Old 05-24-2012, 02:09 PM   #1
ssregal39 OP
ssregal39's Avatar
Oddometer: 207
compression test ktm 300 2001
i have forgoten have many times to kick a 2 stroke for compression test.
anyway, on a cold motor, i kicked 6 good times and got 175. seems ok to me.
what do the other 2 smokers think?
i wanna ride
ssregal39 is offline   Reply With Quote
Old 05-24-2012, 03:11 PM   #2
Reino
Reino's Avatar
Oddometer: 212
I am assuming that is psi, but according to my limited knowledge base i would say that is reasonable.
A 300 should get around 200 - 210 psi on a fresh top end. Minimum acceptable compression is generally about 150 psi.
http://www.dirtbikeworld.net/forum/a...p/t-40434.html (12th post from top)
proper pressure after 5 kicks should be in the 175-190 psi range on fresh top end for that bike.
http://answers.yahoo.com/question/in...0062714AAfJjoe
A 300 will run with 120 but not well. Start saving for a top end. If you let it go too long you will need to replate the cylinder.
http://boardreader.com/thread/05_300..._d89Xl3gb.html
what model is your bike? (sx, xc, xc-w or an exc)
And remember Google is your friend.
Reino is offline   Reply With Quote
Old 05-25-2012, 09:52 PM   #3
ssregal39 OP
ssregal39's Avatar
Oddometer: 207
thanks. it's an exc. the motor should be fine for a while i think.
now i just need to sort the jetting.
i wanna ride
Old 05-26-2012, 01:21 AM   #4
Reino
Reino's Avatar
Oddometer: 212
Same here on the jetting, good luck with the bike i hope you get every thing sorted.
Old 12-23-2014, 01:23 PM   #5
w33b8t1
w33b8t1's Avatar
Oddometer: 310
Oops responded to the wrong thread.
http://ridefourcorners.com
w33b8t1 screwed with this post 12-23-2014 at 01:50 PM
w33b8t1 is offline   Reply With Quote
Times are GMT -7.   It's 08:36 PM.
