Old 06-03-2012, 01:58 PM   #16
hansi
Teurer Abenteurer
hansi's Avatar
Oddometer: 310
hansi is offline   Reply With Quote
Old 06-03-2012, 11:49 PM   #17
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Originally Posted by ADAMRRP View Post
We are soon to be developing our fairing kits and screens to take twin HID Lights and we still offer a discount if the headlight is not required I often price up kits for people that want to take out odd bits.
Interesting - any news on release date?
modeselector is offline   Reply With Quote
Old 06-04-2012, 04:20 AM   #18
ADAMRRP OP
ADAMRRP's Avatar
Oddometer: 12
Originally Posted by thorinoakenshield View Post
is the stock plastic rad screen supposed to fit over the RR rad protector?
mine does not go over and I also need a large washer with the supplied nut to secure the screen. the hole in the screen that the bolt goes through is too large for the supplied hardware.
zip ties work fine, though.
The rad protector is not meant to be used with the stock screen, our rad screen is designed to fit right over it it.
ADAMRRP is offline   Reply With Quote
Old 06-04-2012, 04:21 AM   #19
ADAMRRP OP
ADAMRRP's Avatar
Oddometer: 12
Not yet i'm afraid ! I will be sure to give the heads up when we have an idea if this thread is still alive !
Old 06-04-2012, 04:23 AM   #20
ADAMRRP OP
ADAMRRP's Avatar
Oddometer: 12
Originally Posted by Night Crawler View Post
I am wondering if the Rad Protector (RRP 150) protects this mounting tab or reinforces it? I stole the picture from the Code Orange thread.
Our protector does re-enforce the tags, it take as much stress back towards the engine bolts instead of loading up the radiator.
Old 06-04-2012, 11:12 AM   #21
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 190
Adam, can you confirm your statement? The product info in the store states "This laser-cut 2mm stainless-steel Radiator Protector is designed to protect the radiator,but also has our unique design of attaching the OEM radiator screen and side panel screws to it,therefore removing the possibility of any damage being caused to the radiator in the event of a fall,or overtightening the M6 rad screen screws that fix into the top of the OEM radiator,resulting in a leak."
Looking at adding this, but didn't have your screen factored in.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 06-04-2012, 11:38 AM   #22
dunefreak
dunefreak's Avatar
Oddometer: 93
Would it be safe to say that if you install a set of the front RR tanks you won't need any sort of radiator protectors for crash protection since the tanks pretty much cover them in the even of a fall-over or crash?
2012 KTM 690 Enduro R
dunefreak is offline   Reply With Quote
Old 06-04-2012, 12:41 PM   #23
Biped
NooB Again
Biped's Avatar
Oddometer: 352
Not true, I have crashed hard enough with the RR tanks that the radiator sprang a leak, tanks did not get damaged though.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 06-04-2012, 05:25 PM   #24
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,045
Scott's mount
Can your Billet Bar Risers be mounted in either bar mount location (fore or aft) on the 690's stock triple clamp using the same arm on a scott's stabilizer?
The Letter J is offline   Reply With Quote
Old 06-05-2012, 04:02 PM   #25
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,702
Can you confirm if your rad guard (not screen) fits the 2012 690 ER? Also looking for confirmation that it works, or not with the OEM screen or if a RR screen is required. Me and another 690 owner are looking to order rad guards, his would be a 2011, same question as asked by blakrj, does the OEM screen fit on the 2011 with the RR rad guards?
Cheers,
CanadianX is online now   Reply With Quote
Old 06-05-2012, 04:30 PM   #26
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 451
Cheers,
I got my rad guard to fit on my 2012 690.
lots of moving pieces, everything fit, but just barely. i was lucky to get the plastics back on. seems stout, though.
thorinoakenshield is offline   Reply With Quote
Old 06-05-2012, 04:55 PM   #27
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,702
Thanks Thorin! Was it an easy fit or did it take some patience? Nice to know it fits with the OEM screen. Now to find out if it fits a 2011 and maybe I can empty out the wallet for some RR stuff to be shipped to Canada.
Old 06-05-2012, 05:50 PM   #28
thorinoakenshield
ya mo be there
Oddometer: 451
Wait I think we are talking past each other.
The RR protector (frame that goes around the radiator) does not fit the oem screen. Even though they DO advertise this.
I had to zip tie my plastic oem screen on to the protector.
Seems ok, though. Check out my earlier post with the pic.
The RR rad protector has the benefit of working with the RR gas tanks.
The fit wasnt bad, just be sure to keep everything loose. I had to force the plastic fairing on, but it's fine. I popped the rubber mounts off because they are not needed anymore.
Old 06-06-2012, 04:18 AM   #29
ADAMRRP OP
ADAMRRP's Avatar
Oddometer: 12
Hi guys, in regards to this OEM screen on the rad protector I will have this checked out as to why is is advertised as fitting . Im not in today due to a nasty bug over the weekend but will check it out soon!
Old 06-10-2012, 06:51 AM   #30
ADAMRRP OP
ADAMRRP's Avatar
Oddometer: 12
Hi guys I brought up the OEM screen on the Rad Protectors at work, I am sorry to say it does not I will have the website amended when we get back in.
Times are GMT -7.   It's 03:41 AM.
