Old 05-22-2012, 09:29 PM   #1
Anywhereness OP
Anywhereness's Avatar
Oddometer: 97
Eek Leaning Wobble in Corners?
This issue is RESOLVED. See here on what I think went down..
Info Preface:
I have a 2001 LC4E with the 18L tank, outfitted with some Kenda dual sport knobbies, and don't have a lot of experience riding enduro/dirt bikes.
The Problem:
When going around corners on asphalt, I often (but not always) get a wobble on the bike that seems to push or pull the bike towards the lean angle. It doesn't feel like steering wheel wobble and seems to happen on tight corners where I lean in quickly.
My first thought is that it's being caused by fuel sloshing around in the tank, because the wobble has that "carrying five gallon bucket of water" feeling to it's oscillation. I can correct it mid turn by fighting against it and smoothing it out.
It seems like it's possible to get the bike leaned over more on tar, but the wobble is enough to affect handling and doesn't inspire the confidence to start pushing the bike further.
Afterthought Side Question:
I'm leaning through corners principally by leaning the bike, bending my knees and getting down low on the bike and trying to keep my torso more perpendicular to the ground, rather than a sport bike lean where my spine shares nearly the same angle as the bike. Does this sound like correct technique to get the most out of cornering?
Cheers!
"Is there any system you can't introduce chaos into?!"
www.anywhereness.org
Anywhereness screwed with this post 06-28-2012 at 08:59 AM
Anywhereness is offline   Reply With Quote
Old 05-22-2012, 11:08 PM   #2
assquatch20
Hoss Cat
assquatch20's Avatar
Oddometer: 1,102
Although fuel slosh could be an issue, I find myself getting wobble when I'm on roads I'm less familiar with and I'm making more corrections to my line without noticing. It's more like a broad weave than a tight wobble, but once I get honed in on that particular turn, it seems to go away.
As for correct lean, I'm still unsure. I've used both and seem to have more control when I start laying my torso down, but I do better "on top" of the bike at lower speeds.
Some things shouldn't be left like you found them.
assquatch20 is offline   Reply With Quote
Old 05-22-2012, 11:50 PM   #3
DAKEZ
DAKEZ's Avatar
Oddometer: 19,719
Try cranking up the pre-load on the rear and see if it helps.
Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ screwed with this post 05-23-2012 at 12:55 PM
DAKEZ is offline   Reply With Quote
Old 05-23-2012, 04:50 AM   #4
Fajita Dave
Fajita Dave's Avatar
Oddometer: 717
How are you holding yourself onto the motorcycle when you make the steering input and from that point on? Are you simply holding onto the handlebars with your lower body relaxed and doing nothing, or are you "locked in" with your lower body and making it part of the chassis instead of something that's shifting around on top of it? Which one do you think the motorcycle would prefer you do?
Knobby tires do give you a very vague feel when cornering especially when you lean it over further where the tread tends to get taller, smaller, and more flexible (depending on the exact tire of course). Pushing the bike under you is ok for dirt but if you're on pavement the best way is to keep yourself inline with the bike or hanging off the inside slightly. That will reduce lean angle a little bit and keep the contact patch on the stronger part of the tire for pavement. If it were a road tire it really wouldn't matter, if you had rubber left there is no reason not to use it.
2008 GSXR 600
2001 CR250R
Fajita Dave is offline   Reply With Quote
Old 05-23-2012, 05:21 AM   #5
outlaws justice
outlaws justice's Avatar
Oddometer: 1,151
Steering input, Sounds more like steering input, you are using both hands to steer the bike and giving different imput with each hand, push with the inside hand then make a little correction with the outside (You are creating what we call a feedback loop). Try to only steer with the insdie hand when making turns and see if that helps.
David
2005 KTM950 Adventure, 2007 BMW K1200GT, 2005 Yamaha Vmax, 2005 Suzuki SV650S, 1991 Honda VFR750, 2004 Honda CRF250X, 2000 Buell Blast................
outlaws justice screwed with this post 05-23-2012 at 12:32 PM
outlaws justice is offline   Reply With Quote
Old 05-23-2012, 05:24 AM   #6
Bill_Z
Dude! chill,...
Bill_Z's Avatar
Oddometer: 460
I have felt what you describe when my tires are low. I've noticed it to be more pronounced at lower speeds and it feels like loose surface dirt, dispite being a clean area. My tires were down 7-10 pounds and they felt squishy in turns.
"The road goes ever on and on, down from the door where it began.
Now far ahead the road has gone and I must follow if I can." J.R.R. Tolkien
DL650AL1
LIMNCS #51
Bill_Z is offline   Reply With Quote
Old 05-23-2012, 05:57 AM   #7
OakLeaf
Oddometer: 9
Throttle control
I've experienced wobble in corners when not being smooth with the throttle. You can't corner as hard with knobbies, and you are probably sensing that. Slow down a little more in the set up for the corner, before you actually start the arc. You can then get on the throttle earlier, pretty much the second you actually start the arc. Keep a very consistent throttle, or SLOWLY roll on the gas through the turn. The wobble, for me, has come when accidentally rolling off the throttle.
Steering input, as said above is also a very likely culprit. Smooth throttle and smooth steering are almost the same issue.
Cheers,
-Carl
OakLeaf is offline   Reply With Quote
Old 05-23-2012, 06:09 AM   #8
Rekd
Bitter Clinger
Rekd's Avatar
Oddometer: 93
Check your air pressure.
Rekd is offline   Reply With Quote
Old 05-23-2012, 06:40 AM   #9
ADW
'tard bike restos
ADW's Avatar
Oddometer: 557
Which Kendas are you running?
Originally Posted by Epoch of Entropy View Post
Info Preface:
The Problem:
Cheers!
What Kenda DS knobbies are you running? I switched from the Kenda K270 in the rear to a Shinko 244 because the very outboard set of knobs on the Kenda are very small and "squirmy". The bike goes from "fine...fine...fine...OH S&%^!" as you continue to lean over and get to those squirrely, wiggly knobs on the outside. The Shinko has much larger/better supported knobs on the outer edge.
Kenda K270
Shinko 244
08 KLR, 06 KLR w/Sputnik sidecar, 09 WR250R, 72 CB350F
ADW is online now   Reply With Quote
Old 05-23-2012, 07:48 AM   #10
DAKEZ
DAKEZ's Avatar
Oddometer: 19,719
Kenda K270/Shinko 244
I concure. The Shinko is much more predictable in the tight stuff.
The Shinko actually lets you know it is going to wash out the front and gives you the option of gathering it back up. The Kenda just puts you on your face.
Bib
Old 05-23-2012, 08:00 AM   #11
geg
Canadian living in exile
geg's Avatar
Oddometer: 6,530
Originally Posted by outlaws justice View Post
Steering imput, Sounds more like steering imput, you are using both hands to steer the bike and giving different imput with each hand, push with the inside hand then make a little correction with the outside (You are creating what we call a feedback loop). Try to only steer with the insdie hand when making turns and see if that helps.
WTF is "IMPUT"?
Greg
Europe 2013 Europe 2012 Europe 2011 England 2010 Gaspe PQ 2008 Nova Scotia 2007
Try to see the world beyond your front door.
geg is online now   Reply With Quote
Old 05-23-2012, 08:05 AM   #12
tkent02
Oddometer: 2,460
Any chance your swing arm bearings are loose?
I restore old bikes, when the swing arm bearings get too worn and loose the bikes wobble like you have described.
tkent02 is offline   Reply With Quote
Old 05-23-2012, 10:04 AM   #13
Kommando
Kommando's Avatar
Oddometer: 7,378
It sounds to me like the OP isn't purposefully countersteering. He's trying to lean the bike, rather than pushing on the inside bar to lean it. Smooth steering inputs at the bars can smooth things out if tire pressure, tread, and other factors are ruled out.
Kommando is offline   Reply With Quote
Old 05-23-2012, 10:22 AM   #14
Meromorph
Expat Brit in TN.
Meromorph's Avatar
Oddometer: 141
Check:
1. swing arm bearings
2. headstock bearings
3. tire pressure (front and rear)
4. front wheel kinked.
5. steering technique. (you can only steer by countersteering. Whatever else you think you're doing, is only achieving indirect countersteering. The simple direct and reliable way to countersteer is to press forward on the left grip to turn left, press forward on the right grip to turn right.)
Your 'leaning' technique is incorrect, stay in line with your bike unless you know, and understand, the times when you can do better by leaning one way or the other. Staying in line is always right.
Meromorph is offline   Reply With Quote
Old 05-23-2012, 11:57 AM   #15
Bill_Z
Dude! chill,...
Bill_Z's Avatar
Oddometer: 460
Originally Posted by geg View Post
WTF is "IMPUT"?
hahaha
DL650AL1
LIMNCS #51
Times are GMT -7.   It's 09:07 AM.
