Old 05-31-2012, 03:50 PM   #1
Rokoneer OP
Oddometer: 539
Right side drive two strokes
Contemplating a two stroke engine transplant in to former four stroke machine that has a right side countershaft and thus right side chain drive.
Looking for suitable 2T motorcycle engines, either singles or multiple cylinder, that are right side drive. Trying to keep cost reasonable so anything exotic or current may not be the best option. Been looking at air cooled vintage stuff but older liquid cooled stuff could be a consideration as well.
Rotax/Bombardier, Husqvarna and Ossa are the few I know off hand. Pleas enlighten me to any that you are aware of.
Muchos GrassyAss!
Rokoneer is offline   Reply With Quote
Old 05-31-2012, 05:49 PM   #2
ppe172
Oddometer: 169
1980+ it175, it200.
ppe172 is offline   Reply With Quote
Old 05-31-2012, 06:22 PM   #3
Rokoneer OP
Oddometer: 539
Originally Posted by ppe172 View Post
1980+ it175, it200.
Interesting! I wasn't aware that any of the Japanese manufacturers had done a right side drive. Thanks for that.
Ideally I'd like a bit more displacement than a 175 or 200, but beggers can't be choosers.
Old 05-31-2012, 06:45 PM   #4
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,578
Ummm couldn't you just flip the wheel around and remake spacers and brake stays? Or respoke the hub to flip it?
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 05-31-2012, 07:58 PM   #5
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,261
can-am 175/250 right side drive. it200 would be my choice, there's alot of power to be unlocked in those motors, and parts are cheap (aside from cylinders/heads....) ... the can-am 250 would be great - it's not as wide as other rotary motors - and they're built pretty stout..
as for flipping to left side, if it's drum brakes, it can be tough - figuring out brake lever to rod crossover or converting to cable rear (easier)....
i'm trying to jam a mx175 motor into a puch 175 frame - no mounts match up, and figuring pipe will be a chore.
current bikes
stainlesscycle is online now   Reply With Quote
Old 05-31-2012, 08:09 PM   #6
jar944
jar944's Avatar
Oddometer: 666
ktm 440/500/550
jar944 is offline   Reply With Quote
Old 05-31-2012, 08:57 PM   #7
Abdelhub
Blanco Trasho
Abdelhub's Avatar
Oddometer: 727
montesas are right side...
Mike
the most valuable bike i own hasn't run in 20 years...
http://www.youtube.com/abdelhub
Abdelhub is offline   Reply With Quote
Old 06-01-2012, 04:58 AM   #8
Rokoneer OP
Oddometer: 539
Or just flip the swing arm over and you're all good, right!
Simple and inexpensive (ha!) are hoped for with this project.
You can't strip a perfectly good Can-Am Rat, you just can't!
Any multi cylinder right side drive 2t's anyone is aware of?
Rokoneer screwed with this post 06-01-2012 at 05:04 AM
Old 06-01-2012, 05:06 AM   #9
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,297
Add early 1980's CR250 Honda engines to that,right hand chain,left side kick.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 06-01-2012, 08:09 AM   #10
mtothef
Oddometer: 397
did somebody say displacement?
honda cr480. last of the air-cooled dinosaurs.
mtothef is offline   Reply With Quote
Old 06-04-2012, 04:16 PM   #11
Neil E.
Neil E.'s Avatar
Oddometer: 298
Let me guess ........ Husaberg frame?
Consider the exhaust port location (height/angle) so you are sure the exhaust will clear the frame.
Neil E. is online now   Reply With Quote
Old 06-05-2012, 05:51 AM   #12
Rokoneer OP
Oddometer: 539
Just imagine a 'real' Swedish built Husaberg frame with a 430 or 500 Husqvarna 2T engine swapped in? Huge power, very light due to losing the liquid cooling components, simple mechanics, reliable electrics.....
It'd be the bike Husaberg should have built!
Old 06-05-2012, 11:37 AM   #13
Neil E.
Neil E.'s Avatar
Oddometer: 298
I had a Husaberg and wanted to do a 2T conversion. I looked at everything from ultralight motors to rotary engines for go-karts. The tough part was how to marry anything to the Husaberg gearbox to keep the nice wide ratios. A 2T bike engine is a better choice, but 4T frames run close to the front wheel and don't leave much room for a pipe.
Old 06-06-2012, 11:04 AM   #14
taosgsr
taosgsr's Avatar
Oddometer: 442
Husqvarna
WR 250 and 300 Right side drive still to this day.
See ya at the Pub!!
"don't I have a real dirtbike to do this on?????"
taosgsr is offline   Reply With Quote
Old 10-12-2012, 04:01 PM   #15
THE PIG
Vtech
Oddometer: 23
Right side.
About Jawa 350.
" Insanity; doing the same thing over and over and expecting different results".
Albert Einstein.
THE PIG is offline   Reply With Quote
Times are GMT -7.   It's 02:18 PM.
