Old 11-08-2012, 12:17 PM   #136
SlickSix OP
SlickSix's Avatar
Oddometer: 185
The cover itīs easy to remove with the engine in place, I donīt know what the fuss some guys do about it
Just lift it and at the same time bring the center bolt as far as it can go until it touches the frame and bring the cover to the side of the carb.the bolt will pass through.
Now, since I have to buy the spring, Iīll buy a chain too and maybe the slider that touches the tensioner. Or both?
They do seem fine, with only a wear just where the tip of the tensioner touches.
What say you?
SlickSix is offline   Reply With Quote
Old 11-08-2012, 12:23 PM   #137
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Originally Posted by mcma111 View Post
You got off easy.
Yup, real lucky. I should be thankful that she broke as soon as I started her and not when riding, minimizing the chance that for the tip to fall into the engine
About chains, are the aftermarket ones ok? I found a few on ebay that states they are made by Borg Warner? Theyīre the ones that supply Honda OEMs right?
Old 11-08-2012, 12:24 PM   #138
mcma111
Oddometer: 12,931
When the engine is set to TDC how do the cam gear marks line up? If off then get a chain. You don't need the slider.
Old 11-08-2012, 12:32 PM   #139
SlickSix OP
SlickSix's Avatar
Oddometer: 185
The chain is about half a tooth off but Iīll replace it just for piece of mind.
Itīs ok on the blades? Thanks Steve
By the way, do you have a spare tensioner you can sell? I want to have a spare.
Old 11-08-2012, 12:37 PM   #140
mcma111
Oddometer: 12,931
How many tensioners ya want? I have plenty.
Old 11-08-2012, 12:38 PM   #141
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Just sent you a pm. Make a price
Old 11-20-2012, 06:04 AM   #142
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Ok, some updates.
Already have the new chain and spring fitted and took some photos comparing the stretch on the old one
Did not expect to see so much difference, let me just upload them
Old 11-20-2012, 06:08 AM   #143
SlickSix OP
SlickSix's Avatar
Oddometer: 185
DID chain
side by side
Old 11-20-2012, 06:19 AM   #144
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Now, hereīs the kicker.
Canīt get her to fire no matter what, tryed all proven ways to start a thumper and no go.
After the rebuild, she started in 3-4 kicks, but heard the racket and shut her off.
The timing is good and thereīs not much to go wrong when installing the chain and tensioner spring so I went through
all the electrics again measuring and checking the connections. Everything checks out and I do have spark, but itīs a weak ass one
Next, I went to check the stator output at cranking speed and only got 30-35 vac max.
Altough the resistance checks out, the volts produced are not enough to fire the plug in the cilinder.
Old 11-20-2012, 06:26 AM   #145
SlickSix OP
SlickSix's Avatar
Oddometer: 185
I thought that was strange, since when I picked her up, she fired in 2-3 kicks and after the rebuild too.
Then, I thought about it for a while and got to the conclusion that (?) although the spark is weak, it was enough to fire when the compression was low due to wear on the piston and rings but now with a new heart, the 30 vac are not up to the job.
Another new task to learn, winding up the stator. That should be fun. Hey, itīs all in the spirit of the game right
Old 11-20-2012, 07:33 AM   #146
Jack90210
mindful
Jack90210's Avatar
Oddometer: 15,372
Ah man.
The suspense is killing me!
I must say that my son has exposed a reservoir of love and of worry within me that I never knew existed. --nskitts, 9/2/12
Jack90210 is offline   Reply With Quote
Old 11-20-2012, 07:47 AM   #147
elsalvadorklr
southern xr rider
Oddometer: 4,154
mike the yank just rewound his stock stator....I rewound my oem one twice
its easy just use very high quality high temp exposy to seal the winding after you rewind....ok?
good luck
yes 30vac is not enough...wasnt on my mild modded bike...my ricky stator was giving me 25 to 30vac as fast as I could kick
new stator and done
christian
check my thread for pics of the reound exciter coil...ask mike the yank for some pics too...he just did this and had success! I would order RICKY stator as a backup just in case if you can!
elsalvadorklr is offline   Reply With Quote
Old 11-20-2012, 08:16 AM   #148
SlickSix OP
SlickSix's Avatar
Oddometer: 185
The suspense is killing you ?!
What about me??? Iīm itching to get dirty and as soon as I think that today ill be the day, something comes up!
The day after I had her finished and all wrapped up, I got all geared up and ready to do some mean break in...
only to have the cam chain rattling about! Damn, I was pissed
Christian, I saw your thread and have a bunch of them bookmarked, I think Iīll be ok.
If I need, Iīll ask you for help
Old 11-20-2012, 08:36 AM   #149
elsalvadorklr
southern xr rider
Oddometer: 4,154
I know the feeling man!
good luck!
Old 11-20-2012, 08:43 AM   #150
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Thanks, when thereīs a will...
I wonīt be buying a new stator, I want to learn it the hard way
Also, a FCR and USDs are in the woks so...
Times are GMT -7.   It's 07:59 PM.
