05-30-2012, 01:32 PM
#16 |
Oddometer: 12
Emmbeedee, I would welcome a SAE or SAE like connection directly to the device.
05-30-2012, 01:40 PM
#17 | |
Procrastinators
Oddometer: 5,822
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
05-30-2012, 02:02 PM
#18 |
Oddometer: 237
Garmin 660/665
We upgraded from a 550, with the thoughts of utilizing the Powerlet Handle Bar Power mount (which we used with the 550) and a short Powerlet cable to the Power outlet mounted on the bars.
Unfortunately as the OP has pointed out, it does not work. The Garmin Bundle of Snakes Motorcycle mount is too busy and has way more connections than we want or need. And yes the OP is correct in that there is no Quick Disconnect for the 660/665 (like there was/is for the 550). Again the OP in our opininon is correct when he says the lack of engineering on the part of Garmin has made this unit less user friendly. And as for the "crack" about doing advanced research, how would you suggest that be done? You buy from reputable vendors and expect a quality well designed piece. Especially for something that is specifically esigned for use on a motorcycle. Enjoy
Different in Every Way |
05-30-2012, 03:35 PM
#19 |
Oddometer: 12
The OP says thank you....
05-30-2012, 04:38 PM
#20 | |
Road Captain
Oddometer: 9,322
![]() Enjoy!
Pain in the Butte Ranch Durango, Colorado - Calculated risk or forbidden fruit? FatChance screwed with this post 05-30-2012 at 04:45 PM |
05-30-2012, 05:46 PM
#21 | |
Procrastinators
Oddometer: 5,822
We volunteer to help people make decisions, preferably before they make what they might consider in retrospect a bad purchase. We're hardly likely to agree that any piece of equipment is badly designed simply because it doesn't meet someone's expectations.
06-07-2012, 11:05 AM
#22 | |
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 173
To the OP - Don't really see this as a Garmin issue, but a lack of research to start with. A very simple check would be to have taken a look at the manual before dropping a grand. The mount remains installed on the bike - USB does not make sense. Want to talk standards, just check the different specs on USB alone. However, a bike battery and regulated power is 12V DC. Plain and simple. As for not wanting all the wires - you can buy a modified mount from various sources that only have power, or easily modify it yourself. On the other hand, best of luck finding an alternative with all the same functionality, that does connect to a USB.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen) 2008 Yamaha YZ450, 2002 Yamaha YZ426 www.bruneibikers.com www.airborneriders.com |
06-18-2012, 01:25 PM
#23 | |
Oddometer: 1
Hello afulldeck, For Item #1 above, have you tried to use using a Mini USB adapter from powerlet (www.powerlet.com) part number PPC-024? I had a very similar issue with one of my Garmins... This device works well and is cheap It also allows you to charge your Garmin when plugged into a PC. I hope this helps you out on at least one of your problems. Jim |
06-18-2012, 01:41 PM
#24 |
Oddometer: 3,325
There will never be a standard on GPS connectors. All you have to do is look at the absurd variety of batteries out there to understand that. The manufacturers don't want a standard.
If I wasn't here, I'd be somewhere else |
06-23-2012, 09:43 PM
#25 | |
I grow everywhere
Oddometer: 28
If you aren't looking for what you are buying in exact specs to what you want, you will never have an excuse in mind. |
06-24-2012, 12:52 AM
#26 |
Oddometer: 2,214
i dont own a gps but i cant imagine NOT having some sort of mount or cradle to mount it near your normal feild of view whilst riding the bike.Sitting in the top of a tank bag would not be my idea of user freindly
aka BMWST?
06-26-2012, 04:53 PM
#27 |
Oddometer: 219
I got a little lost in all the back-and-forth over the OP's original post. But if the crux of the problem is the power cable connection maybe this will help [altho it's for a 660, IIRC it also works for the 665].
http://www.touratech-usa.com/Store/3...ick-Disconnect
It is better to have ridden and crashed, than to have never ridden at all. |
07-02-2012, 08:31 PM
#28 |
IBA #49986
Oddometer: 211
I have the same issue, but knew about it before purchase.
I too have weatherproof USB connectors on my bike for phone and GPS. Much cleaner than SAE or cigarette or powerlette, IMHO. But, I knew the USB would not work for the 665 and planned on and will make a connection to the power on the bike directly. NBD in my case, I will just tap into the wires for one of my USB adapters. Will take 5 minutes. But I do hear him about the giant jumble of wires. Just ugly. |
07-07-2012, 10:46 PM
#29 |
Oddometer: 759
If you try to use a Scala G4 with that 665 for music and a intercom with pillion or riding buddy, you'll really have something to bitch about. There is a firmware incompatibility between the two.
R1200RT (R1100RT gone) KLR650 Don't be the guy who needs to pee on the fence to figure out that it's electrified. |
07-13-2012, 06:19 AM
#30 |
Truffle Rustler
Oddometer: 1,944
Oh man, maybe the OP should have asked for advice on his planned install before spending $1000 on stuff he was doomed to not like. This cannot end well. Money is not the answer amigo.
Normal is just a setting on the dryer. Armageddon was yesterday - Today we have a serious problem. 2009 R1200GS Adventure 2008 K1200GT |
