Old 07-03-2012, 10:40 AM   #16
JRWooden
Oddometer: 4,249
Originally Posted by chadams View Post
I haven't run a controller for the last 70,000km... it was cutting out on me around 30,000k, so it got the chop
Dang it ... another good idea of mine shot to hell by an ugly fact................
Old 07-29-2012, 12:58 PM   #17
itsatdm
itsatdm's Avatar
Oddometer: 4,858
Today I stumbled across this: http://www.highflowfuel.com/i-892784...2006-2010.html
Obviously a few unanswered questions, so an email follow up. I suspect our pump is used in other BMW models and this pump is also the one they recommend for the X Challenge. From another site, they are rated at 90LPH and 50 PSI.
Too good to be true?
itsatdm is online now   Reply With Quote
Old 07-29-2012, 08:37 PM   #18
njoytheride
NJOYN' THE JOURNEY
Oddometer: 937
very interesting. will keep up with this thread. love the thought of a spare pump.
njoytheride is offline   Reply With Quote
Old 08-01-2012, 08:05 AM   #19
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
Originally Posted by GB View Post
Are you sure it's the fuel pump? it's more common to have a fuel pump controller issue, than the fuel pump itself. Someone on ADVrider sells a fuel pump controller bypass cable for emergency use (in the Vendors forum).
Here's the link to the cable at burnsmoto.com - http://burnsmoto.com/bmw-fuel-pump-bypass-cable.php
Bucko is offline   Reply With Quote
Old 08-01-2012, 08:20 AM   #20
itsatdm
itsatdm's Avatar
Oddometer: 4,858
I did get a response from my email:
we have one considerable research
into the BMW bike pump fitment but it's possible we got the years off,
however if the bike is EFI, this pump will certainly fit. The volume
of this pump is 90LPH and the pressure is 45psi, however the final
fuel pressure will be determined by the bike's fuel pressure
regualator.
Old 08-20-2012, 12:04 PM   #21
wponder
Wendell
Oddometer: 20
itsatdm -- Thanks for researching this part. I am keeping the part number and business phone number with me.
Regards,
Wendell
wponder is offline   Reply With Quote
Old 08-20-2012, 01:17 PM   #22
itsatdm
itsatdm's Avatar
Oddometer: 4,858
The only thing I can add is I found another site selling the same pump that says the PSI is 50lb. I think that is the same as OEM.
Old 08-20-2012, 01:27 PM   #23
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,331
At that price it is worth giving it a try! Thanks for digging up this little treasure itsatdm!
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is online now   Reply With Quote
Old 11-16-2012, 06:26 PM   #24
rockinrog
rockinrog's Avatar
Oddometer: 2,881
Originally Posted by Bucko View Post
Can someone point me to a video/pics on where/how to do this on the F800gs?
ie where the fuel pump control (FPC) module is located and how to remove it. Video on youtube for the 1200, but looking for something bike specific.
rockinrog is offline   Reply With Quote
Old 11-16-2012, 08:11 PM   #25
njoytheride
NJOYN' THE JOURNEY
Oddometer: 937
The fuel pump assembly on the video looked the same as the 800's located under the seat. Should be able to take off the seat and see the fuel pump controller under the rubber cover.
How does the CANbuss react to the card being gone?
Old 11-16-2012, 08:21 PM   #26
njoytheride
NJOYN' THE JOURNEY
Oddometer: 937
great find on the fuel pump. Would be interesting to hear results of a replaced pump.
My bike was surging like crazy after I filled it up and added cleaner. Made the front end pop up like every 5 seconds or so for two or three minutes and the run for 10 or so minutes and start the surging routine again.
Old 11-22-2012, 09:37 PM   #27
njoytheride
NJOYN' THE JOURNEY
Oddometer: 937
Ordered a replacement fuel pump and looked at the fuel pump control module. Rode the bike and it was cutting out like crazy. Long story short the kick stand is causing the engine to die. This is a seperate problem from the fuel sytem that was cutting out. May be fine after filling up and Techtron added.
Now on to the kick stand issue..
Old 11-22-2012, 11:58 PM   #28
rockinrog
rockinrog's Avatar
Oddometer: 2,881
Does anyone have instructions for removing the fuel pump? Tried bipassing the controller still wouldn't start and gs911 says it is the fuel pump. Taking a look at the link and thinking for 60 bucks it may be worth a try since the bmw unit is 500.
Old 11-23-2012, 02:24 AM   #29
chadams
Oddometer: 209
Here you go
http://www.motorcycleinfo.co.uk/inde...&pageId=428065
Current ride:- 2002 KLX400R
Previous rides:-09 f800gs, 05 z750, 81 z1000j, 84 gpz1100, 98 dr250, 99 dr250, 96 dr350, 93 rf900, 93 nx650, 98 xtz660, 97 dt200r
chadams is online now   Reply With Quote
Old 11-23-2012, 06:49 AM   #30
rockinrog
rockinrog's Avatar
Oddometer: 2,881
Thanks, but that shows removing the controller. I have done that.
I am looking to go a bit further and remove the entire fuel pump hanger dismantle it and replace just the fuel pump motor.
Times are GMT -7.   It's 10:58 PM.
