Old 11-23-2012, 10:19 AM   #31
JRWooden
Oddometer: 4,249
This?
(Moderator, I'm assuming that a limited snip from a manual is allowed under fair-use)....
The BMW dealer has the special tool the "pin wrench" to actually unscrew the top...
I've not tried it myself, but others have successfully used either a block of wood or brass drift to remove it.
Obviously something that is "non-sparking" would be a good choice here....
I think that the OEM fuel line clamps are single use only...
Old 11-23-2012, 10:48 AM   #32
rockinrog
rockinrog's Avatar
Oddometer: 2,883
thx JR.
rockinrog is online now   Reply With Quote
Old 11-23-2012, 07:40 PM   #33
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,339
Just to add my 2 cents..........
I've removed many a pump assy when doing the fuel level sensor replacement under warranty on the 08's and 9's. The clamp on the fuel line, at least on those years, was the one time use crimped on type. It's easy to break the plastic nipple when trying to cut off the clamp (yep, did that). If you remove the two screws on that fitting then you can remove the whole fitting leaving the hose clamp intact. There is just one o ring on there and if you're careful you just re-use it. The fitting isn't sold separately so why risk it. The residual fuel pressure helps pop it out but watch for spray in the eyes .
The retaining ring is torqued to 35NM (I believe) but experience taught me that once it's tight, it's tight so maybe do the stripe thing before loosening it rather than worry about how to tq it. A little vaseline on the gasket helps if its dry on reassembly, also on the fitting o ring. It's an aircraft thing...... Hanger full of guys, all with tubs of vaseline in their toolboxes .
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 11-23-2012, 09:23 PM   #34
JRWooden
Oddometer: 4,249
Excellent tips Reaver - Thank you!
Although I don't really know if I have due cause to worry, and I have only limited experience ...
Using worm gear clamps on high pressure lines always makes me wince a bit ....
Is there real cause for alarm there (assuming I don't use worm gear clamps from Freight Harbor Salvage)?
Old 11-26-2012, 09:08 AM   #35
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,339
Hi JRWoody
The one time use crimp on clamps work well because they're self limiting in clamping pressure. Once the two ends touch they can't be further crimped. Think of the omega symbol Ω . The problem is (was) that when the rubber hose dries up over 10 years, clamping pressure is lost so it may start to leak. Time for new hoses anyway. Also, many left the factory without enough crimp. It was routine to find a leaking hose and just recrimp it without batting an eye or as preventative maintenance. They are tough to cut off though and can cause a scene while words are being spoken in the attempt. Also you lose focus and break the part the hose is attatched to. Oops.
The worm gear clamps are great as long as they are stainless steel and are the thick heavy duty type. Problem there is that they have a hex head and people feel the need to tighten the crap out of them with a ratchet just short of stress failure. The rubber shouldn't ooze out of the slots like a play dough extruder. Much better to have these for maintenance esp when travelling. Who brings different size clamps and the big heavy crimper?????
Old 11-26-2012, 10:49 AM   #36
Bayner
Oddometer: 1,557
Play dough extruder - man that's an excellent description!
Bayner is offline   Reply With Quote
Old 11-26-2012, 04:25 PM   #37
JRWooden
Oddometer: 4,249
+1 on Play-doh extruder
Thanks Reaver!
Old 11-26-2012, 06:29 PM   #38
njoytheride
NJOYN' THE JOURNEY
Oddometer: 937
Ordered one of the replacement pumps from Ebay for $69 bucks. I don't need it until i get the kick stand issue resolved but it came today after ordering Friday. great service. Anybody have any news after installing one ?
njoytheride is offline   Reply With Quote
Old 11-27-2012, 10:07 AM   #39
JRWooden
Oddometer: 4,249
Once piece of news reported on some threads (perhaps including this one ... so sorry if it's a repeat) is that the canister filter on some bikes seems to be clogging to the point of loosing some efficiency thus making the pump work harder.
I'd suggest back-flushing the filter to see if you get much of any gunk out of it ...
The filter is not available as a separate item from BMW, and the mfg. does not appear to sell it in the aftermarket,
so .... well ... it's being discussed on a thread here somewhere
Old 12-17-2012, 08:19 PM   #40
rockinrog
rockinrog's Avatar
Oddometer: 2,883
I decided to let the dealer replace the $490 part:
I plan on rebuilding the old one ...just in case.
Times are GMT -7.   It's 02:02 PM.
