Old 06-10-2012, 02:59 PM   #31
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 316
Originally Posted by The Letter J View Post
Can your Billet Bar Risers be mounted in either bar mount location (fore or aft) on the 690's stock triple clamp using the same arm on a scott's stabilizer?
The Letter J is offline   Reply With Quote
Old 06-10-2012, 05:43 PM   #32
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 398
Originally Posted by ADAMRRP View Post
Hi guys I brought up the OEM screen on the Rad Protectors at work, I am sorry to say it does not I will have the website amended when we get back in.
well like i said, zip ties work just fine........
ktm 450xcw, ktm 690 enduro r, kawasaki versys 650
"In Europe we ride about eight-tenths. If we really have to, we might ride nine-tenths. The crazy ones ride ten-tenths—but not for very long. In America, they seem to ride eleven-tenths all the time."-- Phil Read
thorinoakenshield is offline   Reply With Quote
Old 06-11-2012, 12:49 AM   #33
B2
"Racin Mason"# 4
B2's Avatar
Oddometer: 1,392
Ive just bought a load of gear from RR includind the soft luggage rack for my ktm 690 R im concerned it hasnt got the rear bar that goes behind number plate bracing the two sides will i have to get someone to make a bar up for me or doesnt ti need one -will be carrying the rotopax water and fuel systems with camping gear and and misc so will have some weight involved. thanks
B2 is offline   Reply With Quote
Old 06-13-2012, 01:38 AM   #34
ADAMRRP OP
ADAMRRP's Avatar
Oddometer: 12
B2,
I understand your concern completely, we have tested the racks with a substantial amount of weight but if you do make this mod let us know how it goes!
ADAMRRP is offline   Reply With Quote
Old 06-13-2012, 02:54 PM   #35
ktmmitch
Oddometer: 192
Yes,We supply a special arm to fit the Scotts Damper with our Steering Damper Fitting Kit,this then works with our Billet Bar Riser,in both hole positions.
ktmmitch is offline   Reply With Quote
Old 06-17-2012, 03:44 AM   #36
CanadianX
Oh!? That is deep.
Oddometer: 756
Any more news on fitting your tank kit on the 2012 690?
CanadianX is offline   Reply With Quote
Old 06-21-2012, 02:22 PM   #37
Evil Invader
Evil Invader's Avatar
Oddometer: 593
ADAMRRP Please check your inbox, don´t think my mail work properly....
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 06-23-2012, 12:45 AM   #38
B2
"Racin Mason"# 4
B2's Avatar
Oddometer: 1,392
Hey
Any idea what pillion pegs i have to get to put on the RR soft luggage rack
thanks
Barry
Old 07-18-2012, 07:12 AM   #39
Maxacceleration
Maxacceleration's Avatar
Oddometer: 1,638
I see this thread has gone dead.
Lets wake it up!
I have 2012 690 Enduro and I am installing the twin 9.5 auxiliary tanks.
A lot is left up to interpretation from the instruction manual.
First on the 2012 with putting the rectifier behind the frame. Using the 10mm spacers behind the frame as stated, the rectifier hits the exhaust header and exhaust header bolt! Works with going only with the lower spacer.
NOW I ALWAYS THOUGHT THE RECTIFIER NEEDS TO BE IN A COOL SPOT FOR AIR FLOW AS A RECTIFIER HEATS UP???
It is buried in the hottest spot imaginable. ...The supplied selection of bolts don't fit. My bike runs hot (fan on) as it is.
HAS ANYONE TOASTED A RECTIFIER WHEN BURIED DOWN IN?
No replacement grommets for the top radiator mounts as pictured in the manual (???).
The double nut on the main tank bolts? One on the backside or both up front?
And what is with this side panel fitment? Do I have the side panel for the pre 2012's?
Lets hear it Rally Raid.
Oh, KTM Twins packing is haphazard. Small bubble wrap packages loose throughout. They could of easily bagged it all together - easy to toss out baggies...
I expected a more organized package for 900 plus dollars.
I AM WAITING FOR PHOTOBUCKET TO COME BACK ONLINE TO POST UP MY PICS ---- SOON I HOPE
Horsepower is a distant second to useable torque, unless cafe cruising is the reason for the purchase...
Originally Posted by DireWolf
Sounds dangerous.
Maxacceleration screwed with this post 07-18-2012 at 04:32 PM
Maxacceleration is offline   Reply With Quote
Old 07-18-2012, 11:47 AM   #40
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 170
Lets wake it up!
No replacement grommets for the top radiator mounts as pictured in the manual.
Got a version of the instructions electronically? Not sure what the change from the 2011 relocation of coil and rectifier. However, I can advise that the bracket to relocate has resulted in many a lost hour pulling bike apart to get it going again. I have ended up running a dedicated earth to bypass the issue
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 07-18-2012, 04:58 PM   #41
Maxacceleration
Oddometer: 1,638
Thanks blakrj
The coil does not have to be moved on the 12, only the rectifier to the inside of the frame. The coil & ground are not disrupted.
(coil on the inside of the frame)
Still worried that the rectifier will get baked... Its close!
Amazingly the side plastic compresses/bends in to fit where the overlap is pictured above. Makes for a swoopy curve.
I guess it will be ok after all (& picking up some bolts).
Sounds dangerous.
Maxacceleration screwed with this post 07-18-2012 at 05:17 PM
Old 07-18-2012, 10:20 PM   #42
Maxacceleration
Oddometer: 1,638
9.5 twin aux tanks
OK Rally Raid step up.
How bad are my side panels supposed to fit on my '12?
I just cannot strretch these side panels enough to fit the rear bolt.
The 'blades' that slide on the tank bracket are puckering due to the stress of trying to stretch these panels to fit.
Why did I pay 223 extra dollars for side panels that don't fit properly?
And is the rectifier supposed to sit 10mm from the header & header bolt?
How far out is the main tank bolt supposed to stick out?
One fall and that bolt is going to gouge through my plastic side panel.
ANYONE PUT THE 9.5 TWIN AUXILIARY TANKS ON A '12 690 YET?
FITMENT?
A sloppy kit IMO...
Sounds dangerous.
Maxacceleration screwed with this post 07-18-2012 at 10:38 PM
Old 07-19-2012, 11:02 AM   #43
Kirkster
Parts Murderer
Oddometer: 162
FITMENT?
A sloppy kit IMO...
Looks like you are the first... I have had my tank on order for a long time with no delivery from KTMTwins. Just sent them an email today to figure out where mine are...
Hopefully you will have all the bugs worked out so mine will just go right in...
I don't crash. I burn in and make a crater....
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
1972 Honda CL125 - Retired but ready to ride in AZ
Kirkster is offline   Reply With Quote
Old 07-19-2012, 11:49 AM   #44
beaney
rally racer
beaney's Avatar
Oddometer: 124
I think you've done something wrong, the tanks should fit tight against the frame and the stud should not stick out like that.
slacken all the tank mounts then line up the side panel, you'll never get it lined up with the tanks not sitting on the frame correctly
690 enduro/ rally
350 exc
RALLY-RAIDPRODUCTS.CO.UK
beaney is offline   Reply With Quote
Old 07-19-2012, 07:37 PM   #45
Maxacceleration
Oddometer: 1,638
beaney my tanks do fit tight against the frame. Solid and tight. The bolts stick out.
I did complete the install today. Maybe it could of been done different.
I could not get the tanks to rotate for good side panel fitment.
The tanks line up on the radiator well on each side.
Took a heat gun!
The supplied bolt selection was off and hopefully the updated rectifier mount (outboard) makes it to future customers.
Could of been just me but I sure did a lot of fit/re-fit over two days to get it close.
Not a smooth $900 kit but it went on.
Thank you ktmmitch for your pm's on advice.
Bring it on.
Sounds dangerous.
Times are GMT -7.   It's 09:42 AM.
