:39 PM   #4
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,609
Check your pushrods at TDC and see if they turn. That's an easy way to figure out which side is ready to be checked.
hardwaregrrl is online now   Reply With Quote
Old 05-18-2012, 04:26 PM   #5
2GbeemerLUV OP
Bavarian Motor Pie
Oddometer: 51
Are you saying I may have the opposite cylinder on compression instead of the one I'm "adjusting"? So 360 from where I'm at and check for free spinning pushrods? Aka: pushrods will only spin on comp stroke for that particular cylinder?
Old 05-18-2012, 04:57 PM   #6
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,479
Yes, that is what they mean.
Also, I(we) asume your given measures are .10/.20 mm?
otherwise- .004/.008.
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 05-18-2012, 05:28 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,207
The pistons are traveling in and out together. Have both valve covers off. Turn engine over and the side that the intake valve has just closed on is the side you adjust when it reaches OT. Turn another 360* and adjust the other side.
Ozmoses is right. The figures you gave are incorrect. Try not to make this kind of mistake. It can lead to regrettable expense.
---Albert Einstein
Old 05-18-2012, 05:46 PM   #8
2GbeemerLUV OP
Bavarian Motor Pie
Oddometer: 51
Sorry, typo. Correction: 0.1/0.2mm was measured- thank you. (noob)
Also, "opening" is when the intake valve is travelIng into the cylinder, right? So "just closed" is when the intake valve appears the longest? (noob)
Old 05-18-2012, 06:06 PM   #9
zenduddhist
zenduddhist's Avatar
Oddometer: 153
I believe it's the opposite. When the intake valve is travelling away from the cylinder it is open. As it closes, it will be moving towards the cylinder...
Someone verify?
zenduddhist is offline   Reply With Quote
Old 05-18-2012, 07:12 PM   #10
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,207
The valves are normally closed until the cam shaft acts on the valve train and opens any of them. When a valve is closed on a solid lifter , not a hydraulic lifter machine, there is valve lash. This is the space we measure with a feeler gauge between the tip of the valve and the tip of the rocker. The valve is closed when it will not flow and the valve face is on the valve seat. When the valve is open it will allow flow of gas and or liquid. When a valve is open there is no lash, a feeler gauge can not be put between the rocker and the tip of the valve, the valve spring is compressed.
On the 4 stroke engine there are two Top Dead Centers per combustion cycle. Only the one at the end of the compression stroke has both valves closed and both can be set. The intake valve will open with the movement of the intake rocker on the intake stroke, the piston is traveling down and the valve opens to let gas in. Just before the piston starts back up the intake valve closes, The intake valve should be entirely closed on the compression stroke and the exhaust will not open till the end of the power stroke so both valves are closed for most of 2 of the total of 4 strokes of the engine. That is they are closed for half of the time. It actual practice there is a lot of overlap and the valves take time to make all this motion but for the purpose of setting the valves use TDC after the intake valve has closed.
This is assuming that you are turning the engine in the direction it normally travels during operation. Looking at the front of the engine with the cover off the engine should turn clockwise.
---Albert Einstein
Old 05-18-2012, 07:15 PM   #11
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,207
The comment about the valve being closed when the valve is longest was correct, I think. The Buddist guy was wrong.
---Albert Einstein
Old 05-18-2012, 07:16 PM   #12
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,479
Think of the valve as, well, a valve or perhaps a door. Open is open, closed is closed.
Opens into combustion chamber. Closes at (in) the head.
Take a length of coat hanger, or stiff wire & insert into the spark plug hole; as the piston rise in the bore it will push the wire ahead of it. When it stops pushing, this is TDC for that particular cylinder.
Old 05-18-2012, 07:33 PM   #13
bmwloco
bmwloco's Avatar
Oddometer: 1,506
TDC
.6 intake, .8 exhaust.
Rotate and repeat.
Thusfar, it has worked for this monkey. YMMV.
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 05-19-2012, 05:52 AM   #14
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,479
Originally Posted by bmwloco View Post
TDC
.006 intake, .008 exhaust.
Rotate and repeat.
Fixt, as they say. No offense, I just want the OP to have apples to apples.
We know what you mean.
So, OP- what's the deal? Nice day to ride...
Old 05-19-2012, 06:03 AM   #15
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,521
But it HAS to be TDC on the compression stroke, NOT on the exhaust stroke. Any ole TDC won't work...
'73 R60/5 Toaster
Times are GMT -7.   It's 02:42 PM.
