Old 08-02-2012, 10:49 AM   #61
Reino OP
Reino's Avatar
Oddometer: 212
This is the closest thing to an electronic carb found on early gm's.
Reino is offline   Reply With Quote
Old 08-03-2012, 12:26 AM   #62
Twin-shocker
Oddometer: 1,673
Originally Posted by Reino View Post
I don't know of any tuning method that can adjust its self to temp and atmospheric changes.
Unless you are one day riding at sea level and the next at 8000ft above, there is no real need for major changes to a properly set up bike. However its worth bearing in mind manufacturers spend an awful lot of time and money developing various OE induction and ignition parts, so dont be too sure you will easily be able to do better.
Old 08-03-2012, 12:44 AM   #63
Reino OP
Reino's Avatar
Oddometer: 212
The thing is the engineer may develop a system very close to perfection, but it is untimely the accountant that tells him what he can and can not use.
Reino screwed with this post 08-03-2012 at 03:10 AM
Old 08-03-2012, 04:24 AM   #64
Reino OP
Reino's Avatar
Oddometer: 212
I have also looked into developing an electronic carb with ecu controlled venturis. basically it would function as a normal efi system just without a pump. But that route is even more expensive than what i am planing.
I like that intelajet device if it adjusts from 0 to 100% throttle basically giving you a carb that mimics efi but i would have to buy a reprogramming ecu as well.
Old 08-05-2012, 12:51 AM   #65
Twin-shocker
Oddometer: 1,673
As you seem intent on spending $4-5k on replacing your carb and stock ignition systems, then I would be very interested to know in what areas you feel the stock parts are lacking?
Old 08-05-2012, 02:53 AM   #66
Reino OP
Reino's Avatar
Oddometer: 212
i could improve on throttle resonce alone with an 3d ignition map not to mention having perfect jetting all the time and more low down torque without sacrificing high rpm power.
Old 08-05-2012, 03:35 AM   #67
Twin-shocker
Oddometer: 1,673
I wonder have you ridden EFI 2T modified bikes in the past, or are you relying on advertising blurb (95% nonsense mostly) and posts on forums which suggest your $4-5k is going to be well spent?
Old 08-05-2012, 06:55 AM   #68
Reino OP
Reino's Avatar
Oddometer: 212
That is the conclusion i came up with on my own and NO i have not riden a efi 2t, very few people have. If jou can point me to a system that works just as good at maintaing perfect jetting all the time, fine i will drop the efi project.
But i doudt that you can, because there is no such system. I almost shat my self when low buget mentiond intelajet, because it would mean i can drop efi. But if does nothing in the first 1/3 throttle.
So i chalange you, show me a alternative.
Old 08-05-2012, 07:23 AM   #69
Twin-shocker
Oddometer: 1,673
Unless you are riding your bike from sea level to elevations above 3000ft pretty much every day, is there a real need to spend at least $4-5K to be able to do this without needing to spend maybe 30 minutes changing jets?
Old 08-05-2012, 07:58 AM   #70
Reino OP
Reino's Avatar
Oddometer: 212
and what about temp changes and humidity, you are missing the point. I have tried to explain it.
And i am not going to spend 5000usd on my dyno time. I know the dyno owner.
I also see a trend that you think that the manufactures are the be all and the end all of bike technology. Than why do you send your suspension to the local suspension shop for upgrades, why do you send your engine to a tuner, why would you send your carb for oval boring.
Tm(developed not sold), ossa (enduro bike), many snowmobile's and jetskis use efi.
What is it that you want to know?
Do you want my motovation for doing this. If that is the question, i have answerd this before.
Old 08-05-2012, 09:50 AM   #71
Twin-shocker
Oddometer: 1,673
Does your dyno friend have specific experience of setting up home built 2T EFI systems? If not can he afford to spend many hours/days working for you at a reduced rate?
In terms of changes related to atmo and temperature, these are generally simply a matter of adjusting the pilot air circuit, which at most take a few minutes.
The only 2T EFI bike currently on the market seems to be the Ossa trials machine, and to be honest it doesnt run that much better than a bike with properly set up carb, and I would suggest you have a ride on one before committing a fair amount of money and time to a project which ultimately might disappoint you.
Old 08-05-2012, 10:24 AM   #72
Reino OP
Reino's Avatar
Oddometer: 212
so once again, suggest me an alternative system that does what i want it to do.
Old 08-05-2012, 12:58 PM   #73
Twin-shocker
Oddometer: 1,673
What I would suggest to you before you go ahead and spend quite a large sum of money, is to arrange to have a ride on an EFI Ossa trials, and compare it back to back with a properly set up bike fitted with a carb, which will give you a very good idea as to whether spending your money is going to be worth it or not.
Old 08-05-2012, 01:04 PM   #74
Reino OP
Reino's Avatar
Oddometer: 212
There are no ossa bikes in my country. No body rides trail bikes in my country.
Old 08-05-2012, 01:11 PM   #75
Reino OP
Reino's Avatar
Oddometer: 212
I'll tell you what i will try things like the intelajet and other products until i have my Beng degree and if i still want to do efi 2t I will be able to comfortably afford it.
Times are GMT -7.   It's 06:05 PM.
