Old 06-01-2012, 03:32 PM   #1
murdock84 OP
Oddometer: 577
Rear Brake Lever Install Help
I ordered a Tourtech rear brake lever with the folding tip. I got the stock lever off and found that the Tourtech one needed the rear hole where the pin goes drilled out a little to get the pin back in. Anyway when I went to put the pin back and then install the brake lever the part that the pin attaches to came out of the little rubber boot. It doesn't appear to want to go back into the rubber boot and stay in place now. It looks like there is grease in there. How do I get this back in there properly?
Hell installing the GPS mount and wiring it up was easier then taking a bolt off the brake pedal and trying to get it back together.
murdock84 is offline   Reply With Quote
Old 06-02-2012, 03:03 AM   #2
JRP
Old guy
JRP's Avatar
Oddometer: 1,537
Nothing really holds that rod in except friction with the rubber boot if it is not attached to the brake lever. Just put it back in place and install the connecting pin.
"What could possibly go wrong? " The Jerk
2014 Royal Enfield Continental GT
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 06-02-2012, 06:18 AM   #3
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 275
put it all together and step on it and it will go right back in, had the same thing happen when I installed mine including having to enlarge the hole a bit
Angryrican is offline   Reply With Quote
Old 06-02-2012, 07:56 AM   #4
murdock84 OP
Oddometer: 577
Thanks guys. The bolt that holds the lever on won't go the whole way on now either. I think the threads are screwed up. Everytime I take something off, I have trouble getting it back on for some reason.
Old 06-02-2012, 09:24 PM   #5
murdock84 OP
Oddometer: 577
Got it all back together, hopefully correctly. Went out and bought a tap and die kit and that was the trick. I tightened it up to the specified tourque but had to loosen it up so the brake lever would return. Will ride it on Sunday to see if everything is fine. There is a little left and right play in the lever, is that normal?
Old 03-23-2013, 08:29 PM   #6
Makalu
Makalu's Avatar
Oddometer: 2,849
I’m getting ready to switch over to the TT rear brake lever also. After a quick look at the stock lever, how do you get that spring off to remove the lever?
Makalu is offline   Reply With Quote
Old 03-24-2013, 03:35 PM   #7
murdock84 OP
Oddometer: 577
I think it will come off when you unbolt it. I just went out and looked at mine and I don't recall anything giving me a problem except the threads in the bolt hole.
Old 03-24-2013, 05:28 PM   #8
JGoody
Oddometer: 291
Do you mean up and down play -- like the lever doesn't fit quite as precisely in the perch? If so I noticed that when I put in the Touratech clutch lever. Bothers me but seems to work fine.
JGoody is offline   Reply With Quote
Old 03-25-2013, 01:02 PM   #9
murdock84 OP
Oddometer: 577
No, the play is from bike side to away from the bike. Haven't had any issues since the install and it has gotten bounced around some off road, so I'm guessing it isn't going anywhere soon!
Old 03-30-2013, 08:02 AM   #10
Mtl_Biker
Mtl_Biker's Avatar
Oddometer: 652
Last night I wanted to install my Touratech folding rear brake lever (which had been on backorder for weeks with my dealer) and it just didn't look like it was going to be right...
My bike if a 2013 (if that makes a difference) F800GS and the stock foot brake lever curves above the foot peg and down to where you step on it. The Touratech appears (unless I've REALLY screwed up) to curve BELOW the foot peg and then back up to where you step on it.
This doesn't look right and it seems that the foot brake arm would now be the lowest part on that side of the bike and the most likely to touch the ground first when heeled over in a tight turn.
Is this the way it's supposed to be? Or did I end up with the wrong part or something?
Mtl_Biker is offline   Reply With Quote
Old 03-30-2013, 12:01 PM   #11
cchoc
Outdoor Photographer
cchoc's Avatar
Oddometer: 203
Thr picture on the Touratech site looks like it goes over the peg:
Charlie...
Stalking Light
'13 F800GS Kalamata Metallic
cchoc is offline   Reply With Quote
Old 03-30-2013, 05:41 PM   #12
Mtl_Biker
Mtl_Biker's Avatar
Oddometer: 652
Charlie, as I said on the other board, that's not the Touratech lever I have. Mine is: http://www.touratech-usa.com/Store/2...GS-F650GS-Twin
And it does go UNDER the foot peg. I don't like that at all as it'll be the first thing that hits ground in a hard leaning corner. When my dealer reopens after the Easter holiday I think I will return it and try to find another option.
Cheers!
Old 03-30-2013, 07:41 PM   #13
cchoc
cchoc's Avatar
Oddometer: 203
Ah, I see. The picture I posted was the folding adjustable one.
Sent from my iPad using Tapatalk
Charlie...
Stalking Light
cchoc screwed with this post 03-31-2013 at 05:44 AM
Old 03-30-2013, 08:11 PM   #14
Nacho911
Nacho911's Avatar
Oddometer: 472
For the cost is should come with a high definition video for the install.
Nacho911
Nacho911 is offline   Reply With Quote
Old 03-31-2013, 04:51 AM   #15
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 275
Cheers!
It is the right brake lever, it threw me off when I got mine since it curves under the foot peg but it fits and works fine.
Times are GMT -7.   It's 07:26 PM.
