Old 05-31-2012, 11:03 PM   #1
drrider1 OP
just running amuck
drrider1's Avatar
Oddometer: 360
ural hotrod
someone please talk me outta cutting up 2 good motorcycles to put a bmw powertrain in an old ural tourist
Every life needs 9 cats.
11R1200rt 96 Ural Tourist (red peril)
02 800 vulcan classic(wife's)gone but not forgotten
drrider1 is offline   Reply With Quote
Old 05-31-2012, 11:37 PM   #2
NitroMax
NitroMax's Avatar
Oddometer: 579
drrider: don't cut up 2 good motrocycles to put a BMW powertrain in an old ural tourist !!
Now go to your garage, armed with hacksaw and camera and get to work !!!
1300cc 217Nm/207Hp NOS-injected VMax (1985)
500 cc 1950 BSA chopper (1983)
750 cc CB750 chopper ( 1990)
1200 cc Z1000 dragbike (1976)
300 cc MZ transporthack (1989) winterhack
900 cc BMW R 90/6 hack ( 1976) summerhack
750 cc BMW K 75 RT ( 1993 ) daily driver
Age is an issue of mind over matter. If you don't mind, it doesn't matter ( Mark Twain )
NitroMax is offline   Reply With Quote
Old 06-01-2012, 12:27 AM   #3
iantochips
Oddometer: 251
Thumb
No. Do it. Motorcycling has a long and honourable history of specials.
iantochips is offline   Reply With Quote
Old 06-01-2012, 12:33 AM   #4
Billtr96sn
Flange Furtler
Oddometer: 368
Do it, or better still, just throw the Ural away.
Billtr96sn is offline   Reply With Quote
Old 06-01-2012, 01:43 AM   #5
Wolfgang55
Wolfgang55's Avatar
Oddometer: 2,962
pix help w/ suggestion
Ahhhhh, got any pix of just what this is going to look like?
Wolfgang55 is offline   Reply With Quote
Old 06-01-2012, 02:09 AM   #6
iantochips
Oddometer: 251
Strike a blow against convention, wedge two Ural engines in the BMW. You may need a spare........
Old 06-01-2012, 07:13 AM   #7
Ivan Rider
Ivan Rider's Avatar
Oddometer: 506
Send a message via Yahoo to Ivan Rider
You wouldn't be the first. I had a '98 Ural with an '83 BMW R100RT engine, trans, final drive, disc brakes, wheels and lower frame in it. It was an awesome rig that would cruize at 85 mph all day.
'99 Ural Patrol '02 Ural Sahara BC
'03 BMW CLC/Ural
'06 Honda Ruckus /Sidecar
'10 Ural ST Solo
http://www.flickr.com/photos/ivanrider/
Ivan Rider screwed with this post 06-01-2012 at 07:15 AM Reason: Double photo problem
Ivan Rider is offline   Reply With Quote
Old 06-01-2012, 08:37 AM   #8
4PawsHacienda
4PawsHacienda's Avatar
Location: Climax NC or Fancy Gap VA (milemarker 199 BRP)
Oddometer: 305
Are you also going to put the Ural bits and pieces removed into the BMW?
That I'd love to see! If it runs just might be a first.
4PawsHacienda is offline   Reply With Quote
Old 06-01-2012, 10:13 AM   #9
ruckuschick
Oddometer: 61
I say DO IT! Course I don't have to dot he work or hack teh 2 donor bikes.
ruckuschick is offline   Reply With Quote
Old 06-01-2012, 10:19 AM   #10
JLeather
Bike Butcherer
JLeather's Avatar
Oddometer: 273
At that point why wouldn't you have just put the sidecar and gas tank from the ural on the bmw and called it a day?
JLeather is online now   Reply With Quote
Old 06-01-2012, 10:29 AM   #11
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 2,934
Yeah, don't forget to install the BMW brakes to go along with the new top speed.
High Country Herb is online now   Reply With Quote
Old 06-01-2012, 10:31 AM   #12
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Location: Bristol Hills in the Fingerlakes region of NY
Oddometer: 2,268
I know that guy! He probably stole the BMW and had to hide it inside the Ural.
Just kidding, Dennis is one hell of a guy and has some unique stuff, including his ATGATT.
Hi Dennis, Say hello to Becky and Lucy for me. Wish I could be there on the ocean BSing with you today,
Tom
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
madeouttaglass is online now   Reply With Quote
Old 06-01-2012, 10:45 AM   #13
kailuasurfer
Dreamer
kailuasurfer's Avatar
Oddometer: 284
Send a message via Skype™ to kailuasurfer
Sooo, which motor?
So, which BMW motor is a "best fit" for a Ural? I have a '98 and wouldn't mind doing something like this also.
kailuasurfer is offline   Reply With Quote
Old 06-01-2012, 11:56 AM   #14
drrider1 OP
just running amuck
drrider1's Avatar
Oddometer: 360
this is exactly what i have in mind....thanks.....i want to keep my leading link tho
Old 06-03-2012, 01:36 AM   #15
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,441
Here's a different idea.
Get yourself a French BFG motorcycle with its 1 299 cm3 four cylinder engine.
TECHNICAL SPECIFICATIONS AND DIMENSIONS
Frame type: Tube, engine is part of frame
Front suspension: Telescopic fork
Rear suspension: Swing arm, 2 shock absorbers
Wheelbase: 1 610 mm
Seat height: 785 mm
Brakes front: 2 x 300 mm discs
Brake rear: 1 x 260 mm disc
Performance
Max speed: 197 km/h (123 mph)
Acceleration: 0 - 1000 m : 25 sec
Fuel consumption: 5 litres/100 km
Engine
Type: Citroën GSA type, 1 299cm3 capacity, 4 horizontally opposed air cooled cylinders
Power output: 70 bhp (51 kW) at 5 500 rpm
Maximum torque: 100 Nm (75 lbs.ft) at 3 250 rpm
Ignition: Electronic
Alternator: 480 W
Battery: 18 Ah, 12 V
Dry weight: 290 kg
Max weight: 490 kg
Fuel tank capacity: 22 litres
Engine oil capacity: 4 litres
Gearbox oil capacity: 4 litres
Then attach whatever sidecar you like to that!
As a solo- standing Kilometer in 25 sec. Roughly 1.6 kilometers in 1 mile. So much more roughly that's near Three Quarters of a Mile.
'77 BMW R100RS with Ural chair
'08 Suzuki AN650A Burgman (and trailer)
vortexau is offline   Reply With Quote
Times are GMT -7.   It's 10:32 AM.
