Old 06-01-2012, 08:11 AM   #1
Tangai OP
Oddometer: 596
Failed Balancer Shaft Seal, Symptoms?
KTM 950 Adventure 2005.5
I’ve read about some of you replacing the balancer shaft seal. What are the symptoms of a failed seal?
I assume the part you are replacing is what the parts manual calls the, “shaft seal ring” part #0760 122050?
Tangai is offline   Reply With Quote
Old 06-01-2012, 09:11 AM   #2
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,409
Lots of blow-by, lots of oil dripping down the front carb, lots of oil consumption. Changing this seal solves all of those problems.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 06-01-2012, 01:31 PM   #3
Tangai OP
Oddometer: 596
I haven't seen any of that, thanks
Old 06-01-2012, 01:42 PM   #4
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Aha. I think I am experiencing this. Need to take a look at this more closely.
What the Chuck!
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 12-02-2012, 06:35 AM   #5
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
Countershaft Seal Replacement
Are there any pictures of this job floating around, and/or sage advice? What has worked best to pull the old seal, for example? Don't see anything in the HOW..
erappaport is offline   Reply With Quote
Old 12-02-2012, 11:38 AM   #6
Snowhite808
Snowhite808's Avatar
Oddometer: 104
Just about the shaft seal replacement
here is my 2c.'
http://advrider.com/forums/showthread.php?t=843718
Snowhite808 is offline   Reply With Quote
Old 12-03-2012, 09:31 AM   #7
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
Thanks! Good pics, I just stumbled across your thread today, by luck. It looks like you can pop the old seal out by careful work with a screwdriver or some snap-ring pliers?
Also going to check the stator bolts while I'm in there, though still hunting around for the torque spec. Anybody know?
Times are GMT -7.   It's 03:33 AM.
